path: root/drivers/media/dvb/frontends/dib7000p.h
2012-08-13[media] move the dvb/frontends to drivers/media/dvb-frontendsMauro Carvalho Chehab
Raise the DVB frontends one level up, as the intention is to remove the drivers/media/dvb directory. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-24[media] dib7090: add the reference board TFE7090EOlivier Grenie
The intend of this patch is to add the support for the DiBcom reference board TFE7090E. Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-24[media] dib7000p/dib0090: update the driverOlivier Grenie
This patch intends to update the dib7000p and dib0090 driver in order to improve the performances. Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] DiBxxxx: Codingstype updatesOlivier Grenie
This patchs fix several conding-style violations. Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] DiB7090: add support for the dib7090 basedOlivier Grenie
This patch adds support for the SoC DiB7090 DVB-T demodulator and its melt-in UHF/VHF RF tuner. Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-09-27V4L/DVB: dib7000p: add disable sample and hold, and diversity delay parameterOlivier Grenie
This patch improves the overall driver performance in diversity-reception scenarios. Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr> Cc: stable@kernel.org Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-09-27V4L/DVB: dib7770: enable the current mirrorOlivier Grenie
To improve performance on DiB7770-devices enabling the current mirror is needed. This patch adds an option to the dib7000p-driver to do that and it creates a separate device-entry in dib0700-device to use those changes on hardware which is using the DiB7770. Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13212): fix gcc-4.3.3 compilation error at dib7000p_pid_filter(): ↵David T.L. Wong
missing parameter name Signed-off-by: David T.L. Wong <davidtlwong@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13049): dib8000: SNR in 10th of dBOlivier Grenie
dib7000p/dib8000: added pid filtering dib8000: the SNR is in 10th of dB (not in dB) dib7000p and dib8000: added the pid filtering. This feature is enabled by module option (dvb-usb module). Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10901): cleanup linewraps in dib7000p.hMichael Krufky
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10899): remove build-time dependencies on dib7000pMichael Krufky
2008-12-30V4L/DVB (9977): Kbuild: fix compilation when dib7000p is not definedMauro Carvalho Chehab
dib7000p.h defines a few extern symbols when CONFIG_DVB_DIB7000P is not set. since the header is used on more than one driver, this causes symbol duplication, as pointed by Ingo Molnar <mingo@elte.hu>: drivers/media/dvb/built-in.o: In function `dib7000p_set_gpio': (.text+0x3f242): multiple definition of `dib7000p_set_gpio' drivers/media/video/built-in.o:(.text+0xb8c1e): first defined here drivers/media/dvb/built-in.o: In function `dib7000p_i2c_enumeration': (.text+0x3f282): multiple definition of `dib7000p_i2c_enumeration' drivers/media/video/built-in.o:(.text+0xb8c3e): first defined here drivers/media/dvb/built-in.o: In function `dib7000p_set_wbd_ref': (.text+0x3f1c1): multiple definition of `dib7000p_set_wbd_ref' drivers/media/video/built-in.o:(.text+0xb8bfe): first defined here LD drivers/net/built-in.o make[2]: *** [drivers/media/built-in.o] Error 1 Cc: Patrick Boettcher <patrick.boettcher@desy.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8656): fix DVB_FE_CUSTOMISE for DVB_DIB7000P and DVB_TUNER_DIB0070 ↵Michael Krufky
with dvb-usb-cxusb Allow dvb-usb-cxusb to be built without dib7000p or dib0070 selected Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-06-05V4L/DVB (7916): dib7000p: fix dib7000p_attach when !CONFIG_DVB_DIB7000PMichael Krufky
somebody forgot to to fix this header... Thanks to Ingo Molnar for pointing this out. Tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7672): dib7000p: Add output mode param to the attach structSteven Toth
This allows future drivers to select the most appropriate output mode. Signed-off-by: Steven Toth <stoth@hauppauge.com> Reviewed-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5955): Add support for DiB7070-based devicesPatrick Boettcher
This changeset adds support for DiB7070P-based devices by adding the dib0070-driver and putting the appropriate layouts into dib0700_devices.c It also includes a new firmware for the dib0700 which is necessary to make the DiB7070-boards work and it also should fix the i2c-problems on some boards. Signed-off-by: Jean-Philippe Sibers <jpsibers@dibcom.fr> Signed-off-by: Patrick Boettcher <pboettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5954): Sync with DiBcom Driver Release 2.1.3 + some improvementsPatrick Boettcher
This changesets syncs the OpenSource driver for DiBcom demodulators with version 2.1.3 of DiBcom reference driver. There were some improvements since the last release for linux-dvb, e.g.: - stepped AGC startup - less space for initialization - diversity synchronization Furthermore this changeset contains the following things: - latest AGC settings for MT2266-based devices (namely Nova-TD and other) will improve the sensitivity - support for STK7700D reference design in dib0700-devices - remove some line-breaks when debugging is enabled - getting rid of layer between frontend_parameters and ofdm_channel used in dib*-drivers Signed-off-by: Patrick Boettcher <pboettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5914): Add initial support for Dual-DVB-T stickOlivier DANET
Add initial support for Dual-DVB-T stick based on DiB7700 and MT2266 - Microtune MT2266 driver. - Preliminary support for these dual tuner devices : - Pinnacle Dual DVB-T diversity - Terratec Cinergy DT USB XS diversity - Hauppauge Nova TD USB Signed-off-by: Olivier DANET <odanet@caramail.com> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4772): Add support for DiBcom DiB7000PCPatrick Boettcher
This patch contains support for the DiB7000PC-driver. Signed-off-by: Francois KANOUNNIKOFF <fkanounnikoff@dibcom.fr> Signed-off-by: Patrick Boettcher <pboettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
