git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (505 commits)
[media] af9015: Fix max I2C message size when used with tda18271
[media] IR: initialize ir_raw_event in few more drivers
[media] Guard a divide in v4l1 compat layer
[media] imon: fix nomouse modprobe option
[media] imon: remove redundant change_protocol call
[media] imon: fix my egregious brown paper bag w/rdev/idev split
[media] cafe_ccic: Configure ov7670 correctly
[media] ov7670: allow configuration of image size, clock speed, and I/O method
[media] af9015: support for DigitalNow TinyTwin v3 [1f4d:9016]
[media] af9015: map DigitalNow TinyTwin v2 remote
[media] DigitalNow TinyTwin remote controller
[media] af9015: RC fixes and improvements
videodev2.h.xml: Update to reflect the latest changes at videodev2.h
[media] v4l: document new Bayer and monochrome pixel formats
[media] DocBook/v4l: Add missing formats used on gspca cpia1 and sn9c2028
[media] firedtv: add parameter to fake ca_system_ids in CA_INFO
[media] tm6000: fix a macro coding style issue
tm6000: Remove some ugly debug code
[media] Nova-S-Plus audio line input
[media] [RFC,1/1] V4L2: Use new CAP bits in existing RDS capable drivers
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
Extend the error handling code with operations found in other nearby error
handling code.
A simplified version of the sematic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
@r@
statement S1,S2,S3;
constant C1,C2,C3;
*if (...)
{... S1 return -C1;}
*if (...)
{... when != S1
return -C2;}
*if (...)
{... S1 return -C3;}
// </smpl>
The patch below updates broken web addresses in the kernel
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Acked-by: Ben Pfaff <blp@cs.stanford.edu>
Acked-by: Hans J. Koch <hjk@linutronix.de>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
This requires changing all users of dvb_usercopy to
omit the inode argument.
Some whitespace adjustments.
Signed-off-by: Oliver Endriss <o.endriss@gmx.de>
av7110_av_start_play() should return 0 on success.
Fixed VIDEO_SLOWMOTION ioctl.
Discard PES packet if transport error indicator flag is set.
Implemented TS replay capability.
audio/video devices are able to process PES and TS data now.
dvb: constify VFTs
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Add support for the 'full-ts' hardware modification.
On full-featured cards the data throughput is limited by the hardware
design. The full-ts mod removes this bottleneck, i.e. the card is able
to deliver the complete transport stream of a transponder.
For details see http://www.escape-edv.de/endriss/dvb-full-ts-mod
split the suckers into kernel-memory and user-memory versions,
annotate both properly.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
direct dereferencing from user-supplied address
Reviewed-by: Oliver Endriss <o.endriss@gmx.de>
Improved display of still pictures (VIDEO_STILLPICTURE ioctl).
Ensure that both fields are displayed for progressive frames.
Thanks to Reinhard Nissl and Klaus Schmidinger for finding out
that the FREEZE command does this.
Thanks-to: Reinhard Nissl <rnissl@gmx.de>
Thanks-to: Klaus Schmidinger <Klaus.Schmidinger@cadsoft.de>
Remove V4L1 code.
Signed-off-by: Marco Schluessler <marco@lordzodiac.de>
crash
Re-initialize aspect ratio and pan scan after arm crash.
kernel 2.6.22)
Fix signedness warnings (gcc 4.1.1, kernel 2.6.22).
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
The cx23415 adds some extra features that this DVB decoding API did
not support. This API has been expanded to support the required
features. Both source and binary backwards compatibility is kept
intact by these changes. So existing applications are not affected.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Ralph Metzler <rjkm@metzlerbros.de>
The patch removes unneeded void * casts for the following (void *) pointers:
- struct file: private_data
- struct dvb_device: priv
- struct dvb_demux: priv
- struct dvb_adapter: priv
The patch also contains some whitespace and coding style cleanups in the
relevant areas.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Since av7110.c is the only file actually using something from this
header, there's no reson for other files to
Added support for the msp34x5 audio dac. Analog sound output of
Technotrend DVB-C 2300 (aka Hauppauge Nexus-CA) works now.
Signed-off-by: Tim Kaiser <timkaiser@t-online.de>
This attached patch was originally proposed by Anssi Hannula to the dvb-kernel
user to choose the default broadcast mode when using the ttpci driver.
NTSC users need to only add the following line to modprobe.d:
options dvb-ttpci tv_standard=1
PAL users will not need to change anything, for this will be the default.
Signed-off-by: C.Y.M <syphir@syphir.sytes.net>
- Driver support for live-ac3, firmware >= 2621 required.
Signed-off-by: Dr. Werner Fink <werner@suse.de>
Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
- Fixed mpeg audio on spdif from Nexus-CA card (rev 2.3),
definitions for sound chip MSP3415
Fix indentation and add some whitepsace between operators.
Signed-off-by: Johannes Stezenbach <js@linuxtv.org>
o propagate more errors back to caller or log them, mainly in
av7110.c and av7110_av.c
o fix error message in StartHWFilter
o do not StopHWFilter for handle 0xffff
Signed-off-by: Wolfgang Rohdewald <wolfgang@rohdewald.de>
Fixed typo in AUDUIO_CONTINUE ioctl: AUDIO_CMD_MUTE -> AUDIO_CMD_UNMUTE
Signed-off-by: "Dr. Werner Fink" <werner@suse.de>
Modified dvb_register_adapter() to avoid kmalloc/kfree. Drivers have to embed
struct dvb_adapter into their private data struct from now on. (Andreas
Oberritter)
VIDEO_SET_DISPLAY_FORMAT ioctl fixed:
set videostate.display_format, not videostate.video_format (Oliver Endriss)
Switch analog output of the Crystal sound chip to left/stereo/right mode.
This will fix problems with some (most?) channels which do not encode
2-channel audio correctly. (Oliver Endriss)
infrastructure for it.
Let it rip!
