git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- Added support for some new video formats
- mn88473 DVB frontend driver got promoted from staging
- several improvements at the VSP1 driver
- several cleanups and improvements at the Media Controller
- added Media Controller support to snd-usb-audio. Currently, enabled
only for au0828-based V4L2/DVB boards
- Several improvements at nuvoton-cir: it now supports wake up codes
- Add media controller support to em28xx and saa7134 drivers
- coda driver now accepts NXP distributed firmware files
- Some legacy SoC camera drivers will be moving to staging, as they're
outdated and nobody so far is willing to fix and convert them to use
the current media framework
- As usual, lots of cleanups, improvements and new board additions.
* tag 'media/v4.6-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (381 commits)
media: au0828 disable tuner to demod link in au0828_media_device_register()
[media] touptek: cast char types on %x printk
[media] touptek: don't DMA at the stack
[media] mceusb: use %*ph for small buffer dumps
[media] v4l: exynos4-is: Drop unneeded check when setting up fimc-lite links
[media] v4l: vsp1: Check if an entity is a subdev with the right function
[media] hide unused functions for !MEDIA_CONTROLLER
[media] em28xx: fix Terratec Grabby AC97 codec detection
[media] media: add prefixes to interface types
[media] media: rc: nuvoton: switch attribute wakeup_data to text
[media] v4l2-ioctl: fix YUV422P pixel format description
[media] media: fix null pointer dereference in v4l_vb2q_enable_media_source()
[media] v4l2-mc.h: fix yet more compiler errors
[media] staging/media: add missing TODO files
[media] media.h: always start with 1 for the audio entities
[media] sound/usb: Use meaninful names for goto labels
[media] v4l2-mc.h: fix compiler warnings
[media] media: au0828 audio mixer isn't connected to decoder
[media] sound/usb: Use Media Controller API to share media resources
[media] dw2102: add support for TeVii S662
Rename dma_*_writecombine() to dma_*_wc(), so that the naming
is coherent across the various write-combining APIs. Keep the
old names for compatibility for a while, these can be removed
at a later time. A guard is left to enable backporting of the
rename, and later remove of the old mapping defines seemlessly.
Build tested successfully with allmodconfig.
The following Coccinelle SmPL patch was used for this simple
transformation:
@ rename_dma_alloc_writecombine @
expression dev, size, dma_addr, gfp;
-dma_alloc_writecombine(dev, size, dma_addr, gfp)
+dma_alloc_wc(dev, size, dma_addr, gfp)
@ rename_dma_free_writecombine @
expression dev, size, cpu_addr, dma_addr;
-dma_free_writecombine(dev, size, cpu_addr, dma_addr)
+dma_free_wc(dev, size, cpu_addr, dma_addr)
@ rename_dma_mmap_writecombine @
expression dev, vma, cpu_addr, dma_addr, size;
-dma_mmap_writecombine(dev, vma, cpu_addr, dma_addr, size)
+dma_mmap_wc(dev, vma, cpu_addr, dma_addr, size)
We also keep the old names as compatibility helpers, and
guard against their definition to make backporting easier.
Generated-by: Coccinelle SmPL
Suggested-by: Ingo Molnar <mingo@kernel.org>
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
Cc: airlied@linux.ie
Cc: akpm@linux-foundation.org
Cc: benh@kernel.crashing.org
Cc: bhelgaas@google.com
Cc: bp@suse.de
Cc: dan.j.williams@intel.com
Cc: daniel.vetter@ffwll.ch
Cc: dhowells@redhat.com
Cc: julia.lawall@lip6.fr
Cc: konrad.wilk@oracle.com
Cc: linux-fbdev@vger.kernel.org
Cc: linux-pci@vger.kernel.org
Cc: luto@amacapital.net
Cc: mst@redhat.com
Cc: tomi.valkeinen@ti.com
Cc: toshi.kani@hp.com
Cc: vinod.koul@intel.com
Cc: xen-devel@lists.xensource.com
Link: http://lkml.kernel.org/r/1453516462-4844-1-git-send-email-mcgrof@do-not-panic.com
During the recent vb2_buffer restructuring, the calculation of the
buffer payload reported to userspace was accidentally broken for the
first encoded frame, counting only the length of the headers.
This patch re-adds the length of the actual frame data.
Fixes: 2d7007153f0c ("[media] media: videobuf2: Restructure vb2_buffer")
Reported-by: Michael Olbrich <m.olbrich@pengutronix.de>
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Tested-by: Jan Luebbe <jlu@pengutronix.de>
Cc: <stable@vger.kernel.org> # for v4.4 and up
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
coda_jpeg_check_buffer only cares about the buffer length and contents,
so change the parameter type back from v4l2_vb2_buffer to just the
vb2_buffer.
Instead of just checking the first and last bytes for the SOI and EOI
markers, relax the EOI marker check a bit and allow up to 32 trailing
bytes after the EOI marker as hardware generated JPEGs sometimes contain
some alignment overhead.
Signed-off-by: Kamil Debski <k.debski@samsung.com>
Move timestamp from struct vb2_v4l2_buffer to struct vb2_buffer
for common use, and change its type to u64 in order to handling
y2038 problem. This patch also includes all device drivers' changes related to
this restructuring.
Signed-off-by: Junghak Sung <jh1009.sung@samsung.com>
Signed-off-by: Geunyoung Kim <nenggun.kim@samsung.com>
Acked-by: Seung-Woo Kim <sw0312.kim@samsung.com>
Acked-by: Inki Dae <inki.dae@samsung.com>
Signed-off-by: Hans Verkuil <hansverk@cisco.com>
Remove v4l2 stuff - v4l2_buf, v4l2_plane - from struct vb2_buffer.
Add new member variables - bytesused, length, offset, userptr, fd,
data_offset - to struct vb2_plane in order to cover all information
of v4l2_plane.
struct vb2_plane {
<snip>
unsigned int bytesused;
unsigned int length;
union {
unsigned int offset;
unsigned long userptr;
int fd;
} m;
unsigned int data_offset;
Replace v4l2_buf with new member variables - index, type, memory - which
are common fields for buffer management.
struct vb2_buffer {
<snip>
unsigned int index;
unsigned int type;
unsigned int memory;
unsigned int num_planes;
struct vb2_plane planes[VIDEO_MAX_PLANES];
<snip>
v4l2 specific fields - flags, field, timestamp, timecode,
sequence - are moved to vb2_v4l2_buffer in videobuf2-v4l2.c
struct vb2_v4l2_buffer {
struct vb2_buffer vb2_buf;
__u32 flags;
__u32 field;
struct timeval timestamp;
struct v4l2_timecode timecode;
__u32 sequence;
Make videobuf2-v4l2 as a wrapper of videobuf2-core for v4l2-use.
And replace videobuf2-core.h with videobuf2-v4l2.h.
This renaming change should be accompanied by the modifications
of all device drivers that include videobuf2-core.h.
It can be done with just running this shell script.
replace()
str1=$1
str2=$2
dir=$3
for file in $(find $dir -name *.h -o -name *.c -o -name Makefile)
do
echo $file
sed "s/$str1/$str2/g" $file > $file.out
mv $file.out $file
done
replace "videobuf2-core" "videobuf2-v4l2" "include/media/"
replace "videobuf2-core" "videobuf2-v4l2" "drivers/media/"
replace "videobuf2-core" "videobuf2-v4l2" "drivers/usb/gadget/"
replace "videobuf2-core" "videobuf2-v4l2" "drivers/staging/media/"
The buffers with zero payload are now dumped in coda_fill_bitstream and not
passed to coda_bitstream_queue. This avoids unnecessary fifo addition and
buffer sequence counter increment.
Signed-off-by: Zahari Doychev <zahari.doychev@linux.com>
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
Storing internal frames in macroblock tiled order improves memory
access patterns by allowing increased burst sizes when transferring
the uncompressed macroblocks to or from main memory.
The translation logic only supports a single chroma base address,
so this is only supported for the chroma interleaved NV12 format.
Since the rotator used to copy the decoder output into the v4l2
capture buffers does not seem to support the tiled format correctly,
only enable it in the encoder for now.
start_encoding
The frame cache should be set up correctly to encode NV12 source frames.
This was not done before, so move the cache setup out of start_decoding
into its own function and call it from both start_encoding and
start_decoding.
The encoder allows to specify the VBV model reference decoder's initial
delay and buffer size. Export the corresponding V4L2 controls.
On i.MX6, sometimes after decoding a stream, encoding will produce macroblock
errors caused by missing 8-byte sequences in the output stream. Until the cause
for this is found, reset the hardware after sequence end, which seems to help.
Keep count of number of buffer meta structures in the list and use
a separate spinlock for operations on this counted list instead
of reusing the bitstream mutex in some places and none at all in
others.
Trace events with exactly the same parameters and trace output, such as
coda_enc_pic_run and coda_enc_pic_done, are supposed to use the
DECLARE_EVENT_CLASS and DEFINE_EVENT macros instead of duplicated
TRACE_EVENT macro calls.
This patch changes the order of parameters to coda_dec_rot_done and adds
a timestamp so it can share an event class with coda_bit_queue.
Allow coda_seq_end_work to be called multiple times, move the setting
of ctx->initialized from coda_start/stop_streaming() into
coda_start_encoding/decoding and coda_seq_end_work, respectively,
and skip the SEQ_END command in coda_seq_end_work if the context is
already deinitialized before.
In stream end mode the hardware will read the bitstream to its end,
overshooting the write pointer. Do not write additional data into
the bitstream in this mode.
The mvcol buffer is allocated at the end of the first internal buffer.
This patch fixes an out of bounds array access.
This is already done for one side of the comparison with the expectation
that the HW counter rolls over at the 16 bit boundary. This is true when
decoding a h.264 stream, but doesn't hold for at least MJPEG. As we don't
know the exact wrap-around point for this format just clamp the HW counter
to the same 16 bits. This should be enough to detect most of the errors
and saves us from doing different comparisons based on the decoded format.
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Setting the last buffer flag causes the videobuf2 core to return -EPIPE from
DQBUF calls on the capture queue after the last buffer is dequeued.
This patch also fixes the EOS event to conform to the specification. It now is
sent right after the last buffer has been decoded instead of when the last
buffer is dequeued.
This patch adds tracepoints to the coda driver that can be used together
with the v4l2:v4l2_qbuf and v4l2:v4l2_dqbuf tracepoints to to follow video
frames through the mem2mem device.
For encoding with the BIT processor:
coda:coda_enc_pic_run
coda:coda_enc_pic_done
For decoding with the BIT processor:
coda:coda_bit_queue
coda:coda_dec_pic_run
coda:coda_dec_pic_done
coda:coda_dec_rot_done
Additionally, two low level tracepoints register whenever the BIT processor
is started and returns:
coda:coda_bit_run
coda:coda_bit_done
Issuing a cache flush for the whole bitstream buffer is not optimal in the first
place when only a part of it was written. But given that the buffer is mapped in
writecombine mode, it is not needed at all.
Tested-by: Ian Molton <imolton@ad-holdings.co.uk>
When queueing a buffer into the bitstream fails, it has to be requeued
in the videobuf2 queue before streaming starts, but while streaming it
should be returned to userspace with an error.
Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com>
coda_alloc_aux_buf already prints an error, no need to print duplicate
error messages all over the place.
The parameter buffer is a per-context buffer, so we can allocate and free it
together with the other context buffers during REQBUFS.
Since this was the last context buffer allocated in coda-common.c, we can now
move coda_alloc_context_buf into coda-bit.c.
Allocating the bitstream buffer only when the format is set allows to guarantee
that at least two frames fit into the bitstream buffer. For small frame sizes
a smaller bitstream buffer can be allocated. Since the bitstream buffer size now
depends on the format, replace CODA_MAX_FRAME_SIZE with ctx->bitstream.size
where appropriate and remove the now unused constant.
Since REQBUFS can be called multiple times, but the format can't be changed
unless REQBUFS 0 was called before, we can just keep the allocated context and
bitstream buffers if REQBUFS is called multiple times with a non-zero buffer
count.
[fixed a resource leak preventing repeatedly decoding]
Signed-off-by: Peter Seiderer <ps.report@gmx.net>
Allocate the per-context buffers from REQBUFS instead in start_encoding or
start_decoding. This allows to stop and start streaming independently of
buffer (re)allocation
Make sure the buffer_mutex lock is taken in coda_bit_release
while coda_free_framebuffers and coda_free_context_buffers
are called.
reference buffers
On i.MX6, two subsampling ping-pong buffers are used for motion estimation and
deblocking They should not be counted as framebuffers, or they will be also used
to store reconstructed frames, causing visible artifacts in P-frames.
Compare rounded up width to fit into bytesperline.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
To make sure a set RET_DEC_PIC_SUCCESS flag is not a leftover from
a previous successful run, clear it in prepare_decode.
If userspace doesn't properly separate the bitstream input into
individual frames (which may happen for example on slightly
corrupted streams) the CODA hardware may decode more frames
than we expect. We already log an error in this case, but it's
also necessary to adjust the sequence offset. Otherwise we
spam the log with a sequence number mismatch on every frame
frame after the unexpected one.
Handle an empty buffer metadata list without crashing. This can happen
if the decoder is fed a broken stream, or multiple compressed frames in
a single queued buffer.
This patch adds a quick check for valid JPEG frames before feeding them into
the bitstream buffer: Frames that do not begin with the JPEG start of image
marker and end with the end of image marker are dropped.
For small frame sizes, allocating 1 MiB per compressed buffer is a waste of
space. On the other hand, incompressible 1080p data can produce JPEGs larger
than 1 MiB at higher quality settings. Allow userspace to set the compressed
buffer size and clamp the value to a sensible range.
Also set the initial sizeimage to a value inside the range allowed by try_fmt.
While at it, reduce the default image size to a maximum of 1920*1088 (otherwise
JPEG will default to 8k*8k and 96 MiB buffers).
With bitstream padding, it is possible to decode a single JPEG in the bitstream
immediately. This allows us to only ever queue a single JPEG into the bitstream
buffer, except to increase payload over 512 bytes or to back out of hold state.
This is a measure to decrease JPEG decoder latency.
Before starting a PIC_RUN, pad the bitstream with 0xff until 256 bytes
past the next multiple of 256 bytes, if the buffer to be decoded is the
last buffer in the bitstream.
Storing the buffer position in the bitstream with the buffer metadata
allows to later use that information to drop metadata for skipped buffers
and to determine whether bitstream padding has to be applied.
This patch also renames struct coda_timestamp to struct coda_buffer_meta
to make clear that it contains more than only the buffer timestamp.
This patch adds JPEG encoding and decoding support for CODA7541,
using the BIT processor. Separate JPEG encoder and decoder video
devices are created due to different streaming behaviour and
different supported pixel formats.
The hardware can not change subsampling on the fly, but encode
and decode 4:2:2 subsampled JPEG images from and into this format.
The CODA7541 JPEG decoder uses the bitstream buffer and thus can run
without new buffers queued if there is a buffer in the bitstream.
Since there is no standard way to store the colorspace used in
JPEGs, and to make v4l2-compliance happy, the JPEG format always
reports V4L2_COLORSPACE_JPEG.
This patch adds support for the three-plane YUV422P format with one luma plane
and two horizontally subsampled chroma planes.
This patch adds support for the two-plane NV12 format with one luma plane
and one interleaved chroma plane.
Since the firmware newer writes to FRAME_MEM_CTRL, we can initialize it once
per context (incidentally, we already do write it in coda_hw_init) and never
have to read it back.
This will still do a 1:1 copy into the internal buffers, but stop
producing visual artifacts in chroma interleaved (NV12) mode.
Add a helper function that writes a vb2_buffer's Y, Cb, and
Cr plane base addresses of into three consecutive registers.
This moves common code out of coda-bit.c.
coda-bit uses kmalloc/kfree functions, so the slab header needs to be included
in order to fix the following build errors:
drivers/media/platform/coda/coda-bit.c: In function 'coda_fill_bitstream':
drivers/media/platform/coda/coda-bit.c:231:4: error: implicit declaration of function 'kmalloc' [-Werror=implicit-function-declaration]
drivers/media/platform/coda/coda-bit.c: In function 'coda_alloc_framebuffers':
drivers/media/platform/coda/coda-bit.c:312:3: error: implicit declaration of function 'kfree' [-Werror=implicit-function-declaration]
This patch breaks most long lines, concatenates broken up text strings,
and adds or removes parentheses where needed to make checkpatch happy.
The long codec list lines and a few 81-wide lines remain.
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Lock modification of the timestamp list with bitstream_mutex and do not
try to remove a timestamp element if the list is empty. This can happen
if the userspace feeds us garbage or multiple encoded frames in a single
buffer.
Signed-off-by: Michael Olbrich <m.olbrich@pengutronix.de>
Produce some error messages when internal buffer allocation
fails, for example because the CMA region is too small.
coda_finish_decode
The return value of this call to v4l2_m2m_next_dst_buf() is never used.
This patch moves the BIT processor specific coda_context_ops, the firmware
upload and other related functions from coda-common.c into coda-bit.c.
