Raise the DVB frontends one level up, as the intention is to remove
the drivers/media/dvb directory.
kconfig description
This patch does some small cleanup to mt312.
It changes kconfig description to also list the ZL10313.
It does change some strange symbol names to be consistent with
module name mt312 and naming of all other functions in there.
* vp310_mt312_ops -> mt312_ops
* vp310_mt312_attach -> mt312_attach
Adds a MODULE_AUTHOR for me
Signed-off-by: Matthias Schwarzott <zzam@gentoo.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Make it unsigned (0/1) rather than signed (0/-1).
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Add a setting to config struct for inversion of lnb-voltage.
Needed for support of Avermedia A700 cards.
__FUNCTION__ is gcc-specific, use __func__
Acked-by: Oliver Endriss <o.endriss@gmx.de>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
When a front-end is disabled, card drivers that use it are compiled with
a stub version of the front-end's attach function. This way they have no
references to the front-end's code and don't need it to be loaded.
If a card driver is compiled into the kernel, and a front-end is a
module, then that front-end is effectively disabled wrt the card driver.
In this case, the card driver should get the stub version. This was not
happening.
The stub vs real attach function selection is changed so that when the
front-end is a module the real attach function is only used if the card
driver is a module as well. This means a module front-end will be
supported by card drivers that are modules and not supported by card
drivers compiled into the kernel.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Allow it to be en/disabled
Disable it in < 2.6.17 due to symbol_xxx() bug
Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net>
Acked-by: Michael Krufky <mkrufky@linuxtv.org>
Acked-by: Trent Piepho <xyzzy@speakeasy.org>
Convert to tuner_ops calls.
Remove pll function pointers from structure.
Remove unneeded tuner calls.
Add i2c gate control function.
This patch contains the following possible cleanups:
- update the Kconfig help to mention the VP310
- merge vp310_attach and mt312_attach into a new vp310_mt312_attach
to remove some code duplication
infrastructure for it.
Let it rip!
