path: root/drivers/media/dvb/ttusb-dec/ttusbdecfe.c
2008-10-12V4L/DVB (9040): TTUSB-DEC DVB-S: claim to have lockPeter Beutner
As reported by BOUWSMA Barry the readout of the signal status doesn't work on dec3000-s models. Since we don't know how to do it better, revert back to the old behaviour and always report a signal lock. Reported by Barry Bouwsma Signed-off-by: Peter Beutner <p.beutner@gmx.net> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-06-05V4L/DVB (7962): ttusb endianness annotations and fixesAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7517): media/dvb/ttusb-dec replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25V4L/DVB (4028): Change dvb_frontend_ops to be a real field instead of a ↵Patrick Boettcher
pointer field inside dvb_frontend The dvb_frontend_ops is a pointer inside dvb_frontend. That's why every demod-driver is having a field of dvb_frontend_ops in its private-state-struct and using the reference for filling the pointer-field in dvb_frontend. - It saves at least two lines of code per demod-driver, - reduces object size (one less dereference per frontend_ops-access), - be coherent with dvb_tuner_ops, - makes it a little bit easier for newbies to understand how it works and - avoids stupid mistakes because you would have to copy the dvb_frontend_ops always, before you could assign the static pointer directly, which was dangerous. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09V4L/DVB (3154): TTUSB DEC driver patch roundupAlex Woods
- Collection of patches from Peter Beutner addressing: - add symbolrates to the DVB-S frontend description - fix capability flags in DVB-S frontend describtion - remove some void casts - disable zig-zag scanning as it makes no sense for DVB-T - set sensible min_delay value - return an error for requested filter types the driver can't handle Signed-off-by: Peter Beutner <p.beutner@gmx.net> Signed-off-by: Alex Woods <linux-dvb@giblets.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-07-07[PATCH] dvb: ttusb-dec: kfree cleanupAdrian Bunk
The Coverity checker discovered that these two kfree's can never be executed. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
