Add a V4L2 sub-device driver for the Sony IMX214 image sensor.
This is a camera sensor using the I2C bus for control and the
CSI-2 bus for data.
Tested on a DB820c alike board with Intrinsyc Open-Q 13MP camera.
[Sakari Ailus: squash exposure time max limit patch]
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
Reviewed-by: Jacopo Mondi <jacopo@jmondi.org>
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
Add a v4l2 sub-device driver for the Sony imx355 image sensor.
This is a camera sensor using the i2c bus for control and the
csi-2 bus for data.
This driver supports following features:
- manual exposure and analog/digital gain control support
- vblank/hblank control support
- 4 test patterns control support
- vflip/hflip control support (will impact the output bayer order)
- support following resolutions:
- 3268x2448, 3264x2448, 3280x2464 @ 30fps
- 1940x1096, 1936x1096, 1924x1080, 1920x1080 @ 60fps
- 1640x1232, 1640x922, 1300x736, 1296x736,
1284x720, 1280x720 820x616 @ 120fps
- support 4 bayer orders output (via change v/hflip)
- SRGGB10(default), SGRBG10, SGBRG10, SBGGR10
[Sakari Ailus: Use do_div() for dividing 64-bit numbers, fix fwnode if usage]
Cc: Tomasz Figa <tfiga@chromium.org>
Signed-off-by: Tianshu Qiu <tian.shu.qiu@intel.com>
Signed-off-by: Bingbu Cao <bingbu.cao@intel.com>
Add a v4l2 sub-device driver for the Sony imx319 image sensor.
csi-2 bus for data.
- 3264x2448, 3280x2464 @ 30fps
- 1936x1096, 1920x1080 @ 60fps
- 1640x1232, 1640x922, 1296x736, 1280x720 @ 120fps
[Sakari Ailus: Replace 64-bit division by do_div(), fix fwnode if usage]
This patch adds V4L2 sub-device driver for OV2680 image sensor.
The OV2680 is a 1/5" CMOS color sensor from Omnivision.
Supports output format: 10-bit Raw RGB.
The OV2680 has a single lane MIPI interface.
The driver exposes following V4L2 controls:
- auto/manual exposure,
- exposure,
- auto/manual gain,
- gain,
- horizontal/vertical flip,
- test pattern menu.
Supported resolution are only: QUXGA, 720P, UXGA.
[Sakari Ailus: Drop "-level" from Kconfig help text]
Signed-off-by: Rui Miguel Silva <rui.silva@linaro.org>
Add V4L2 sensor driver for Aptina MT9V111 CMOS image sensor.
The MT9V111 is a 1/4-Inch CMOS image sensor based on MT9V011 with an
integrated Image Flow Processor.
Reviewed-by: Kieran Bingham <kieran.bingham+renesas@ideasonboard.com>
Signed-off-by: Jacopo Mondi <jacopo+renesas@jmondi.org>
The dw9807 contains a voice coil lens driver as well as an EEPROM. This
driver is just for the VCM. Reflect this in the driver's name --- this is
already the case for the compatible string, for instance.
Add a v4l2 sub-device driver for the ak7375 lens voice coil.
This is a voice coil module using the i2c bus to control the
focus position.
ak7375 can write multiple bytes of data at a time. If more
data is received instead of the stop condition after receiving
one byte of data, the address inside the chip is automatically
incremented and the data is written into the next address.
The ak7375 can control the position with 12 bits value and
consists of two 8 bit registers show as below:
register 0x00(AK7375_REG_POSITION):
|D11|D10|D09|D08|D07|D06|D05|D04|
register 0x01:
|D03|D02|D01|D00|---|---|---|---|
This driver support :
- set ak7375 to standby mode once suspend and
turn it back to active if resume
- set the position via V4L2_CID_FOCUS_ABSOLUTE ctrl
[Sakari Ailus: Rename val as ret in probe, drop redundant error message]
DW9807 is a 10 bit DAC from Dongwoon, designed for linear
control of voice coil motor.
This driver creates a V4L2 subdevice and
provides control to set the desired focus.
Signed-off-by: Alan Chiang <alanx.chiang@intel.com>
Signed-off-by: Andy Yeh <andy.yeh@intel.com>
Reviewed-by: Tomasz Figa <tfiga@chromium.org>
Remove soc_camera framework dependencies from rj54n1 sensor driver.
- Handle clock
- Handle GPIOs (named 'powerup' and 'enable')
- Register the async subdevice
- Remove g/s_mbus_config as they're deprecated.
- Adjust build system
- List the driver as maintained for 'Odd Fixes' as I don't have HW to test.
This commits does not remove the original soc_camera based driver.
Compiled tested only.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Add a V4L2 sub-device driver for the Sony IMX258 image sensor.
CSI-2 bus for data.
Signed-off-by: Jason Chen <jasonx.z.chen@intel.com>
The ov7251 sensor is a 1/7.5-Inch B&W VGA (640x480) CMOS Digital Image
Sensor from Omnivision.
The driver supports the following modes:
- 640x480 30fps
- 640x480 60fps
- 640x480 90fps
Output format is 10bit B&W RAW - MEDIA_BUS_FMT_Y10_1X10.
The driver supports configuration via user controls for:
- exposure and gain;
- horizontal and vertical flip;
- test pattern.
[Sakari Ailus: Wrap a line over 80 characters, fix trivial sparse warning]
Signed-off-by: Todor Tomov <todor.tomov@linaro.org>
There are several thermal sensors that only have a low-speed bus
interface but output valid video data. This patchset enables support
for the AMG88xx "Grid-Eye" sensor family.
Signed-off-by: Matt Ranostay <matt.ranostay@konsulko.com>
Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com>
[hans.verkuil@cisco.com: split up int ret = ...->xfer(); line]
Signed-off-by: Hans Verkuil <hansverk@cisco.com>
Remove soc_camera framework dependencies from mt9t112 sensor driver.
- Handle clk, gpios and power routines
- Register async subdev
- Remove deprecated g/s_mbus_config operations
- Remove driver flags
- Change driver interface and add kernel doc
- Fix code style issues reported by checkpatch in strict mode
This commit does not remove the original soc_camera based driver as long
as other platforms depends on soc_camera framework.
As I don't have access to a working camera module, this change has only
been compile tested.
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
Remove soc_camera framework dependencies from tw9910 sensor driver.
- Handle clock and gpios
- Register async subdevice
- Remove soc_camera specific g/s_mbus_config operations
- Add kernel doc to driver interface header file
as other platforms depends on soc_camera-based CEU driver.
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Remove soc_camera framework dependencies from ov772x sensor driver.
- Change image format colorspace from JPEG to SRGB as the two use the
same colorspace information but JPEG makes assumptions on color
components quantization that do not apply to the sensor
- Remove sizes crop from get_selection as driver can't scale
This patch adds driver for Omnivision's ov2685 sensor.
Though the ov2685 can output yuv data, this driver only
supports the raw bayer format, including the following features:
- output 1600x1200 at 30fps
- test patterns
- manual exposure/gain control
- vblank and hblank
- media controller
- runtime pm
[Sakari Ailus: trivial: ov5695_of_match -> ov2685_of_match]
Signed-off-by: Shunqian Zheng <zhengsq@rock-chips.com>
Reviewed-by: Jacopo Mondi <jacopo+renesas@jmondi.org>
This patch adds driver for Omnivision's ov5695 sensor,
the driver supports following features:
- supported resolutions
+ 2592x1944 at 30fps
+ 1920x1080 at 30fps
+ 1296x972 at 60fps
+ 1280x720 at 30fps
+ 640x480 at 120fps
- test patterns
- manual exposure/gain(analog and digital) control
- vblank and hblank
- media controller
- runtime pm
Add support for the TDA1997x HDMI receivers.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
[hans.verkuil@cisco.com: fix type 'testin' -> 'testing']
The ov7740 (color) image sensor is a high performance VGA CMOS
image snesor, which supports for output formats: RAW RGB and YUV
and image sizes: VGA, and QVGA, CIF and any size smaller.
Signed-off-by: Songjun Wu <songjun.wu@microchip.com>
Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
Remove the V4L2 AS3645A sub-device driver in favour of the LED flash class
driver for the same hardware, drivers/leds/leds-as3645a.c. The latter uses
the V4L2 flash LED class framework to provide V4L2 sub-device interface.
Acked-by: Pavel Machek <pavel@ucw.cz>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- Documentation for digital TV (both kAPI and uAPI) are now in sync
with the implementation (except for legacy/deprecated ioctls). This
is a major step, as there were always a gap there
- New sensor driver: imx274
- New cec driver: cec-gpio
- New platform driver for rockship rga and tegra CEC
- New RC driver: tango-ir
- Several cleanups at atomisp driver
- Core improvements for RC, CEC, V4L2 async probing support and DVB
- Lots of drivers cleanup, fixes and improvements.
* tag 'media/v4.15-1' of ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (332 commits)
dvb_frontend: don't use-after-free the frontend struct
media: dib0700: fix invalid dvb_detach argument
media: v4l2-ctrls: Don't validate BITMASK twice
media: s5p-mfc: fix lockdep warning
media: dvb-core: always call invoke_release() in fe_free()
media: usb: dvb-usb-v2: dvb_usb_core: remove redundant code in dvb_usb_fe_sleep
media: au0828: make const array addr_list static
media: cx88: make const arrays default_addr_list and pvr2000_addr_list static
media: drxd: make const array fastIncrDecLUT static
media: usb: fix spelling mistake: "synchronuously" -> "synchronously"
media: ddbridge: fix build warnings
media: av7110: avoid 2038 overflow in debug print
media: Don't do DMA on stack for firmware upload in the AS102 driver
media: v4l: async: fix unregister for implicitly registered sub-device notifiers
media: v4l: async: fix return of unitialized variable ret
media: imx274: fix missing return assignment from call to imx274_mode_regs
media: camss-vfe: always initialize reg at vfe_set_xbar_cfg()
media: atomisp: make function calls cleaner
media: atomisp: get rid of storage_class.h
media: atomisp: get rid of wrong stddef.h include
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
The imx274 is a Sony CMOS image sensor that has 1/2.5 image size.
It supports up to 3840x2160 (4K) 60fps, 1080p 120fps. The interface
is 4-lane MIPI CSI-2 running at 1.44Gbps each.
This driver has been tested on Xilinx ZCU102 platform with a Leopard
LI-IMX274MIPI-FMC camera board.
Support for the following features:
-Resolutions: 3840x2160, 1920x1080, 1280x720
-Frame rate: 3840x2160 : 5 – 60fps
1920x1080 : 5 – 120fps
1280x720 : 5 – 120fps
-Exposure time: 16 – (frame interval) micro-seconds
-Gain: 1x - 180x
-VFLIP: enable/disabledrivers/media/i2c/imx274.c
-Test pattern: 12 test patterns
Signed-off-by: Leon Luo <leonl@leopardimaging.com>
Tested-by: Sören Brinkmann <soren.brinkmann@xilinx.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Provide support for the ADV7481 and ADV7482.
The driver is modelled with 4 subdevices to allow simultaneous streaming
from the AFE (Analog front end) and HDMI inputs though two CSI TX
entities.
The HDMI entity is linked to the TXA CSI bus, whilst the AFE is linked
to the TXB CSI bus.
The driver is based on a prototype by Koji Matsuoka in the Renesas BSP,
and an earlier rework by Niklas Söderlund.
Signed-off-by: Kieran Bingham <kieran.bingham+renesas@ideasonboard.com>
Provides single source pad with up to 2592x1944 pixels at 10-bit raw
bayer format over MIPI CSI2 two lanes at 840Mbps/lane.
The driver supports following features:
- up to 30fps at 5M pixels
- manual exposure
- digital/analog gain
- V-blank/H-blank
- test pattern
- media controller
- runtime pm
[mchehab@s-opensource.com: fix a trivial merge conflict at Makefile]
Signed-off-by: Chiranjeevi Rapolu <chiranjeevi.rapolu@intel.com>
Remove the soc_camera dependencies and move the diver to i2c
Lost features, fortunately not used or not critical on test platform:
- soc_camera power on/off callback - replaced with clock enable/disable
only, no support for platform provided regulators nor power callback,
- soc_camera sense request - replaced with arbitrarily selected default
master clock rate and pixel clock limit, no support for platform
requested values,
- soc_camera board flags - no support for platform requested mbus config
tweaks.
Tested on Amstrad Delta with now out of tree but still locally
maintained omap1_camera host driver.
Signed-off-by: Janusz Krzysztofik <jmkrzyszt@gmail.com>
DW9714 is a 10 bit DAC, designed for linear
[Sakari Ailus: Add MAINTAINERS entry.]
Signed-off-by: Rajmohan Mani <rajmohan.mani@intel.com>
This patch adds driver for Omnivision's ov13858
sensor, the driver supports following features:
- manual exposure/gain(analog and digital) control support
- two link frequencies
- VBLANK/HBLANK support
- test pattern support
- media controller support
- runtime pm support
+ 4224x3136 at 30FPS
+ 2112x1568 at 30FPS(default) and 60FPS
+ 2112x1188 at 30FPS(default) and 60FPS
+ 1056x784 at 30FPS(default) and 60FPS
[Sakari Ailus: use V4L2_CID_DIGITAL_GAIN instead, add MAINTAINERS entry.]
Signed-off-by: Hyungwoo Yang <hyungwoo.yang@intel.com>
This driver is based on ov5640_mipi.c from Freescale imx_3.10.17_1.0.0_beta
branch, modified heavily to bring forward to latest interfaces and code
cleanup.
Signed-off-by: Steve Longerbeam <steve_longerbeam@mentor.com>
This patch adds driver support for the MAX2175 chip. This is Maxim
Integrated's RF to Bits tuner front end chip designed for software-defined
radio solutions. This driver exposes the tuner as a sub-device instance
with standard and custom controls to configure the device.
Signed-off-by: Ramesh Shanmugasundaram <ramesh.shanmugasundaram@bp.renesas.com>
The OV5647 sensor from Omnivision supports up to 2592x1944 @ 15 fps, RAW 8
and RAW 10 output formats, and MIPI CSI-2 interface.
The driver adds support for 640x480 RAW 8.
Signed-off-by: Ramiro Oliveira <roliveir@synopsys.com>
Reviewed-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
The ov5645 sensor from Omnivision supports up to 2592x1944
and CSI2 interface.
The driver adds support for the following modes:
- 1280x960
- 1920x1080
- 2592x1944
Output format is packed 8bit UYVY.
Convert ov2640 to a standard subdev driver. The soc-camera driver no longer
uses this driver, so it can safely be converted.
Acked-by: Hugues Fruchet <hugues.fruchet@st.com>
Add driver for et8ek8 sensor, found in Nokia N900 main camera. Can be
used for taking photos in 2.5MP resolution with fcam-dev.
Signed-off-by: Ivaylo Dimitrov <ivo.g.dimitrov.75@gmail.com>
Signed-off-by: Pavel Machek <pavel@ucw.cz>
As the mt9m111 is now working as a standalone v4l2 subdevice sensor,
move it out of soc_camera directory and sever its dependency on
soc_camera.
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
This adds support for AD5820 autofocus coil, found for example in
Nokia N900 smartphone.
Acked-by: Pali Rohár <pali.rohar@gmail.com>
Add simple support for this 8 channel volume control driver.
Currently all it does is to unmute all 8 channels.
Based upon Devin's initial patch made for an older kernel which I
cleaned up and rebased. Thanks to Kernel Labs for that work.
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
The driver is tested on our hardware and all the implemented features
works as expected.
Missing features:
- CEC support
- HDCP repeater support
- IR support
Signed-off-by: Mats Randgaard <matrandg@cisco.com>
[hans.verkuil@cisco.com: updated copyright year to 2015]
[hans.verkuil@cisco.com: update confusing confctl_mutex comment]
this patch adds support for omnivision's ov2659
1: Asynchronous probing
2: DT support
3: Media controller support
Signed-off-by: Benoit Parrot <bparrot@ti.com>
Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
These drivers haven't been tested in a long, long time. The hardware is
ancient and hopelessly obsolete. These drivers also need to be converted
to newer media frameworks but due to the lack of hardware that's going
to be impossible.
So these drivers are a prime candidate for removal. If someone is
interested in working on these drivers to prevent their removal, then
please contact the linux-media mailinglist.
This patch adds subdev driver for Samsung S5K6A3 raw image sensor.
As it is intended at the moment to be used only with the Exynos
FIMC-IS (camera ISP) subsystem it is pretty minimal subdev driver.
It doesn't do any I2C communication since the sensor is controlled
by the ISP and its own firmware.
This driver, if needed, can be updated in future into a regular
subdev driver where the main CPU communicates with the sensor
directly.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
This patch adds the driver for the LM3646, dual LED Flash driver.
The LM3646 has two 1.5A sync. boost converter with dual white current source.
It is controlled via an I2C compatible interface.
Each flash brightness, torch brightness and enable/disable can be controlled.
Under voltage, input voltage monitor and thermal threshhold Faults are added.
Please refer the datasheet http://www.ti.com/lit/ds/snvs962/snvs962.pdf
Signed-off-by: Daniel Jeong <gshark.jeong@gmail.com>
Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi>
This driver is independent from saa7134, so there is no reason why this
shouldn't be in media/i2c like all other i2c media drivers.
Driver for Samsung S5K5BAF UXGA 1/5" 2M CMOS Image Sensor with
embedded SoC ISP. The device is exposed as two V4L2 subdevices:
- S5K5BAF-CIS - the image sensor matrix, fixed 1600x1200 format,
no controls.
- S5K5BAF-ISP - the Image Signal Processor, formats up to 1600x1200,
pre/post ISP cropping, downscaling via selection API, controls.
[m.chehab@samsung.com: Whitespace cleanups]
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
The omap24xx driver and the tcm825x sensor driver are the only two
remaining drivers to still use the old deprecated v4l2-int-device API.
Nobody maintains these drivers anymore. But unfortunately the v4l2-int-device
API is used by out-of-tree drivers (MXC platform). This is a very bad situation
since as long as this deprecated API stays in the kernel there is no reason for
those out-of-tree drivers to convert.
This patch moves v4l2-int-device and the two drivers that depend on it to
staging in preparation for their removal.
If someone would be interested in getting these drivers to work, then start with
this since it's not very far from the state where they used to work:
<URL:http://vihersipuli.retiisi.org.uk/cgi-bin/gitweb.cgi?p=~sailus/linux-omap/.git;a=summary>
The branch is n800-cam. Porting to up-to-date APIs can then be done. David
might have done some work in that area, so check with him first.
Cc: Sakari Ailus <sakari.ailus@iki.fi>
Cc: David Cohen <dacohen@gmail.com>
Adds the driver for the LM3560, dual LED Flash The LM3560 has two 1A
constant current driver for high current white LEDs.
It is controlled via an I2C compatible interface(up to 400kHz).
controlled independantly, but flash timeout and operation mode are shared.
This is an Analog Devices HDMI transmitter.
This is a Analog Devices Component/Graphics/SD Digitizer with 2:1
Multiplexed HDMI Receiver.
The full datasheets are available from TI website:-
http://www.ti.com/product/ths8200
Note: This patch adds support only for progressive format
as of now.
Signed-off-by: Mats Randgaard <mats.randgaard@cisco.com>
Signed-off-by: Martin Bugge <martin.bugge@cisco.com>
Add OKI Semiconductor ML86V7667 video decoder driver.
[Sergei: added v4l2_device_unregister_subdev() call to the error cleanup path
of ml86v7667_probe(), renamed ml86v7667_try_mbus_fmt() to ml86v7667_mbus_fmt(),
killed v4l2_chip_match_i2c_client() checks in the [gs]_register() methods, fixed
the prototype of the s_register() method, did some cleanup.]
Signed-off-by: Vladimir Barinov <vladimir.barinov@cogentembedded.com>
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
