Since at least kernel 2.6.12-rc2, module.h includes moduleparm.h. This
patch removes all occurences of moduleparm.h from drivers/media files.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
pointer field inside dvb_frontend
The dvb_frontend_ops is a pointer inside dvb_frontend. That's why every demod-driver
is having a field of dvb_frontend_ops in its private-state-struct and
using the reference for filling the pointer-field in dvb_frontend.
- It saves at least two lines of code per demod-driver,
- reduces object size (one less dereference per frontend_ops-access),
- be coherent with dvb_tuner_ops,
- makes it a little bit easier for newbies to understand how it works and
- avoids stupid mistakes because you would have to copy the dvb_frontend_ops
always, before you could assign the static pointer directly, which was
dangerous.
Signed-off-by: Patrick Boettcher <pb@linuxtv.org>
Make it call the tuner calls - in case someone wants to use it to develop a
tuner without a demod.
Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net>
This is the drivers/media/ part of the big kfree cleanup patch.
Remove pointless checks for NULL prior to calling kfree() in drivers/media/.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Cc: Johannes Stezenbach <js@linuxtv.org>
Cc: Michael Krufky <mkrufky@m1k.net>
Cc: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
Acked-by : Manu Abraham <manu@linuxtv.org>
Acked-by: Andreas Oberritter <obi@linuxtv.org>
Acked-by: Wilson Michaels <wilsonmichaels@earthlink.net>
I recently picked up my older work to remove unnecessary #includes of
sched.h, starting from a patch by Dave Jones to not include sched.h
from module.h. This reduces the number of indirect includes of sched.h
by ~300. Another ~400 pointless direct includes can be removed after
this disentangling (patch to follow later).
However, quite a few indirect includes need to be fixed up for this.
In order to feed the patches through -mm with as little disturbance as
possible, I've split out the fixes I accumulated up to now (complete for
i386 and x86_64, more archs to follow later) and post them before the real
patch. This way this large part of the patch is kept simple with only
adding #includes, and all hunks are independent of each other. So if any
hunk rejects or gets in the way of other patches, just drop it. My scripts
will pick it up again in the next round.
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
remove unnecessary casts in frontends (Kenneth Aafloy)
Signed-off-by: Johannes Stezenbach <js@linuxtv.org>
infrastructure for it.
Let it rip!
