path: root/drivers/media/platform/s5p-g2d
2015-10-20[media] media: videobuf2: Change queue_setup argumentJunghak Sung
Replace struct v4l2_format * with void * to make queue_setup() for common use. And then, modify all device drivers related with this change. Signed-off-by: Junghak Sung <jh1009.sung@samsung.com> Signed-off-by: Geunyoung Kim <nenggun.kim@samsung.com> Acked-by: Seung-Woo Kim <sw0312.kim@samsung.com> Acked-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> [hans.verkuil@cisco.com: fix missing const in fimc-lite.c] Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-10-01[media] media: videobuf2: Restructure vb2_bufferJunghak Sung
Remove v4l2 stuff - v4l2_buf, v4l2_plane - from struct vb2_buffer. Add new member variables - bytesused, length, offset, userptr, fd, data_offset - to struct vb2_plane in order to cover all information of v4l2_plane. struct vb2_plane { <snip> unsigned int bytesused; unsigned int length; union { unsigned int offset; unsigned long userptr; int fd; } m; unsigned int data_offset; } Replace v4l2_buf with new member variables - index, type, memory - which are common fields for buffer management. struct vb2_buffer { <snip> unsigned int index; unsigned int type; unsigned int memory; unsigned int num_planes; struct vb2_plane planes[VIDEO_MAX_PLANES]; <snip> }; v4l2 specific fields - flags, field, timestamp, timecode, sequence - are moved to vb2_v4l2_buffer in videobuf2-v4l2.c struct vb2_v4l2_buffer { struct vb2_buffer vb2_buf; __u32 flags; __u32 field; struct timeval timestamp; struct v4l2_timecode timecode; __u32 sequence; }; Signed-off-by: Junghak Sung <jh1009.sung@samsung.com> Signed-off-by: Geunyoung Kim <nenggun.kim@samsung.com> Acked-by: Seung-Woo Kim <sw0312.kim@samsung.com> Acked-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-10-01[media] media: videobuf2: Replace videobuf2-core with videobuf2-v4l2Junghak Sung
Make videobuf2-v4l2 as a wrapper of videobuf2-core for v4l2-use. And replace videobuf2-core.h with videobuf2-v4l2.h. This renaming change should be accompanied by the modifications of all device drivers that include videobuf2-core.h. It can be done with just running this shell script. replace() { str1=$1 str2=$2 dir=$3 for file in $(find $dir -name *.h -o -name *.c -o -name Makefile) do echo $file sed "s/$str1/$str2/g" $file > $file.out mv $file.out $file done } replace "videobuf2-core" "videobuf2-v4l2" "include/media/" replace "videobuf2-core" "videobuf2-v4l2" "drivers/media/" replace "videobuf2-core" "videobuf2-v4l2" "drivers/usb/gadget/" replace "videobuf2-core" "videobuf2-v4l2" "drivers/staging/media/" Signed-off-by: Junghak Sung <jh1009.sung@samsung.com> Signed-off-by: Geunyoung Kim <nenggun.kim@samsung.com> Acked-by: Seung-Woo Kim <sw0312.kim@samsung.com> Acked-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-05-12[media] media: platform: s5p: Constify platform_device_idKrzysztof Kozlowski
The platform_device_id is not modified by the driver and core uses it as const. Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com> [k.debski@samsung.com: Fix misspelling in title (s/sp5/s5p/)] Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-02-02[media] s5p-g2d: remove unnecessary version.h inclusionFabian Frederick
Based on versioncheck. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-12-02[media] media/platform: fix querycapHans Verkuil
Querycap shouldn't set the version field (the core does that for you), but it should set the device_caps field. In addition, remove the CAPTURE and OUTPUT caps for M2M devices. These were already slated for removal, so it's time to do so. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Kamil Debski <k.debski@samsung.com> Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Acked-by: Jacek Anaszewski <j.anaszewski@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2014-10-20media: platform: s5p-g2d: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-08-26[media] g2d: remove unused varMauro Carvalho Chehab
drivers/media/platform/s5p-g2d/g2d.c: In function 'job_abort': drivers/media/platform/s5p-g2d/g2d.c:493:6: warning: variable 'ret' set but not used [-Wunused-but-set-variable] int ret; ^ The job_abort function returns void. No sense to get the returned argument, if this won't be used. Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-03-05[media] v4l: Copy timestamp source flags to destination on m2m devicesSakari Ailus
Copy the flags containing the timestamp source from source buffer flags to the destination buffer flags on memory-to-memory devices. This is analogous to copying the timestamp field from source to destination. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-03-05[media] v4l: Rename vb2_queue.timestamp_type as timestamp_flagsSakari Ailus
The timestamp_type field used to contain only the timestamp type. Soon it will be used for timestamp source flags as well. Rename the field accordingly. [m.chehab@samsung.com: do the change also to drivers/staging/media and at s2255] Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-12-04[media] s5p-g2d: Use mem-to-mem ioctl helpersSylwester Nawrocki
Simplify the driver by using the m2m ioctl and vb2 helpers. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-10-28[media] s5p-g2d: Remove casting the return value which is a void pointerJingoo Han
Casting the return value which is a void pointer is redundant. The conversion from void pointer to any other pointer type is guaranteed by the C programming language. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-09-03[media] s5p-g2d: Fix registration failureSachin Kamat
Commit 1c1d86a1ea ("[media] v4l2: always require v4l2_dev, rename parent to dev_parent") expects v4l2_dev to be always set. It converted most of the drivers using the parent field of video_device to v4l2_dev field. G2D driver did not set the parent field. Hence it got left out. Without this patch we get the following boot warning and G2D driver fails to register the video device. WARNING: CPU: 0 PID: 1 at drivers/media/v4l2-core/v4l2-dev.c:775 __video_register_device+0xfc0/0x1028() Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.11.0-rc1-00001-g1c3e372-dirty #9 [<c0014b7c>] (unwind_backtrace+0x0/0xf4) from [<c0011524>] (show_stack+0x10/0x14) [<c0011524>] (show_stack+0x10/0x14) from [<c041d7a8>] (dump_stack+0x7c/0xb0) [<c041d7a8>] (dump_stack+0x7c/0xb0) from [<c001dc94>] (warn_slowpath_common+0x6c/0x88) [<c001dc94>] (warn_slowpath_common+0x6c/0x88) from [<c001dd4c>] (warn_slowpath_null+0x1c/0x24) [<c001dd4c>] (warn_slowpath_null+0x1c/0x24) from [<c02cf8d4>] (__video_register_device+0xfc0/0x1028) [<c02cf8d4>] (__video_register_device+0xfc0/0x1028) from [<c0311a94>] (g2d_probe+0x1f8/0x398) [<c0311a94>] (g2d_probe+0x1f8/0x398) from [<c0247d54>] (platform_drv_probe+0x14/0x18) [<c0247d54>] (platform_drv_probe+0x14/0x18) from [<c0246b10>] (driver_probe_device+0x108/0x220) [<c0246b10>] (driver_probe_device+0x108/0x220) from [<c0246cf8>] (__driver_attach+0x8c/0x90) [<c0246cf8>] (__driver_attach+0x8c/0x90) from [<c0245050>] (bus_for_each_dev+0x60/0x94) [<c0245050>] (bus_for_each_dev+0x60/0x94) from [<c02462c8>] (bus_add_driver+0x1c0/0x24c) [<c02462c8>] (bus_add_driver+0x1c0/0x24c) from [<c02472d0>] (driver_register+0x78/0x140) [<c02472d0>] (driver_register+0x78/0x140) from [<c00087c8>] (do_one_initcall+0xf8/0x144) [<c00087c8>] (do_one_initcall+0xf8/0x144) from [<c05b29e8>] (kernel_init_freeable+0x13c/0x1d8) [<c05b29e8>] (kernel_init_freeable+0x13c/0x1d8) from [<c041a108>] (kernel_init+0xc/0x160) [<c041a108>] (kernel_init+0xc/0x160) from [<c000e2f8>] (ret_from_fork+0x14/0x3c) ---[ end trace 4e0ec028b0028e02 ]--- s5p-g2d 12800000.g2d: Failed to register video device s5p-g2d: probe of 12800000.g2d failed with error -22 Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com> Cc: stable@vger.kernel.org
2013-04-25[media] s5p-g2d: Add copy time stamp handlingKamil Debski
Since the introduction of the timestamp_type field, it is necessary that the driver chooses which type it will use. This patch adds support for the timestamp_type. Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-05[media] s5p-g2d: Add DT based discovery supportSachin Kamat
This patch adds device tree based discovery support to the G2D driver. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-02-06[media] media: Convert to devm_ioremap_resource()Thierry Reding
Convert all uses of devm_request_and_ioremap() to the newly introduced devm_ioremap_resource() which provides more consistent error handling. devm_ioremap_resource() provides its own error messages so all explicit error messages can be removed from the failure code paths. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-02-05[media] s5p-g2d: Add support for G2D H/W Rev.4.1Sachin Kamat
Modified the G2D driver (which initially supported only H/W Rev.3) to support H/W Rev.4.1 present on Exynos4x12 and Exynos52x0 SOCs. - Set the SRC and DST type to 'memory' instead of using reset values. - FIMG2D v4.1 H/W uses different logic for stretching(scaling). - Use CACHECTL_REG only with FIMG2D v3. [s.nawrocki: removed empty line at end of file]] Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-01-06[media] s5p-g2d: Fix incorrect usage of IS_ERR_OR_NULLTony Prisk
Replace IS_ERR_OR_NULL with IS_ERR on clk_get results. Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-10-05[media] s5p-g2d: fix compiler warningHans Verkuil
drivers/media/platform/s5p-g2d/g2d.c:535:2: warning: passing argument 3 of 'vidioc_try_crop' discards 'const' qualifier from pointer target type [enabled by default] drivers/media/platform/s5p-g2d/g2d.c:510:12: note: expected 'struct v4l2_crop *' but argument is of type 'const struct v4l2_crop *' This is fall-out from this commit: commit 4f996594ceaf6c3f9bc42b40c40b0f7f87b79c86 Author: Hans Verkuil <hans.verkuil@cisco.com> [media] v4l2: make vidioc_s_crop const Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-26[media] Set vfl_dir for all display or m2m driversHans Verkuil
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Acked-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-26[media] v4l2: make vidioc_s_crop constHans Verkuil
Write-only ioctls should have a const argument in the ioctl op. Do this conversion for vidioc_s_crop. Adding const for write-only ioctls was decided during the 2012 Media Workshop. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-15[media] s5p-g2d: Remove unneeded struct vb2_queue clear on queue_init()Ezequiel García
queue_init() is always called by v4l2_m2m_ctx_init(), which allocates a context struct v4l2_m2m_ctx with kzalloc. Therefore, there is no need to clear vb2_queue src/dst structs. Cc: Kamil Debski <k.debski@samsung.com> Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] rename drivers/media/video as .../platformMauro Carvalho Chehab
The remaining drivers are mostly platform drivers. Name the dir to reflect it. It makes sense to latter break it into a few other dirs. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
