The attached patch solves all my vdr tuning problems on a dib7000p
nova-t stick as far as I could check within the last weekend.
It disables streaming while tuning, like that the number of faulty TS
packets is reduced.
Signed-off-by: Soeren Moch <Soeren.Moch@stud.uni-hannover.de>
Signed-off-by: Patrick Boettcher <pb@linuxtv.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Forgot to initialize the timf_default field.
This changeset adds support for DiB7070P-based devices by adding the
dib0070-driver and putting the appropriate layouts into
dib0700_devices.c
It also includes a new firmware for the dib0700 which is necessary to
make the DiB7070-boards work and it also should fix the i2c-problems
on some boards.
Signed-off-by: Jean-Philippe Sibers <jpsibers@dibcom.fr>
Signed-off-by: Patrick Boettcher <pboettcher@dibcom.fr>
This changesets syncs the OpenSource driver for DiBcom demodulators
with version 2.1.3 of DiBcom reference driver. There were some
improvements since the last release for linux-dvb, e.g.:
- stepped AGC startup
- less space for initialization
- diversity synchronization
Furthermore this changeset contains the following things:
- latest AGC settings for MT2266-based devices (namely Nova-TD and other) will improve the sensitivity
- support for STK7700D reference design in dib0700-devices
- remove some line-breaks when debugging is enabled
- getting rid of layer between frontend_parameters and ofdm_channel used in dib*-drivers
Fix the misspellings of "propogate", "writting" and (oh, the shame
:-) "kenrel" in the source tree.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
This patch contains several fixes for the autosearch algorithm and other small ones.
First working version of the dib7000m-driver.
This commit also makes the Hauppauge NOVA-T Stick working.
Signed-off-by: Francois Kanounnikoff <fkanounnikoff@dibcom.fr>
Initial commit for the driver for the DiB7000M COFDM demodulator.
Signed-off-by: Francois KANOUNNIKOFF <fkanounnikoff@dibcom.fr>
