path: root/drivers/media/dvb/frontends/tda10086.c
2008-04-24V4L/DVB (7655): tda10086 coding stlye fixesHartmut Hackmann
This patch replaces the c++ style comments. No functional changes Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7654): tda10086: make the xtal frequency a configuration optionHartmut Hackmann
Some DVB-S boards, i.e. with the SD1878 tuner, use a 4 MHz reference frequency. This reqires a different setup of the clock PLL. This patch adds an enum to the tda10086_config struct and sets the proper values for the boards. This patch also fixes the DVB-S section of the MD7134_BRIDGE_2 Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7514): media/dvb/frontends replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7094): static memoryDouglas Schilling Landgraf
- Static memory is always initialized with 0. - Replaced in some cases C99 comments for /* */ Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7186): tda10086: make the 22kHz tone for DISEQC a config optionHartmut Hackmann
Some cards need the diseqc signal modulated, while some just need the envelope to control the LNB supply. This fixes Bug 9887 Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Acked-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-12-11V4L/DVB (6579): Fix bug #8824: Correct support for Diseqc on tda10086Hartmut Hackmann
This is a modified version of a patch previously posted by Thomas Unverzagt. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6079): Cleanup: remove linux/moduleparam.h from drivers/media filesMauro Carvalho Chehab
Since at least kernel 2.6.12-rc2, module.h includes moduleparm.h. This patch removes all occurences of moduleparm.h from drivers/media files. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-06-08V4L/DVB (5716): Tda10086,tda826x: fix tuning, STR/SNR valuesOliver Endriss
Several people reported unreliable reception with the current driver. Furthermore, STR and SNR values seem to be inverted. This fix is based on a patch posted by Hartmut Hackman. Thanks to Helmut Auer for testing and helping to optimize the patch. tda826x: - set baseband cut-off to 19 MHz tda10086: - change the parameters of the carrier recovery loop - toggle register 0x02 between 0x35 (tuning) and 0x00 (locked) - invert STR and SNR values Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-02V4L/DVB (5495): Tda10086: fix DiSEqC message lengthAndreas Oberritter
Setting the message length to zero means to send one byte, so you need a subtraction instead of an addition. Signed-off-by: Andreas Oberritter <obi@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-11-26V4L/DVB (4874): Fix oops on symbol rate==0Andrew de Quincey
The tda10086 causes an oops (divide by zero) if a zero symbol rate is used; this prevents this. Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4401): Disable tda10086 debug by default.Andrew de Quincey
Left on by accident. Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4396): Add drivers for tda10086 + tda826x chipsAndrew de Quincey
TDA10086 is a new DVB-S demodulator TDA826x is a DVB-S Silicon Tuner Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
