somebody forgot to to fix this header...
Thanks to Ingo Molnar for pointing this out.
Tested-by: Ingo Molnar <mingo@elte.hu>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
This allows future drivers to select the most appropriate output mode.
Signed-off-by: Steven Toth <stoth@hauppauge.com>
Reviewed-by: Patrick Boettcher <pb@linuxtv.org>
This changeset adds support for DiB7070P-based devices by adding the
dib0070-driver and putting the appropriate layouts into
dib0700_devices.c
It also includes a new firmware for the dib0700 which is necessary to
make the DiB7070-boards work and it also should fix the i2c-problems
on some boards.
Signed-off-by: Jean-Philippe Sibers <jpsibers@dibcom.fr>
Signed-off-by: Patrick Boettcher <pboettcher@dibcom.fr>
This changesets syncs the OpenSource driver for DiBcom demodulators
with version 2.1.3 of DiBcom reference driver. There were some
improvements since the last release for linux-dvb, e.g.:
- stepped AGC startup
- less space for initialization
- diversity synchronization
Furthermore this changeset contains the following things:
- latest AGC settings for MT2266-based devices (namely Nova-TD and other) will improve the sensitivity
- support for STK7700D reference design in dib0700-devices
- remove some line-breaks when debugging is enabled
- getting rid of layer between frontend_parameters and ofdm_channel used in dib*-drivers
Add initial support for Dual-DVB-T stick based on DiB7700 and MT2266
- Microtune MT2266 driver.
- Preliminary support for these dual tuner devices :
- Pinnacle Dual DVB-T diversity
- Terratec Cinergy DT USB XS diversity
- Hauppauge Nova TD USB
Signed-off-by: Olivier DANET <odanet@caramail.com>
Signed-off-by: Patrick Boettcher <pb@linuxtv.org>
This patch contains support for the DiB7000PC-driver.
Signed-off-by: Francois KANOUNNIKOFF <fkanounnikoff@dibcom.fr>
