[ Upstream commit 56cb61f70e547e1b0cdfe6ff5a1f1ce6242e6d96 ]
Some cx88 video cards may have transport stream status interrupts set
to 1 from cold start, causing errors like this:
cx88xx: cx88_print_irqbits: core:irq mpeg [0x100000] ts_err?*
cx8802: cx8802_mpeg_irq: mpeg:general errors: 0x00100000
According to CX2388x datasheet, the interrupt status register should be
cleared before enabling IRQs to stream video.
Fix it by clearing the Transport Stream Interrupt Status register.
Signed-off-by: Daniel González Cabanelas <dgcbueu@gmail.com>
[ Upstream commit 25e94139218c0293b4375233c14f2256d7dcfaa8 ]
The VIDIOC_G_FBUF and related overlay ioctls no longer worked (-ENOTTY was
returned).
The root cause was the introduction of the caps field in ivtv-driver.h.
While loading the ivtvfb module would update the video_device device_caps
field with V4L2_CAP_VIDEO_OUTPUT_OVERLAY it would not update that caps
field, and that's what the overlay ioctls would look at.
It's a bad idea to keep information in two places, so drop the caps field
and only use vdev.device_caps.
Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl>
Reported-by: Martin Dauskardt <martin.dauskardt@gmx.de>
Fixes: 2161536516ed (media: media/pci: set device_caps in struct video_device)
[ Upstream commit ef058cc8b7193d15a771272359c7454839ae74ee ]
Commit 2161536516ed ("media: media/pci: set device_caps in struct video_device")
introduced a regression: V4L2_CAP_TUNER is always present in device_caps,
even when the device has no tuner.
This causes a warning:
WARNING: CPU: 0 PID: 249 at drivers/media/v4l2-core/v4l2-ioctl.c:1102 v4l_querycap+0xa0/0xb0 [videodev]
Fixes: 2161536516ed ("media: media/pci: set device_caps in struct video_device")
Signed-off-by: Ondrej Zary <linux@zary.sk>
Signed-off-by: Mauro Carvalho Chehab <mchehab@kernel.org>
[ Upstream commit 3af86b046933ba513d08399dba0d4d8b50d607d0 ]
In hexium_attach(dev, info), saa7146_vv_init() is called to allocate
a new memory for dev->vv_data. saa7146_vv_release() will be called on
failure of saa7146_register_device(). There is a dereference of
dev->vv_data in saa7146_vv_release(), which could lead to a NULL
pointer dereference on failure of saa7146_vv_init().
Fix this bug by adding a check of saa7146_vv_init().
This bug was found by a static analyzer. The analysis employs
differential checking to identify inconsistent security operations
(e.g., checks or kfrees) between two code paths and confirms that the
inconsistent operations are not recovered in the current function or
the callers, so they constitute bugs.
Note that, as a bug found by static analysis, it can be a false
positive or hard to trigger. Multiple researchers have cross-reviewed
the bug.
Builds with CONFIG_VIDEO_HEXIUM_GEMINI=m show no new warnings,
and our static analyzer no longer warns about this code.
Link: https://lore.kernel.org/linux-media/20211203154030.111210-1-zhou1615@umn.edu
Signed-off-by: Zhou Qingyang <zhou1615@umn.edu>
Signed-off-by: Mauro Carvalho Chehab <mchehab+huawei@kernel.org>
[ Upstream commit 348df8035301dd212e3cc2860efe4c86cb0d3303 ]
a new memory for dev->vv_data. In hexium_detach(), saa7146_vv_release()
will be called and there is a dereference of dev->vv_data in
saa7146_vv_release(), which could lead to a NULL pointer dereference
on failure of saa7146_vv_init() according to the following logic.
Both hexium_attach() and hexium_detach() are callback functions of
the variable 'extension', so there exists a possible call chain directly
from hexium_attach() to hexium_detach():
hexium_attach(dev, info) -- fail to alloc memory to dev->vv_data
| in saa7146_vv_init().
hexium_detach() -- a dereference of dev->vv_data in saa7146_vv_release()
the bug.
Builds with CONFIG_VIDEO_HEXIUM_ORION=m show no new warnings,
[ Upstream commit b13203032e679674c7c518f52a7ec0801ca3a829 ]
A out-of-bounds bug can be triggered by an interrupt, the reason for
this bug is the lack of checking of register values.
In flexcop_pci_isr, the driver reads value from a register and uses it as
a dma address. Finally, this address will be passed to the count parameter
of find_next_packet. If this value is larger than the size of dma, the
index of buffer will be out-of-bounds.
Fix this by adding a check after reading the value of the register.
The following KASAN report reveals it:
BUG: KASAN: slab-out-of-bounds in find_next_packet
drivers/media/dvb-core/dvb_demux.c:528 [inline]
BUG: KASAN: slab-out-of-bounds in _dvb_dmx_swfilter
drivers/media/dvb-core/dvb_demux.c:572 [inline]
BUG: KASAN: slab-out-of-bounds in dvb_dmx_swfilter+0x3fa/0x420
drivers/media/dvb-core/dvb_demux.c:603
Read of size 1 at addr ffff8880608c00a0 by task swapper/2/0
CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.19.177-gdba4159c14ef #25
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS
rel-1.12.0-59-gc9ba5276e321-prebuilt.qemu.org 04/01/2014
Call Trace:
<IRQ>
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0xec/0x156 lib/dump_stack.c:118
print_address_description+0x78/0x290 mm/kasan/report.c:256
kasan_report_error mm/kasan/report.c:354 [inline]
kasan_report+0x25b/0x380 mm/kasan/report.c:412
__asan_report_load1_noabort+0x19/0x20 mm/kasan/report.c:430
find_next_packet drivers/media/dvb-core/dvb_demux.c:528 [inline]
_dvb_dmx_swfilter drivers/media/dvb-core/dvb_demux.c:572 [inline]
dvb_dmx_swfilter+0x3fa/0x420 drivers/media/dvb-core/dvb_demux.c:603
flexcop_pass_dmx_data+0x2e/0x40 drivers/media/common/b2c2/flexcop.c:167
flexcop_pci_isr+0x3d1/0x5d0 drivers/media/pci/b2c2/flexcop-pci.c:212
__handle_irq_event_percpu+0xfb/0x770 kernel/irq/handle.c:149
handle_irq_event_percpu+0x79/0x150 kernel/irq/handle.c:189
handle_irq_event+0xac/0x140 kernel/irq/handle.c:206
handle_fasteoi_irq+0x232/0x5c0 kernel/irq/chip.c:725
generic_handle_irq_desc include/linux/irqdesc.h:155 [inline]
handle_irq+0x230/0x3a0 arch/x86/kernel/irq_64.c:87
do_IRQ+0xa7/0x1e0 arch/x86/kernel/irq.c:247
common_interrupt+0xf/0xf arch/x86/entry/entry_64.S:670
</IRQ>
RIP: 0010:native_safe_halt+0x28/0x30 arch/x86/include/asm/irqflags.h:61
Code: 00 00 55 be 04 00 00 00 48 c7 c7 00 62 2f 8c 48 89 e5 e8 fb 31
e8 f8 8b 05 75 4f 8e 03 85 c0 7e 07 0f 00 2d 8a 61 66 00 fb f4 <5d> c3
90 90 90 90 90 90 0f 1f 44 00 00 55 48 89 e5 41 57 41 56 41
RSP: 0018:ffff88806b71fcc8 EFLAGS: 00000246 ORIG_RAX: ffffffffffffffde
RAX: 0000000000000000 RBX: ffffffff8bde44c8 RCX: ffffffff88a11285
RDX: 0000000000000000 RSI: 0000000000000004 RDI: ffffffff8c2f6200
RBP: ffff88806b71fcc8 R08: fffffbfff185ec40 R09: fffffbfff185ec40
R10: 0000000000000001 R11: fffffbfff185ec40 R12: 0000000000000002
R13: ffffffff8be9d6e0 R14: 0000000000000000 R15: 0000000000000000
arch_safe_halt arch/x86/include/asm/paravirt.h:94 [inline]
default_idle+0x6f/0x360 arch/x86/kernel/process.c:557
arch_cpu_idle+0xf/0x20 arch/x86/kernel/process.c:548
default_idle_call+0x3b/0x60 kernel/sched/idle.c:93
cpuidle_idle_call kernel/sched/idle.c:153 [inline]
do_idle+0x2ab/0x3c0 kernel/sched/idle.c:263
cpu_startup_entry+0xcb/0xe0 kernel/sched/idle.c:369
start_secondary+0x3b8/0x4e0 arch/x86/kernel/smpboot.c:271
secondary_startup_64+0xa4/0xb0 arch/x86/kernel/head_64.S:243
Allocated by task 1:
save_stack+0x43/0xd0 mm/kasan/kasan.c:448
set_track mm/kasan/kasan.c:460 [inline]
kasan_kmalloc+0xad/0xe0 mm/kasan/kasan.c:553
kasan_slab_alloc+0x11/0x20 mm/kasan/kasan.c:490
slab_post_alloc_hook mm/slab.h:445 [inline]
slab_alloc_node mm/slub.c:2741 [inline]
slab_alloc mm/slub.c:2749 [inline]
kmem_cache_alloc+0xeb/0x280 mm/slub.c:2754
kmem_cache_zalloc include/linux/slab.h:699 [inline]
__kernfs_new_node+0xe2/0x6f0 fs/kernfs/dir.c:633
kernfs_new_node+0x9a/0x120 fs/kernfs/dir.c:693
__kernfs_create_file+0x5f/0x340 fs/kernfs/file.c:992
sysfs_add_file_mode_ns+0x22a/0x4e0 fs/sysfs/file.c:306
create_files fs/sysfs/group.c:63 [inline]
internal_create_group+0x34e/0xc30 fs/sysfs/group.c:147
sysfs_create_group fs/sysfs/group.c:173 [inline]
sysfs_create_groups+0x9c/0x140 fs/sysfs/group.c:200
driver_add_groups+0x3e/0x50 drivers/base/driver.c:129
bus_add_driver+0x3a5/0x790 drivers/base/bus.c:684
driver_register+0x1cd/0x410 drivers/base/driver.c:170
__pci_register_driver+0x197/0x200 drivers/pci/pci-driver.c:1411
cx88_audio_pci_driver_init+0x23/0x25 drivers/media/pci/cx88/cx88-alsa.c:
1017
do_one_initcall+0xe0/0x610 init/main.c:884
do_initcall_level init/main.c:952 [inline]
do_initcalls init/main.c:960 [inline]
do_basic_setup init/main.c:978 [inline]
kernel_init_freeable+0x4d0/0x592 init/main.c:1145
kernel_init+0x18/0x190 init/main.c:1062
ret_from_fork+0x24/0x30 arch/x86/entry/entry_64.S:415
Freed by task 0:
(stack is not available)
The buggy address belongs to the object at ffff8880608c0000
which belongs to the cache kernfs_node_cache of size 160
The buggy address is located 0 bytes to the right of
160-byte region [ffff8880608c0000, ffff8880608c00a0)
The buggy address belongs to the page:
page:ffffea0001823000 count:1 mapcount:0 mapping:ffff88806bed1e00
index:0x0 compound_mapcount: 0
flags: 0x100000000008100(slab|head)
raw: 0100000000008100 dead000000000100 dead000000000200 ffff88806bed1e00
raw: 0000000000000000 0000000000240024 00000001ffffffff 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8880608bff80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ffff8880608c0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
>ffff8880608c0080: 00 00 00 00 fc fc fc fc fc fc fc fc 00 00 00 00
ffff8880608c0100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ffff8880608c0180: fc fc fc fc fc fc fc fc 00 00 00 00 00 00 00 00
Link: https://lore.kernel.org/linux-media/1620723603-30912-1-git-send-email-zheyuma97@gmail.com
Reported-by: Zheyu Ma <zheyuma97@gmail.com>
Signed-off-by: Zheyu Ma <zheyuma97@gmail.com>
[ Upstream commit 0407c49ebe330333478440157c640fffd986f41b ]
In mxb_attach(dev, info), saa7146_vv_init() is called to allocate a
failure of mxb_probe(dev). There is a dereference of dev->vv_data
in saa7146_vv_release(), which could lead to a NULL pointer dereference
the bug.
Builds with CONFIG_VIDEO_MXB=m show no new warnings,
Fixes: 03b1930efd3c ("V4L/DVB: saa7146: fix regression of the av7110/budget-av driver")
[ Upstream commit 7266dda2f1dfe151b12ef0c14eb4d4e622fb211c ]
Currently a call to snd_card_new that fails will set card with a NULL
pointer, this causes a null pointer dereference on the error cleanup
path when card it passed to snd_card_free. Fix this by adding a new
error exit path that does not call snd_card_free and exiting via this
new path.
Addresses-Coverity: ("Explicit null dereference")
Fixes: 9e44d63246a9 ("[media] cx23885: Add ALSA support")
[ Upstream commit dbb4cfea6efe979ed153bd59a6a527a90d3d0ab3 ]
The interrupt handling should be related to the firmware version. If
the driver matches an old firmware, then the driver should not handle
interrupt such as i2c or dma, otherwise it will cause some errors.
This log reveals it:
[ 27.708641] INFO: trying to register non-static key.
[ 27.710851] The code is fine but needs lockdep annotation, or maybe
[ 27.712010] you didn't initialize this object before use?
[ 27.712396] turning off the locking correctness validator.
[ 27.712787] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 5.12.4-g70e7f0549188-dirty #169
[ 27.713349] Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS rel-1.12.0-59-gc9ba5276e321-prebuilt.qemu.org 04/01/2014
[ 27.714149] Call Trace:
[ 27.714329] <IRQ>
[ 27.714480] dump_stack+0xba/0xf5
[ 27.714737] register_lock_class+0x873/0x8f0
[ 27.715052] ? __lock_acquire+0x323/0x1930
[ 27.715353] __lock_acquire+0x75/0x1930
[ 27.715636] lock_acquire+0x1dd/0x3e0
[ 27.715905] ? netup_i2c_interrupt+0x19/0x310
[ 27.716226] _raw_spin_lock_irqsave+0x4b/0x60
[ 27.716544] ? netup_i2c_interrupt+0x19/0x310
[ 27.716863] netup_i2c_interrupt+0x19/0x310
[ 27.717178] netup_unidvb_isr+0xd3/0x160
[ 27.717467] __handle_irq_event_percpu+0x53/0x3e0
[ 27.717808] handle_irq_event_percpu+0x35/0x90
[ 27.718129] handle_irq_event+0x39/0x60
[ 27.718409] handle_fasteoi_irq+0xc2/0x1d0
[ 27.718707] __common_interrupt+0x7f/0x150
[ 27.719008] common_interrupt+0xb4/0xd0
[ 27.719289] </IRQ>
[ 27.719446] asm_common_interrupt+0x1e/0x40
[ 27.719747] RIP: 0010:native_safe_halt+0x17/0x20
[ 27.720084] Code: 07 0f 00 2d 8b ee 4c 00 f4 5d c3 0f 1f 84 00 00 00 00 00 8b 05 72 95 17 02 55 48 89 e5 85 c0 7e 07 0f 00 2d 6b ee 4c 00 fb f4 <5d> c3 cc cc cc cc cc cc cc 55 48 89 e5 e8 67 53 ff ff 8b 0d 29 f6
[ 27.721386] RSP: 0018:ffffc9000008fe90 EFLAGS: 00000246
[ 27.721758] RAX: 0000000000000000 RBX: 0000000000000002 RCX: 0000000000000000
[ 27.722262] RDX: 0000000000000000 RSI: ffffffff85f7c054 RDI: ffffffff85ded4e6
[ 27.722770] RBP: ffffc9000008fe90 R08: 0000000000000001 R09: 0000000000000001
[ 27.723277] R10: 0000000000000000 R11: 0000000000000001 R12: ffffffff86a75408
[ 27.723781] R13: 0000000000000000 R14: 0000000000000000 R15: ffff888100260000
[ 27.724289] default_idle+0x9/0x10
[ 27.724537] arch_cpu_idle+0xa/0x10
[ 27.724791] default_idle_call+0x6e/0x250
[ 27.725082] do_idle+0x1f0/0x2d0
[ 27.725326] cpu_startup_entry+0x18/0x20
[ 27.725613] start_secondary+0x11f/0x160
[ 27.725902] secondary_startup_64_no_verify+0xb0/0xbb
[ 27.726272] BUG: kernel NULL pointer dereference, address: 0000000000000002
[ 27.726768] #PF: supervisor read access in kernel mode
[ 27.727138] #PF: error_code(0x0000) - not-present page
[ 27.727507] PGD 8000000118688067 P4D 8000000118688067 PUD 10feab067 PMD 0
[ 27.727999] Oops: 0000 [#1] PREEMPT SMP PTI
[ 27.728302] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 5.12.4-g70e7f0549188-dirty #169
[ 27.728861] Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS rel-1.12.0-59-gc9ba5276e321-prebuilt.qemu.org 04/01/2014
[ 27.729660] RIP: 0010:netup_i2c_interrupt+0x23/0x310
[ 27.730019] Code: 0f 1f 80 00 00 00 00 55 48 89 e5 41 55 41 54 53 48 89 fb e8 af 6e 95 fd 48 89 df e8 e7 9f 1c 01 49 89 c5 48 8b 83 48 08 00 00 <66> 44 8b 60 02 44 89 e0 48 8b 93 48 08 00 00 83 e0 f8 66 89 42 02
[ 27.731339] RSP: 0018:ffffc90000118e90 EFLAGS: 00010046
[ 27.731716] RAX: 0000000000000000 RBX: ffff88810803c4d8 RCX: 0000000000000000
[ 27.732223] RDX: 0000000000000001 RSI: ffffffff85d37b94 RDI: ffff88810803c4d8
[ 27.732727] RBP: ffffc90000118ea8 R08: 0000000000000000 R09: 0000000000000001
[ 27.733239] R10: ffff88810803c4f0 R11: 61646e6f63657320 R12: 0000000000000000
[ 27.733745] R13: 0000000000000046 R14: ffff888101041000 R15: ffff8881081b2400
[ 27.734251] FS: 0000000000000000(0000) GS:ffff88817bc80000(0000) knlGS:0000000000000000
[ 27.734821] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 27.735228] CR2: 0000000000000002 CR3: 0000000108194000 CR4: 00000000000006e0
[ 27.735735] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 27.736241] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 27.736744] Call Trace:
[ 27.736924] <IRQ>
[ 27.737074] netup_unidvb_isr+0xd3/0x160
[ 27.737363] __handle_irq_event_percpu+0x53/0x3e0
[ 27.737706] handle_irq_event_percpu+0x35/0x90
[ 27.738028] handle_irq_event+0x39/0x60
[ 27.738306] handle_fasteoi_irq+0xc2/0x1d0
[ 27.738602] __common_interrupt+0x7f/0x150
[ 27.738899] common_interrupt+0xb4/0xd0
[ 27.739176] </IRQ>
[ 27.739331] asm_common_interrupt+0x1e/0x40
[ 27.739633] RIP: 0010:native_safe_halt+0x17/0x20
[ 27.739967] Code: 07 0f 00 2d 8b ee 4c 00 f4 5d c3 0f 1f 84 00 00 00 00 00 8b 05 72 95 17 02 55 48 89 e5 85 c0 7e 07 0f 00 2d 6b ee 4c 00 fb f4 <5d> c3 cc cc cc cc cc cc cc 55 48 89 e5 e8 67 53 ff ff 8b 0d 29 f6
[ 27.741275] RSP: 0018:ffffc9000008fe90 EFLAGS: 00000246
[ 27.741647] RAX: 0000000000000000 RBX: 0000000000000002 RCX: 0000000000000000
[ 27.742148] RDX: 0000000000000000 RSI: ffffffff85f7c054 RDI: ffffffff85ded4e6
[ 27.742652] RBP: ffffc9000008fe90 R08: 0000000000000001 R09: 0000000000000001
[ 27.743154] R10: 0000000000000000 R11: 0000000000000001 R12: ffffffff86a75408
[ 27.743652] R13: 0000000000000000 R14: 0000000000000000 R15: ffff888100260000
[ 27.744157] default_idle+0x9/0x10
[ 27.744405] arch_cpu_idle+0xa/0x10
[ 27.744658] default_idle_call+0x6e/0x250
[ 27.744948] do_idle+0x1f0/0x2d0
[ 27.745190] cpu_startup_entry+0x18/0x20
[ 27.745475] start_secondary+0x11f/0x160
[ 27.745761] secondary_startup_64_no_verify+0xb0/0xbb
[ 27.746123] Modules linked in:
[ 27.746348] Dumping ftrace buffer:
[ 27.746596] (ftrace buffer empty)
[ 27.746852] CR2: 0000000000000002
[ 27.747094] ---[ end trace ebafd46f83ab946d ]---
[ 27.747424] RIP: 0010:netup_i2c_interrupt+0x23/0x310
[ 27.747778] Code: 0f 1f 80 00 00 00 00 55 48 89 e5 41 55 41 54 53 48 89 fb e8 af 6e 95 fd 48 89 df e8 e7 9f 1c 01 49 89 c5 48 8b 83 48 08 00 00 <66> 44 8b 60 02 44 89 e0 48 8b 93 48 08 00 00 83 e0 f8 66 89 42 02
[ 27.749082] RSP: 0018:ffffc90000118e90 EFLAGS: 00010046
[ 27.749461] RAX: 0000000000000000 RBX: ffff88810803c4d8 RCX: 0000000000000000
[ 27.749966] RDX: 0000000000000001 RSI: ffffffff85d37b94 RDI: ffff88810803c4d8
[ 27.750471] RBP: ffffc90000118ea8 R08: 0000000000000000 R09: 0000000000000001
[ 27.750976] R10: ffff88810803c4f0 R11: 61646e6f63657320 R12: 0000000000000000
[ 27.751480] R13: 0000000000000046 R14: ffff888101041000 R15: ffff8881081b2400
[ 27.751986] FS: 0000000000000000(0000) GS:ffff88817bc80000(0000) knlGS:0000000000000000
[ 27.752560] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 27.752970] CR2: 0000000000000002 CR3: 0000000108194000 CR4: 00000000000006e0
[ 27.753481] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 27.753984] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 27.754487] Kernel panic - not syncing: Fatal exception in interrupt
[ 27.755033] Dumping ftrace buffer:
[ 27.755279] (ftrace buffer empty)
[ 27.755534] Kernel Offset: disabled
[ 27.755785] Rebooting in 1 seconds..
Signed-off-by: Sean Young <sean@mess.org>
commit 8d4abca95ecc82fc8c41912fa0085281f19cc29f upstream.
Fix an 11-year old bug in ngene_command_config_free_buf() while
addressing the following warnings caught with -Warray-bounds:
arch/alpha/include/asm/string.h:22:16: warning: '__builtin_memcpy' offset [12, 16] from the object at 'com' is out of the bounds of referenced subobject 'config' with type 'unsigned char' at offset 10 [-Warray-bounds]
arch/x86/include/asm/string_32.h:182:25: warning: '__builtin_memcpy' offset [12, 16] from the object at 'com' is out of the bounds of referenced subobject 'config' with type 'unsigned char' at offset 10 [-Warray-bounds]
The problem is that the original code is trying to copy 6 bytes of
data into a one-byte size member _config_ of the wrong structue
FW_CONFIGURE_BUFFERS, in a single call to memcpy(). This causes a
legitimate compiler warning because memcpy() overruns the length
of &com.cmd.ConfigureBuffers.config. It seems that the right
structure is FW_CONFIGURE_FREE_BUFFERS, instead, because it contains
6 more members apart from the header _hdr_. Also, the name of
the function ngene_command_config_free_buf() suggests that the actual
intention is to ConfigureFreeBuffers, instead of ConfigureBuffers
(which takes place in the function ngene_command_config_buf(), above).
Fix this by enclosing those 6 members of struct FW_CONFIGURE_FREE_BUFFERS
into new struct config, and use &com.cmd.ConfigureFreeBuffers.config as
the destination address, instead of &com.cmd.ConfigureBuffers.config,
when calling memcpy().
This also helps with the ongoing efforts to globally enable
-Warray-bounds and get us closer to being able to tighten the
FORTIFY_SOURCE routines on memcpy().
Link: https://github.com/KSPP/linux/issues/109
Fixes: dae52d009fc9 ("V4L/DVB: ngene: Initial check-in")
Cc: stable@vger.kernel.org
Reported-by: kernel test robot <lkp@intel.com>
Signed-off-by: Gustavo A. R. Silva <gustavoars@kernel.org>
Link: https://lore.kernel.org/linux-hardening/20210420001631.GA45456@embeddedor/
commit 0a7790be182d32b9b332a37cb4206e24fe94b728 upstream.
The saa6588_ioctl() function expects to get called from other kernel
functions with a 'saa6588_command' pointer, but I found nothing stops it
from getting called from user space instead, which seems rather dangerous.
The same thing happens in the davinci vpbe driver with its VENC_GET_FLD
command.
As a quick fix, add a separate .command() callback pointer for this
driver and change the two callers over to that. This change can easily
get backported to stable kernels if necessary, but since there are only
two drivers, we may want to eventually replace this with a set of more
specialized callbacks in the long run.
Fixes: c3fda7f835b0 ("V4L/DVB (10537): saa6588: convert to v4l2_subdev.")
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
[ Upstream commit 1a4520090681853e6b850cbe54b27247a013e0e5 ]
In 'bt878_irq', the driver calls 'tasklet_schedule', but this tasklet is
set in 'dvb_bt8xx_load_card' of another driver 'dvb-bt8xx'.
However, this two drivers are separate. The user may not load the
'dvb-bt8xx' driver when loading the 'bt8xx' driver, that is, the tasklet
has not been initialized when 'tasklet_schedule' is called, so it is
necessary to check whether the tasklet is initialized in 'bt878_probe'.
Fix this by adding a check at the end of bt878_probe.
The KASAN's report reveals it:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000000
PGD 800000006aab2067 P4D 800000006aab2067 PUD 6b2ea067 PMD 0
Oops: 0010 [#1] PREEMPT SMP KASAN PTI
CPU: 2 PID: 8724 Comm: syz-executor.0 Not tainted 4.19.177-
gdba4159c14ef-dirty #40
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.12.0-59-
RIP: 0010: (null)
Code: Bad RIP value.
RSP: 0018:ffff88806c287ea0 EFLAGS: 00010246
RAX: fffffbfff1b01774 RBX: dffffc0000000000 RCX: 0000000000000000
RDX: 0000000000000000 RSI: 1ffffffff1b01775 RDI: 0000000000000000
RBP: ffff88806c287f00 R08: fffffbfff1b01774 R09: fffffbfff1b01774
R10: 0000000000000001 R11: fffffbfff1b01773 R12: 0000000000000000
R13: ffff88806c29f530 R14: ffffffff8d80bb88 R15: ffffffff8d80bb90
FS: 00007f6b550e6700(0000) GS:ffff88806c280000(0000) knlGS:
0000000000000000
CR2: ffffffffffffffd6 CR3: 000000005ec98000 CR4: 00000000000006e0
Call Trace:
<IRQ>
tasklet_action_common.isra.17+0x141/0x420 kernel/softirq.c:522
tasklet_action+0x50/0x70 kernel/softirq.c:540
__do_softirq+0x224/0x92c kernel/softirq.c:292
invoke_softirq kernel/softirq.c:372 [inline]
irq_exit+0x15a/0x180 kernel/softirq.c:412
exiting_irq arch/x86/include/asm/apic.h:535 [inline]
do_IRQ+0x123/0x1e0 arch/x86/kernel/irq.c:260
</IRQ>
RIP: 0010:__do_sys_interrupt kernel/sys.c:2593 [inline]
RIP: 0010:__se_sys_interrupt kernel/sys.c:2584 [inline]
RIP: 0010:__x64_sys_interrupt+0x5b/0x80 kernel/sys.c:2584
Code: ba 00 04 00 00 48 c7 c7 c0 99 31 8c e8 ae 76 5e 01 48 85 c0 75 21 e8
14 ae 24 00 48 c7 c3 c0 99 31 8c b8 0c 00 00 00 0f 01 c1 <31> db e8 fe ad
24 00 48 89 d8 5b 5d c3 48 c7 c3 ea ff ff ff eb ec
RSP: 0018:ffff888054167f10 EFLAGS: 00000212 ORIG_RAX: ffffffffffffffde
RAX: 000000000000000c RBX: ffffffff8c3199c0 RCX: ffffc90001ca6000
RDX: 000000000000001a RSI: ffffffff813478fc RDI: ffffffff8c319dc0
RBP: ffff888054167f18 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000080 R11: fffffbfff18633b7 R12: ffff888054167f58
R13: ffff88805f638000 R14: 0000000000000000 R15: 0000000000000000
do_syscall_64+0xb0/0x4e0 arch/x86/entry/common.c:293
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x4692a9
Code: f7 d8 64 89 02 b8 ff ff ff ff c3 66 0f 1f 44 00 00 48 89 f8 48 89 f7
48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff
ff 73 01 c3 48 c7 c1 bc ff ff ff f7 d8 64 89 01 48
RSP: 002b:00007f6b550e5c48 EFLAGS: 00000246 ORIG_RAX: 000000000000014f
RAX: ffffffffffffffda RBX: 000000000077bf60 RCX: 00000000004692a9
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000020000140
RBP: 00000000004cf7eb R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 000000000077bf60
R13: 0000000000000000 R14: 000000000077bf60 R15: 00007fff55a1dca0
Modules linked in:
CR2: 0000000000000000
---[ end trace 68e5849c3f77cbb6 ]---
RIP: 0010: (null)
0000000000000000
[ Upstream commit 3d37ef41bed0854805ab9af22c422267510e1344 ]
The cobalt_s_bit_sysctrl reads the old register value over PCI,
then changes a bit and sets writes the new value to the register.
This is used among other things for setting the HPD output pin.
But if the HPD is changed for multiple inputs at the same time,
then this causes a race condition where a stale value is read.
Serialize this function with a mutex.
[ Upstream commit c759b2970c561e3b56aa030deb13db104262adfe ]
Add a fix for the memory leak bugs that can occur when the
saa7164_encoder_register() function fails.
The function allocates memory without explicitly freeing
it when errors occur.
Add a better error handling that deallocate the unused buffers before the
function exits during a fail.
Signed-off-by: Daniel Niv <danielniv3@gmail.com>
[ Upstream commit 24df8b74c8b2fb42c49ffe8585562da0c96446ff ]
When STA2X11_VIP is enabled, and GPIOLIB is disabled,
Kbuild gives the following warning:
WARNING: unmet direct dependencies detected for VIDEO_ADV7180
Depends on [n]: MEDIA_SUPPORT [=y] && GPIOLIB [=n] && VIDEO_V4L2 [=y] && I2C [=y]
Selected by [y]:
- STA2X11_VIP [=y] && MEDIA_SUPPORT [=y] && MEDIA_PCI_SUPPORT [=y] && MEDIA_CAMERA_SUPPORT [=y] && PCI [=y] && VIDEO_V4L2 [=y] && VIRT_TO_BUS [=y] && I2C [=y] && (STA2X11 [=n] || COMPILE_TEST [=y]) && MEDIA_SUBDRV_AUTOSELECT [=y]
This is because STA2X11_VIP selects VIDEO_ADV7180
without selecting or depending on GPIOLIB,
despite VIDEO_ADV7180 depending on GPIOLIB.
Signed-off-by: Julian Braha <julianbraha@gmail.com>
[ Upstream commit dbf0b3a7b719eb3f72cb53c2ce7d34a012a9c261 ]
On AMD Family 15h (Models 30h-3fh), I/O Memory Management Unit
RiSC engine sometimes stalls, requiring a reset.
As result, MythTV and w-scan won't scan channels on the AMD Kaveri
APU with the Hauppauge QuadHD TV tuner card.
For the solution I added the Input/Output Memory Management Unit's PCI
Identity of 0x1423 to the broken_dev_id[] array, which is used by
a quirks logic meant to fix similar problems with other AMD
chipsets.
Signed-off-by: Daniel Lee Kruse <daniel.lee.kruse@protonmail.com>
commit 6532923237b427ed30cc7b4486f6f1ccdee3c647 upstream.
After the first IR message, interrupts are no longer received. In addition,
the code generates a timeout IR message of 10ms but sets the timeout value
to 100ms, so no timeout was ever generated.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=204317
Fixes: a49a7a4635de ("media: smipcie: add universal ir capability")
Tested-by: Laz Lev <lazlev@web.de>
Cc: stable@vger.kernel.org # v5.1+
commit 334de4b45892f7e67074e1b1b2ac36fd3e091118 upstream.
Loop was useless as it would always exit on the first iteration. Fix
it with right condition.
Signed-off-by: Pavel Machek (CIP) <pavel@denx.de>
Fixes: a86cf9b29e8b ("media: ipu3-cio2: Validate mbus format in setting subdev format")
Tested-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: stable@vger.kernel.org # v4.16 and up
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
[ Upstream commit b2de3643c5024fc4fd128ba7767c7fb8b714bea7 ]
This function looks like a realloc.
However, if 'risc->cpu != NULL', the memory will be freed, but never
reallocated with the bigger 'size'.
Explicitly set 'risc->cpu' to NULL, so that the reallocation is
correctly performed a few lines below.
[hverkuil: NULL != risc->cpu -> risc->cpu]
Fixes: 5ede94c70553 ("[media] cx25821: remove bogus btcx_risc dependency)
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
[ Upstream commit 15d0c52241ecb1c9d802506bff6f5c3f7872c0df ]
When vb2_queue_init() fails, dev->empress_dev
should be released just like other error handling
paths.
Fixes: 2ada815fc48bb ("[media] saa7134: convert to vb2")
Signed-off-by: Dinghao Liu <dinghao.liu@zju.edu.cn>
commit 219a8b9c04e54872f9a4d566633fb42f08bcbe2a upstream.
The ipu3-cio2 doesn't make use of the field and this is reflected in V4L2
buffers as well as the try format. Do this in active format, too.
Fixes: c2a6a07afe4a ("media: intel-ipu3: cio2: add new MIPI-CSI2 driver")
Reviewed-by: Bingbu Cao <bingbu.cao@intel.com>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
commit a86cf9b29e8b12811cf53c4970eefe0c1d290476 upstream.
Validate media bus code, width and height when setting the subdev format.
This effectively reworks how setting subdev format is implemented in the
driver.
commit 55a6c6b2be3d6670bf5772364d8208bd8dc17da4 upstream.
Pad format can be accessed from user space. Serialise access to it.
commit 8160e86702e0807bd36d40f82648f9f9820b9d5a upstream.
Return actual subdev format on ipu3-cio2 subdev pads. The earlier
implementation was based on an infinite recursion that exhausted the
stack.
Reported-by: Tsuchiya Yuto <kitakar@gmail.com>
commit 61e7f892b5ee1dd10ea8bff805f3c3fe6e535959 upstream.
If starting a video buffer queue fails, the buffers are returned to
videobuf2. Remove the reference to the buffer from the driver's queue as
well.
commit e297ddf296de35037fa97f4302782def196d350a upstream.
If the call to spi_register_master() fails on probe of the NetUP
Universal DVB driver, the spi_master struct is erroneously not freed.
Likewise, if spi_new_device() fails, the spi_controller struct is
not unregistered. Plug the leaks.
While at it, fix an ordering issue in netup_spi_release() wherein
spi_unregister_master() is called after fiddling with the IRQ control
register. The correct order is to call spi_unregister_master() *before*
this teardown step because bus accesses may still be ongoing until that
function returns.
Fixes: 52b1eaf4c59a ("[media] netup_unidvb: NetUP Universal DVB-S/S2/T/T2/C PCI-E card driver")
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Reviewed-by: Mauro Carvalho Chehab <mchehab+huawei@kernel.org>
Cc: <stable@vger.kernel.org> # v4.3+: 5e844cc37a5c: spi: Introduce device-managed SPI controller allocation
Cc: Kozlov Sergey <serjk@netup.ru>
Link: https://lore.kernel.org/r/c4c24f333fc7840f4a3db24789e6e10dd660bede.1607286887.git.lukas@wunner.de
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit 8e4d86e241cf035d6d3467cd346e7ce490681937 ]
The "a->index" value comes from the user via the ioctl. The problem is
that the shift can wrap resulting in setting "mxb->cur_audinput" to an
invalid value, which later results in an array overflow.
Fixes: 6680427791c9 ("[media] mxb: fix audio handling")
[ Upstream commit dcdff74fa6bc00c32079d0bebd620764c26f2d89 ]
Fix to goto snd_error in error handling case when fails
to do snd_ctl_add, as done elsewhere in this function.
Fixes: 28cae868cd24 ("[media] solo6x10: move out of staging into drivers/media/pci.")
Signed-off-by: Qinglang Miao <miaoqinglang@huawei.com>
[ Upstream commit 780d815dcc9b34d93ae69385a8465c38d423ff0f ]
clang static analysis reports this problem
tw5864-video.c:773:32: warning: The left expression of the compound
assignment is an uninitialized value.
The computed value will also be garbage
fintv->stepwise.max.numerator *= std_max_fps;
stepwise.max is set with frameinterval, which comes from
ret = tw5864_frameinterval_get(input, &frameinterval);
fintv->stepwise.step = frameinterval;
fintv->stepwise.min = frameinterval;
fintv->stepwise.max = frameinterval;
When tw5864_frameinterval_get() fails, frameinterval is not
set. So check the status and fix another similar problem.
Signed-off-by: Tom Rix <trix@redhat.com>
[ Upstream commit 15a36aae1ec1c1f17149b6113b92631791830740 ]
As reported by smatch:
drivers/media/pci/saa7134//saa7134-tvaudio.c:686 saa_dsp_writel() warn: should 'reg << 2' be a 64 bit type?
On a 64-bits Kernel, the shift might be bigger than 32 bits.
In real, this should never happen, but let's shut up the warning.
[ Upstream commit 7b817585b730665126b45df5508dd69526448bc8 ]
In bttv_probe if some functions such as pci_enable_device,
pci_set_dma_mask and request_mem_region fails the allocated
memory for btv should be released.
Signed-off-by: Xiaolong Huang <butterflyhuangxx@gmail.com>
value in debiirq()
[ Upstream commit 6499a0db9b0f1e903d52f8244eacc1d4be00eea2 ]
The value av7110->debi_virt is stored in DMA memory, and it is assigned
to data, and thus data[0] can be modified at any time by malicious
hardware. In this case, "if (data[0] < 2)" can be passed, but then
data[0] can be changed into a large number, which may cause buffer
overflow when the code "av7110->ci_slot[data[0]]" is used.
To fix this possible bug, data[0] is assigned to a local variable, which
replaces the use of data[0].
Signed-off-by: Jia-Ju Bai <baijiaju@tsinghua.edu.cn>
[ Upstream commit fc0456458df8b3421dba2a5508cd817fbc20ea71 ]
budget_register() has no error handling after its failure.
Add the missed undo functions for error handling to fix it.
Signed-off-by: Chuhong Yuan <hslester96@gmail.com>
[ Upstream commit a7b2df76b42bdd026e3106cf2ba97db41345a177 ]
In cx23888_ir_probe if kfifo_alloc fails the allocated memory for state
should be released.
Signed-off-by: Navid Emamdoost <navid.emamdoost@gmail.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
[ Upstream commit dc4cac67e13515835ed8081d510aa507aacb013b ]
The AVerMedia CE310B is a simple composite + S-Video + stereo audio
capture card, and uses only the CX23888 to perform all of these
functions.
I've tested both video inputs and the audio interface and confirmed that
they're all working. However, there are some issues:
* Sometimes when I switch inputs the video signal turns black and can't
be recovered until the system is rebooted. I haven't been able to
determine the cause of this behavior, nor have I found a solution to
fix it or any workarounds other than rebooting.
* The card sometimes seems to have trouble syncing to the video signal,
and some of the VBI data appears as noise at the top of the frame, but
I assume that to be a result of my very noisy RF environment and the
card's unshielded input traces rather than a configuration issue.
Signed-off-by: Forest Crossman <cyrozap@gmail.com>
[ Upstream commit e1444e9b0424c70def6352580762d660af50e03f ]
A call to 'pci_disable_device()' is missing in the error handling path.
In some cases, a call to 'free_irq()' may also be missing.
Reorder the error handling path, add some new labels and fix the 2 issues
mentionned above.
This way, the error handling path in more in line with 'cx8800_finidev()'
(i.e. the remove function)
On 32-bits archs, a signed integer has 31 bits plus on extra
bit for signal. Due to that, touching the 32th bit with something
like:
int bar = 1 << 31;
has an undefined behavior in C on 32 bit architectures, as it
touches the signal bit. This is warned by cppcheck.
Instead, force the numbers to be unsigned, in order to solve this
issue.
As warned by cppcheck:
[drivers/media/dvb-frontends/cx24123.c:434]: (error) Shifting signed 32-bit value by 31 bits is undefined behaviour
[drivers/media/pci/bt8xx/bttv-input.c:87]: (error) Shifting signed 32-bit value by 31 bits is undefined behaviour
[drivers/media/pci/bt8xx/bttv-input.c:98]: (error) Shifting signed 32-bit value by 31 bits is undefined behaviour
[drivers/media/v4l2-core/v4l2-ioctl.c:1391]: (error) Shifting signed 32-bit value by 31 bits is undefined behaviour
There are lots of places where we're doing 1 << 31. That's bad,
as, depending on the architecture, this has an undefined behavior.
The BIT() macro is already prepared to handle this, so, let's
just switch all "1 << number" macros by BIT(number) at the header files
with has 1 << 31.
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> # exynos4-is and s3c-camif
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> # omap3isp, vsp1, xilinx, wl128x and ipu3
Reviewed-by: Benoit Parrot <bparrot@ti.com> # am437x and ti-vpe
It doesn't make any sense to have gcc's stdarg.h included
inside the Linux Kernel.
Get rid of those includes.
saa7134_i2c_eeprom_md7134_gate() function and the associated comment uses
an inverted i2c gate open / closed terminology.
Let's fix this.
Signed-off-by: Maciej S. Szmigiero <mail@maciej.szmigiero.name>
[hverkuil-cisco@xs4all.nl: fix alignment checkpatch warning]
Medion 7134 has two i2c eeproms on the same i2c bus sharing the same bus
addresses: the first one for SAA7134 chip config and the second one behind
TDA10046 DVB-T demod chip i2c gate storing its firmware.
The TV tuner on this board is not behind this i2c gate.
Due to the bus conflict described above, the card PCI SVID / SSID sometimes
gets garbled after a reboot, which makes it necessary to specify the card
model manually as an insmod option in order for it to be detected reliably.
To avoid this, let's just leave the gate permanently closed so the eeprom
chips won't clash.
The demod firmware load is done with its i2c gate closed anyway so it is
not affected by this change.
If saa7146_register_device() fails, no cleanup is executed, leading to
memory/resource leaks. To fix this issue, perform necessary cleanup work
before returning the error.
Signed-off-by: Wenwen Wang <wenwen@cs.uga.edu>
Static structure dst_config, of type dst_config, is not used except to
be assigned as the value of field state of a variable having type
dst_state *. In the definition of dst_state, field config is declared as
const. Hence dst_config, when assigned to config, cannot be modified.
Therefore, make dst_config const as well.
Issue found with Coccinelle.
Signed-off-by: Nishka Dasgupta <nishkadg.linux@gmail.com>
This protocol responds to a real philips rc-mm remote; it does not respond
to IR encoded with the encoder in ir-rcmm-decoder.c.
pci_alloc_consistent calls dma_alloc_coherent directly.
In commit 518a2f1925c3
("dma-mapping: zero memory returned from dma_alloc_*"),
dma_alloc_coherent has already zeroed the memory.
So memset is not needed.
Signed-off-by: Fuqian Huang <huangfq.daxian@gmail.com>
Commit b2ce5617dad2 ("media: i2c: fix warning same module names")
renamed the adv7511 module in the media tree to adv7511-v4l2.
This patch does the same rename for the driver name and device id to
keep the naming consistent.
Since the cobalt driver loads this module, it had to be renamed there
as well.
Instead of using the convenience function
v4l2_async_notifier_parse_fwnode_endpoints(), parse the endpoints and set
up the async sub-devices without using callbacks. While this adds a little
bit of code, it makes parsing the endpoints quite a bit more simple and
gives more control to the driver over the process. The parsing assumes
D-PHY instead of letting the V4L2 fwnode framework guess it.
Reviewed-by: Jacopo Mondi <jacopo+renesas@jmondi.org>
The notifier may be registered even if there are no subdevs. Do that to
simplify the code.
The notifier must be cleaned up whenever parsing endpoints fails. Do that
to avoid a memory leak in that case.
Instead of using to_pci_dev + pci_get_drvdata,
use dev_get_drvdata to make code simpler.
