Raise the DVB frontends one level up, as the intention is to remove
the drivers/media/dvb directory.
The intend of this patch is to add the support for the DiBcom reference
board TFE7090E.
Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr>
Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr>
This patch intends to update the dib7000p and dib0090 driver in order to
improve the performances.
This patchs fix several conding-style violations.
This patch adds support for the SoC DiB7090 DVB-T demodulator and its
melt-in UHF/VHF RF tuner.
This patch improves the overall driver performance in
diversity-reception scenarios.
Cc: stable@kernel.org
To improve performance on DiB7770-devices enabling the current mirror
is needed.
This patch adds an option to the dib7000p-driver to do that and it
creates a separate device-entry in dib0700-device to use those changes
on hardware which is using the DiB7770.
missing parameter name
Signed-off-by: David T.L. Wong <davidtlwong@gmail.com>
dib7000p/dib8000: added pid filtering
dib8000: the SNR is in 10th of dB (not in dB)
dib7000p and dib8000: added the pid filtering. This feature is enabled by module option (dvb-usb module).
Signed-off-by: Patrick Boettcher <pboettcher@kernellabs.com>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
dib7000p.h defines a few extern symbols when CONFIG_DVB_DIB7000P is not set. since the
header is used on more than one driver, this causes symbol duplication, as pointed by
Ingo Molnar <mingo@elte.hu>:
drivers/media/dvb/built-in.o: In function `dib7000p_set_gpio':
(.text+0x3f242): multiple definition of `dib7000p_set_gpio'
drivers/media/video/built-in.o:(.text+0xb8c1e): first defined here
drivers/media/dvb/built-in.o: In function `dib7000p_i2c_enumeration':
(.text+0x3f282): multiple definition of `dib7000p_i2c_enumeration'
drivers/media/video/built-in.o:(.text+0xb8c3e): first defined here
drivers/media/dvb/built-in.o: In function `dib7000p_set_wbd_ref':
(.text+0x3f1c1): multiple definition of `dib7000p_set_wbd_ref'
drivers/media/video/built-in.o:(.text+0xb8bfe): first defined here
LD drivers/net/built-in.o
make[2]: *** [drivers/media/built-in.o] Error 1
Cc: Patrick Boettcher <patrick.boettcher@desy.de>
with dvb-usb-cxusb
Allow dvb-usb-cxusb to be built without dib7000p or dib0070 selected
somebody forgot to to fix this header...
Thanks to Ingo Molnar for pointing this out.
Tested-by: Ingo Molnar <mingo@elte.hu>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
This allows future drivers to select the most appropriate output mode.
Signed-off-by: Steven Toth <stoth@hauppauge.com>
Reviewed-by: Patrick Boettcher <pb@linuxtv.org>
This changeset adds support for DiB7070P-based devices by adding the
dib0070-driver and putting the appropriate layouts into
dib0700_devices.c
It also includes a new firmware for the dib0700 which is necessary to
make the DiB7070-boards work and it also should fix the i2c-problems
on some boards.
Signed-off-by: Jean-Philippe Sibers <jpsibers@dibcom.fr>
Signed-off-by: Patrick Boettcher <pboettcher@dibcom.fr>
This changesets syncs the OpenSource driver for DiBcom demodulators
with version 2.1.3 of DiBcom reference driver. There were some
improvements since the last release for linux-dvb, e.g.:
- stepped AGC startup
- less space for initialization
- diversity synchronization
Furthermore this changeset contains the following things:
- latest AGC settings for MT2266-based devices (namely Nova-TD and other) will improve the sensitivity
- support for STK7700D reference design in dib0700-devices
- remove some line-breaks when debugging is enabled
- getting rid of layer between frontend_parameters and ofdm_channel used in dib*-drivers
Add initial support for Dual-DVB-T stick based on DiB7700 and MT2266
- Microtune MT2266 driver.
- Preliminary support for these dual tuner devices :
- Pinnacle Dual DVB-T diversity
- Terratec Cinergy DT USB XS diversity
- Hauppauge Nova TD USB
Signed-off-by: Olivier DANET <odanet@caramail.com>
Signed-off-by: Patrick Boettcher <pb@linuxtv.org>
This patch contains support for the DiB7000PC-driver.
Signed-off-by: Francois KANOUNNIKOFF <fkanounnikoff@dibcom.fr>
