path: root/drivers/media/dvb/frontends/tda1004x.h
2008-04-24V4L/DVB (7514): media/dvb/frontends replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7393): tda827x: fixed support of tuners with LNAHartmut Hackmann
Tuner refactoring broke support of tuners with LNA configurations 1 and 2 for both, analog TV and DVB-T. Additionally, this patch initializes the saa713x gpios defined by the gpiomask at driver init to avoid undefined stated at dvb. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5458): Tda1004x: add ts_mode option to config structHartmut Hackmann
The struct tda1004x_config has a new entry: .ts_mode Possible values are TDA10046_TS_PARALLEL or TDA10046_TS_SERIAL There always is only one interface active, default is parallel. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5317): Create tda827x dvb tuner moduleMichael Krufky
The patch moves the tda827x dvb tuning code to a separate module Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5311): Tda1004x driver updatesHartmut Hackmann
There are the following changes: - separate configuration of IF and GPIOs. - set GPIOs before firmware load. This helps to avoid I2C address collisions. - if desired invert GPIOs at sleep (automatic return to analog mode of card). - added 3 tuner configuration bytes to config stuct. - added i2c gate address to config struct. - moved _state struct declaration to header file to make it accessible on board layer. - added "conf_probed" to the state struct to allow i.e. probing for correct tuner version. - changed firmware load mechanism to always: + check if already loaded + try to boot from eeprom + try downlad from host - corrected name of tda10046 firmware image (backward compatible). Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4835): Added support for the Terratec Cinergy HT PCMCIA moduleHartmut Hackmann
This is a hybrid cardbus module. Besides the card support, i modified the definition names for AGC and GPIO of the tda10046. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-11-03V4L/DVB (4751): Fix DBV_FE_CUSTOMISE for card drivers compiled into kernelTrent Piepho
When a front-end is disabled, card drivers that use it are compiled with a stub version of the front-end's attach function. This way they have no references to the front-end's code and don't need it to be loaded. If a card driver is compiled into the kernel, and a front-end is a module, then that front-end is effectively disabled wrt the card driver. In this case, the card driver should get the stub version. This was not happening. The stub vs real attach function selection is changed so that when the front-end is a module the real attach function is only used if the card driver is a module as well. This means a module front-end will be supported by card drivers that are modules and not supported by card drivers compiled into the kernel. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4387): Add Kconfig infrastructure for dvb_attachAndrew de Quincey
Allow it to be en/disabled Disable it in < 2.6.17 due to symbol_xxx() bug Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Acked-by: Michael Krufky <mkrufky@linuxtv.org> Acked-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4384): Remove remaining static function callsAndrew de Quincey
Rewrote _write() calls to use write() op. Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Acked-by: Michael Krufky <mkrufky@linuxtv.org> Acked-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3858): Convert tda1004x to refactored tuner codeAndrew de Quincey
Convert to tuner_ops calls. Remove pll function pointers from structure. Remove unneeded tuner calls. Add i2c gate control function. Remove europa specific hack (moved into appropriate card driver) Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-02-07V4L/DVB (3304): TDA10046 Driver updateHartmut Hackmann
- Set outputs to tristate in sleep mode - Reduce dangerously high firmware download speed with 16MHz xtal - added tda827x configuration with GPIOs low - added comments to stupid looking IIC reads that work around bugs in the tda10046. - some minor updates Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2005-07-07[PATCH] dvb: frontend: tda1004x: support tda827x tunersHartmut Hackmann
o added preliminary support for tda827x tuners o set parameters for drift compensation to 0 makes no sense for DVB-T but can prevent lock Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] dvb: frontend: tda1004x updateHartmut Hackmann
o added config options for IF frequency and AGC o support DSP boot from on board eeprom o added pll sleep call Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] dvb: tda1004x: allow N_I2C to be overridden by the card driverJohannes Stezenbach
allow N_I2C to be overridden by the card driver (Andreas Oberritter) Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] dvb: tda1004x: dont use bitfieldsJohannes Stezenbach
use simple u8 instead of bitfields (Andreas Oberritter) Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
