The signal bit is unreliable on the DT3304 in QAM mode, so
set FE_HAS_SIGNAL based on 'cr_lock'
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com>
There's a currently-unused lgdt3304 demod driver, which leaves a lot to
be desired as far as functionality. The 3304 is unsurprisingly quite
similar to the 3305, and empirical testing yeilds far better results
and more complete functionality by merging 3304 support into the 3305
driver. (For example, the current lgdt3304 driver lacks support for
signal strength, snr, ucblocks, etc., which we get w/the lgdt3305).
For the moment, not dropping the lgdt3304 driver, and its still up to
a given device's config setup to choose which demod driver to use, but
I'd suggest dropping the 3304 driver entirely.
As a follow-up to this patch, I've got another patch that adds support
for the KWorld PlusTV 340U (ATSC) em2870-based tuner stick, driving
its lgdt3304 demod via this lgdt3305 driver, which is what I used to
successfully test this patch with both VSB_8 and QAM_256 signals.
A few pieces are still a touch crude, but I think its a solid start,
as well as much cleaner and more feature-complete than the existing
lgdt3304 driver.
Signed-off-by: Jarod Wilson <jarod@redhat.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Signed-off-by: Michael Krufky <kernellabs.com>
Setting state->frontend.demodulator_priv to NULL in the event of
a kzalloc error will result in an OOPS. Just remove that line.
Thanks to Matthias Schwarzott for pointing this out.
Cc: Matthias Schwarzott <zzam@gentoo.org>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
We'll start off with MODULE_VERSION("0.1")
small whitespace cleanup - space missing after the *
