This is the 5.4.193 stable release
arch/arm64/boot/dts/freescale/fsl-ls1028a-qds.dts
drivers/edac/synopsys_edac.c
drivers/mmc/host/sdhci-esdhc-imx.c
drivers/mmc/host/sdhci.c
drivers/mtd/nand/raw/gpmi-nand/gpmi-nand.c
sound/soc/codecs/msm8916-wcd-analog.c
[ Upstream commit 4b732a0016853eaff35944f900b0db66f3914374 ]
Previous reg-field, 0x98[11:0], stands for the period of the detected
hsync signal.
Use the correct reg, 0xa0, to get h-total in pixels.
Fixes: d2b4387f3bdf ("media: platform: Add Aspeed Video Engine driver")
Signed-off-by: Jammy Huang <jammy_huang@aspeedtech.com>
Reviewed-by: Joel Stanley <joel@jms.id.au>
Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl>
Signed-off-by: Mauro Carvalho Chehab <mchehab@kernel.org>
[ Upstream commit ca85d271531a1e1c86f24b892f57b7d0a3ddb5a6 ]
The reference taken by 'of_find_device_by_node()' must be released when
not needed anymore.
Add the corresponding 'put_device()' in the error handling path.
Fixes: e7f3c5481035 ("[media] coda: use VDOA for un-tiling custom macroblock format")
Signed-off-by: Miaoqian Lin <linmq006@gmail.com>
commit 4a321de239213300a714fa0353a5f1272d381a44 upstream.
Make sure to balance the runtime PM usage counter on driver unbind.
Fixes: 407ccc65bfd2 ("[media] davinci: vpif: add pm_runtime support")
Cc: stable@vger.kernel.org # 3.9
Cc: Lad, Prabhakar <prabhakar.csengg@gmail.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
Reviewed-by: Lad Prabhakar <prabhakar.csengg@gmail.com>
commit 549cc89cd09a85aaa16dc07ef3db811d5cf9bcb1 upstream.
PHTW register is selected based on default bit rate from Table[1].
for the bit rates less than or equal to 250. Currently first
value of default bit rate which is greater than or equal to
the caculated mbps is selected. This selection can be further
improved by selecting the default bit rate which is nearest to
the calculated value.
[1] specs r19uh0105ej0200-r-car-3rd-generation.pdf [Table 25.12]
Fixes: 769afd212b16 ("media: rcar-csi2: add Renesas R-Car MIPI CSI-2 receiver driver")
Signed-off-by: Suresh Udipi <sudipi@jp.adit-jv.com>
Signed-off-by: Michael Rodin <mrodin@de.adit-jv.com>
Reviewed-by: Niklas Söderlund <niklas.soderlund+renesas@ragnatech.se>
Signed-off-by: Mauro Carvalho Chehab <mchehab+huawei@kernel.org>
[ Upstream commit 43f0633f89947df57fe0b5025bdd741768007708 ]
The return value of dma_set_coherent_mask() is not always 0.
To catch the exception in case that dma is not support the mask.
Link: https://lore.kernel.org/linux-media/20211206022201.1639460-1-jiasheng@iscas.ac.cn
Fixes: b0444f18e0b1 ("[media] coda: add i.MX6 VDOA driver")
Signed-off-by: Jiasheng Jiang <jiasheng@iscas.ac.cn>
'venus_probe()'
[ Upstream commit 8cc7a1b2aca067397a016cdb971a5e6ad9b640c7 ]
A successful 'of_platform_populate()' call should be balanced by a
corresponding 'of_platform_depopulate()' call in the error handling path
of the probe, as already done in the remove function.
A successful 'venus_firmware_init()' call should be balanced by a
corresponding 'venus_firmware_deinit()' call in the error handling path
Update the error handling path accordingly.
Fixes: f9799fcce4bb ("media: venus: firmware: register separate platform_device for firmware loader")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Signed-off-by: Stanimir Varbanov <stanimir.varbanov@linaro.org>
[ Upstream commit 9f89c881bffbdffe4060ffaef3489a2830a6dd9c ]
The func v4l2_m2m_ctx_release waits for currently running jobs
to finish and then stop streaming both queues and frees the buffers.
All this should be done before the call to mtk_vcodec_enc_release
which frees the encoder handler. This fixes null-pointer dereference bug:
[ 638.028076] Mem abort info:
[ 638.030932] ESR = 0x96000004
[ 638.033978] EC = 0x25: DABT (current EL), IL = 32 bits
[ 638.039293] SET = 0, FnV = 0
[ 638.042338] EA = 0, S1PTW = 0
[ 638.045474] FSC = 0x04: level 0 translation fault
[ 638.050349] Data abort info:
[ 638.053224] ISV = 0, ISS = 0x00000004
[ 638.057055] CM = 0, WnR = 0
[ 638.060018] user pgtable: 4k pages, 48-bit VAs, pgdp=000000012b6db000
[ 638.066485] [00000000000001a0] pgd=0000000000000000, p4d=0000000000000000
[ 638.073277] Internal error: Oops: 96000004 [#1] SMP
[ 638.078145] Modules linked in: rfkill mtk_vcodec_dec mtk_vcodec_enc uvcvideo mtk_mdp mtk_vcodec_common videobuf2_dma_contig v4l2_h264 cdc_ether v4l2_mem2mem videobuf2_vmalloc usbnet videobuf2_memops videobuf2_v4l2 r8152 videobuf2_common videodev cros_ec_sensors cros_ec_sensors_core industrialio_triggered_buffer kfifo_buf elan_i2c elants_i2c sbs_battery mc cros_usbpd_charger cros_ec_chardev cros_usbpd_logger crct10dif_ce mtk_vpu fuse ip_tables x_tables ipv6
[ 638.118583] CPU: 0 PID: 212 Comm: kworker/u8:5 Not tainted 5.15.0-06427-g58a1d4dcfc74-dirty #109
[ 638.127357] Hardware name: Google Elm (DT)
[ 638.131444] Workqueue: mtk-vcodec-enc mtk_venc_worker [mtk_vcodec_enc]
[ 638.137974] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 638.144925] pc : vp8_enc_encode+0x34/0x2b0 [mtk_vcodec_enc]
[ 638.150493] lr : venc_if_encode+0xac/0x1b0 [mtk_vcodec_enc]
[ 638.156060] sp : ffff8000124d3c40
[ 638.159364] x29: ffff8000124d3c40 x28: 0000000000000000 x27: 0000000000000000
[ 638.166493] x26: 0000000000000000 x25: ffff0000e7f252d0 x24: ffff8000124d3d58
[ 638.173621] x23: ffff8000124d3d58 x22: ffff8000124d3d60 x21: 0000000000000001
[ 638.180750] x20: ffff80001137e000 x19: 0000000000000000 x18: 0000000000000001
[ 638.187878] x17: 000000040044ffff x16: 00400032b5503510 x15: 0000000000000000
[ 638.195006] x14: ffff8000118536c0 x13: ffff8000ee1da000 x12: 0000000030d4d91d
[ 638.202134] x11: 0000000000000000 x10: 0000000000000980 x9 : ffff8000124d3b20
[ 638.209262] x8 : ffff0000c18d4ea0 x7 : ffff0000c18d44c0 x6 : ffff0000c18d44c0
[ 638.216391] x5 : ffff80000904a3b0 x4 : ffff8000124d3d58 x3 : ffff8000124d3d60
[ 638.223519] x2 : ffff8000124d3d78 x1 : 0000000000000001 x0 : ffff80001137efb8
[ 638.230648] Call trace:
[ 638.233084] vp8_enc_encode+0x34/0x2b0 [mtk_vcodec_enc]
[ 638.238304] venc_if_encode+0xac/0x1b0 [mtk_vcodec_enc]
[ 638.243525] mtk_venc_worker+0x110/0x250 [mtk_vcodec_enc]
[ 638.248918] process_one_work+0x1f8/0x498
[ 638.252923] worker_thread+0x140/0x538
[ 638.256664] kthread+0x148/0x158
[ 638.259884] ret_from_fork+0x10/0x20
[ 638.263455] Code: f90023f9 2a0103f5 aa0303f6 aa0403f8 (f940d277)
[ 638.269538] ---[ end trace e374fc10f8e181f5 ]---
[gst-master] root@debian:~/gst-build# [ 638.019193] Unable to handle kernel NULL pointer dereference at virtual address 00000000000001a0
Fixes: 4e855a6efa547 ("[media] vcodec: mediatek: Add Mediatek V4L2 Video Encoder Driver")
Signed-off-by: Dafna Hirschfeld <dafna.hirschfeld@collabora.com>
[ Upstream commit ed2f97ad4b21072f849cf4ae6645d1f2b1d3f550 ]
After devm_request_threaded_irq() is called there is a chance that an
interrupt may occur before the spinlock is initialized, which will trigger
a kernel oops.
To prevent that, move the initialization of the spinlock prior to
requesting the interrupts.
Fixes: 51abcf7fdb70 ("media: imx-pxp: add i.MX Pixel Pipeline driver")
Signed-off-by: Fabio Estevam <festevam@denx.de>
Reviewed-by: Philipp Zabel <p.zabel@pengutronix.de>
[ Upstream commit cee44d4fbacbbdfe62697ec94e76c6e4f726c5df ]
hsfreqrange should be chosen based on the calculated mbps which
is closer to the default bit rate and within the range as per
table[1]. But current calculation always selects first value which
is greater than or equal to the calculated mbps which may lead
to chosing a wrong range in some cases.
For example for 360 mbps for H3/M3N
Existing logic selects
Calculated value 360Mbps : Default 400Mbps Range [368.125 -433.125 mbps]
This hsfreqrange is out of range.
The logic is changed to get the default value which is closest to the
calculated value [1]
Calculated value 360Mbps : Default 350Mbps Range [320.625 -380.625 mpbs]
[1] specs r19uh0105ej0200-r-car-3rd-generation.pdf [Table 25.9]
Please note that According to Renesas in Table 25.9 the range for
220 default value is corrected as below
|Range (Mbps) | Default Bit rate (Mbps) |
| 197.125-244.125 | 220 |
Signed-off-by: Kazuyoshi Akiyama <akiyama@nds-osk.co.jp>
[ Upstream commit af6d1bde395cac174ee71adcd3fa43f6435c7206 ]
If res-chg, VE_INTERRUPT_MODE_DETECT_WD irq will be raised. But
v4l2_input_status won't be updated to no-signal immediately until
aspeed_video_get_resolution() in aspeed_video_resolution_work().
During the period of time, aspeed_video_start_frame() could be called
because it doesn't know signal becomes unstable now. If it goes with
aspeed_video_init_regs() of aspeed_video_irq_res_change()
simultaneously, it will mess up hw state.
To fix this problem, v4l2_input_status is updated to no-signal
immediately for VE_INTERRUPT_MODE_DETECT_WD irq.
Acked-by: Paul Menzel <pmenzel@molgen.mpg.de>
[ Upstream commit 62cea52ad4bead0ae4be2cfe1142eb0aae0e9fbd ]
aspeed_video_get_resolution() will try to do res-detect again if the
timing got in last try is invalid. But it will always time out because
VE_SEQ_CTRL_TRIG_MODE_DET is only cleared after 1st mode-detect.
To fix the problem, just clear VE_SEQ_CTRL_TRIG_MODE_DET before setting
it in aspeed_video_enable_mode_detect().
toradex_5.4-2.3.x-imx-v5.4.161
drivers/net/phy/micrel.c
drivers/usb/chipidea/core.c
This is the 5.4.160 stable release
'mtk_vpu_probe()'
[ Upstream commit 2143ad413c05c7be24c3a92760e367b7f6aaac92 ]
A successful 'clk_prepare()' call should be balanced by a corresponding
'clk_unprepare()' call in the error handling path of the probe, as already
Fixes: 3003a180ef6b ("[media] VPU: mediatek: support Mediatek VPU")
Reviewed-by: Houlong Wei <houlong.wei@mediatek.com>
[ Upstream commit fc41665498332ad394b7db37f23e9394096ddc71 ]
If rcsi2_code_to_fmt() return NULL, then null pointer dereference occurs
in the next cycle. That should not be possible now but adding checking
protects from future bugs.
The patch adds checking if format is NULL.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Nadezda Lutovinova <lutovinova@ispras.ru>
Reviewed-by: Jacopo Mondi <jacopo@jmondi.org>
[ Upstream commit cdfaf4752e6915a4b455ad4400133e540e4dc965 ]
If of_device_get_match_data() return NULL,
then null pointer dereference occurs in s5p_mfc_init_pm().
The patch adds checking if dev->variant is NULL.
[ Upstream commit 8515965e5e33f4feb56134348c95953f3eadfb26 ]
The variable pdev is assigned to dev->plat_dev, and dev->plat_dev is
checked in:
if (!dev->plat_dev)
This indicates both dev->plat_dev and pdev can be NULL. If so, the
function dev_err() is called to print error information.
dev_err(&pdev->dev, "No platform data specified\n");
However, &pdev->dev is an illegal address, and it is dereferenced in
dev_err().
To fix this possible null-pointer dereference, replace dev_err() with
mfc_err().
Reported-by: TOTE Robot <oslab@tsinghua.edu.cn>
Signed-off-by: Tuo Li <islituo@gmail.com>
[ Upstream commit 548fa43a58696450c15b8f5564e99589c5144664 ]
At the moment of enabling irq handling:
1922 ret = devm_request_threaded_irq(&pdev->dev, irq, dcmi_irq_callback,
1923 dcmi_irq_thread, IRQF_ONESHOT,
1924 dev_name(&pdev->dev), dcmi);
there is still uninitialized field sd_format of struct stm32_dcmi *dcmi.
If an interrupt occurs in the interval between the installation of the
interrupt handler and the initialization of this field, NULL pointer
dereference happens.
This field is dereferenced in the handler function without any check:
457 if (dcmi->sd_format->fourcc == V4L2_PIX_FMT_JPEG &&
458 dcmi->misr & IT_FRAME) {
The patch moves interrupt handler installation
after initialization of the sd_format field that happens in
dcmi_graph_notify_complete() via dcmi_set_default_fmt().
Signed-off-by: Dmitriy Ulitin <ulitin@ispras.ru>
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
This is the 5.4.148 stable release
- drivers/dma/imx-sdma.c:
Following upstream patches are already applied to NXP tree:
7cfbf391e870 ("dmaengine: imx-sdma: remove duplicated sdma_load_context")
788122c99d85 ("Revert "dmaengine: imx-sdma: refine to load context only
once"")
- drivers/usb/chipidea/host.c:
Merge upstream commit a18cfd715e91 ("usb: chipidea: host: fix port index
underflow and UBSAN complains") to NXP version.
Signed-off-by: Andrey Zhizhikin <andrey.zhizhikin@leica-geosystems.com>
[ Upstream commit 38367073c796a37a61549b1f66a71b3adb03802d ]
tegra_cec_probe() and tegra_cec_resume() ignored possible errors of
clk_prepare_enable(). The patch fixes this.
Signed-off-by: Evgeny Novikov <novikov@ispras.ru>
This is the 5.4.147 stable release
[ Upstream commit 09ea9719a423fc675d40dd05407165e161ea0c48 ]
Currently the call to find_format can potentially return a NULL to
fmt and the nullpointer is later dereferenced on the assignment of
pixmp->num_planes = fmt->num_planes. Fix this by adding a NULL pointer
check and returning NULL for the failure case.
Addresses-Coverity: ("Dereference null return")
Fixes: aaaa93eda64b ("[media] media: venus: venc: add video encoder files")
[ Upstream commit 44693d74f5653f82cd7ca0fe730eed0f6b83306a ]
The frame memory control register value is currently determined
before userspace selects the final capture format and never corrected.
Update ctx->frame_mem_ctrl in __coda_start_decoding() to fix decoding
into YUV420 or YVU420 capture buffers.
Reported-by: Andrej Picej <andrej.picej@norik.com>
Fixes: 497e6b8559a6 ("media: coda: add sequence initialization work")
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
This is the 5.4.133 stable release
This is the 5.4.132 stable release
Conflicts (manual resolve):
- drivers/gpu/drm/rockchip/cdn-dp-core.c:
Fix merge hiccup when integrating upstream commit 450c25b8a4c9c
("drm/rockchip: cdn-dp-core: add missing clk_disable_unprepare() on
error in cdn_dp_grf_write()")
- drivers/perf/fsl_imx8_ddr_perf.c:
Port upstream commit 3fea9b708ae37 ("drivers/perf: fix the missed
ida_simple_remove() in ddr_perf_probe()") manually to NXP version.
commit 0a7790be182d32b9b332a37cb4206e24fe94b728 upstream.
The saa6588_ioctl() function expects to get called from other kernel
functions with a 'saa6588_command' pointer, but I found nothing stops it
from getting called from user space instead, which seems rather dangerous.
The same thing happens in the davinci vpbe driver with its VENC_GET_FLD
command.
As a quick fix, add a separate .command() callback pointer for this
driver and change the two callers over to that. This change can easily
get backported to stable kernels if necessary, but since there are only
two drivers, we may want to eventually replace this with a set of more
specialized callbacks in the long run.
Fixes: c3fda7f835b0 ("V4L/DVB (10537): saa6588: convert to v4l2_subdev.")
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
commit 3e465fc3846734e9489273d889f19cc17b4cf4bd upstream.
This reverts commit d39083234c60519724c6ed59509a2129fd2aed41.
Because of recent interactions with developers from @umn.edu, all
commits from them have been recently re-reviewed to ensure if they were
correct or not.
Upon review, it was determined that this commit is not needed at all as
the media core already prevents memory disclosure on this codepath, so
just drop the extra memset happening here.
Cc: Kangjie Lu <kjlu@umn.edu>
Cc: Geert Uytterhoeven <geert+renesas@glider.be>
Cc: Hans Verkuil <hverkuil-cisco@xs4all.nl>
Cc: Mauro Carvalho Chehab <mchehab@kernel.org>
Fixes: d39083234c60 ("media: rcar_drif: fix a memory disclosure")
Cc: stable <stable@vger.kernel.org>
Reviewed-by: Mauro Carvalho Chehab <mchehab+huawei@kernel.org>
Reviewed-by: Fabrizio Castro <fabrizio.castro.jz@renesas.com>
Link: https://lore.kernel.org/r/20210503115736.2104747-4-gregkh@linuxfoundation.org
sun6i_video_start_streaming()
[ Upstream commit f3d384e36630e2a552d874e422835606d9cf230a ]
When sun6i_video_remote_subdev() returns NULL to subdev, no error return
code of sun6i_video_start_streaming() is assigned.
To fix this bug, ret is assigned with -EINVAL in this case.
Signed-off-by: Jia-Ju Bai <baijiaju1990@gmail.com>
Fixes: 5cc7522d8965 ("media: sun6i: Add support for Allwinner CSI V3s")
Acked-by: Chen-Yu Tsai <wens@csie.org>
[ Upstream commit 3536169f8531c2c5b153921dc7d1ac9fd570cda7 ]
Video engine uses eclk and vclk for its clock sources and its reset
control is coupled with eclk so the current clock enabling sequence works
like below.
Enable eclk
De-assert Video Engine reset
10ms delay
Enable vclk
It introduces improper reset on the Video Engine hardware and eventually
the hardware generates unexpected DMA memory transfers that can corrupt
memory region in random and sporadic patterns. This issue is observed
very rarely on some specific AST2500 SoCs but it causes a critical
kernel panic with making a various shape of signature so it's extremely
hard to debug. Moreover, the issue is observed even when the video
engine is not actively used because udevd turns on the video engine
hardware for a short time to make a query in every boot.
To fix this issue, this commit changes the clock handling logic to make
the reset de-assertion triggered after enabling both eclk and vclk. Also,
it adds clk_unprepare call for a case when probe fails.
clk: ast2600: fix reset settings for eclk and vclk
Video engine reset setting should be coupled with eclk to match it
with the setting for previous Aspeed SoCs which is defined in
clk-aspeed.c since all Aspeed SoCs are sharing a single video engine
driver. Also, reset bit 6 is defined as 'Video Engine' reset in
datasheet so it should be de-asserted when eclk is enabled. This
commit fixes the setting.
Signed-off-by: Jae Hyun Yoo <jae.hyun.yoo@linux.intel.com>
Reviewed-by: Eddie James <eajames@linux.ibm.com>
Fixes: d3d04f6c330a ("clk: Add support for AST2600 SoC")
Acked-by: Stephen Boyd <sboyd@kernel.org>
[ Upstream commit 5cde22fcc7271812a7944c47b40100df15908358 ]
Currently the chroma_flags and alpha_flags are being zero'd with a bit-wise
mask and the following statement should be bit-wise or'ing in the new flag
bits but instead is making a direct assignment. Fix this by using the |=
operator rather than an assignment.
Addresses-Coverity: ("Unused value")
Fixes: ef834f7836ec ("[media] vivid: add the video capture and output parts")
[ Upstream commit 69306a947b3ae21e0d1cbfc9508f00fec86c7297 ]
pm_runtime_get_sync() will increase the runtime PM counter
even it returns an error. Thus a pairing decrement is needed
to prevent refcount leak. Fix this by replacing this API with
pm_runtime_resume_and_get(), which will not change the runtime
PM counter on error.
Signed-off-by: Dinghao Liu <dinghao.liu@zju.edu.cn>
[ Upstream commit 443ec4bbc6116f6f492a7a1282bfd8422c862158 ]
The EDID had a few mistakes as reported by edid-decode:
Block 1, CTA-861 Extension Block:
Video Data Block: For improved preferred timing interoperability, set 'Native detailed modes' to 1.
Video Capability Data Block: S_PT is equal to S_IT and S_CE, so should be set to 0 instead.
Fixed those.
[ Upstream commit 5d11e6aad1811ea293ee2996cec9124f7fccb661 ]
The m2m_ctx resources was allocated by v4l2_m2m_ctx_init() in g2d_open()
should be freed from g2d_release() when it's not used.
Fix it
Fixes: 918847341af0 ("[media] v4l: add G2D driver for s5p device family")
Signed-off-by: Dillon Min <dillon.minfei@gmail.com>
[ Upstream commit 01fe904c9afd26e79c1f73aa0ca2e3d785e5e319 ]
In isp_video_release, file->private_data is freed via
_vb2_fop_release()->v4l2_fh_release(). But the freed
file->private_data is still used in v4l2_fh_is_singular_file()
->v4l2_fh_is_singular(file->private_data), which is a use
after free bug.
My patch uses a variable 'is_singular_file' to avoid the uaf.
v3: https://lore.kernel.org/patchwork/patch/1419058/
Fixes: 34947b8aebe3f ("[media] exynos4-is: Add the FIMC-IS ISP capture DMA driver")
Signed-off-by: Lv Yunlong <lyl2019@mail.ustc.edu.cn>
[ Upstream commit 747bad54a677d8633ec14b39dfbeb859c821d7f2 ]
There's a bug at s5p_cec_adap_enable(): if called to
disable the device, it should call pm_runtime_put()
instead of pm_runtime_disable(), as the goal here is to
decrement the usage_count and not to disable PM runtime.
Reported-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Reviewed-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
Fixes: 1bcbf6f4b6b0 ("[media] cec: s5p-cec: Add s5p-cec driver")
[ Upstream commit b7fdd208687ba59ebfb09b2199596471c63b69e3 ]
When ctx_id >= HVA_MAX_INSTANCES in hva_hw_its_irq_thread() it tries to
access fields of ctx that is NULL at that point. The patch gets rid of
these accesses.
[ Upstream commit 56c1f0876293888f686e31278d183d4af2cac3c3 ]
The right thing to do is to add a new object to the building
system when a certain config option is selected, and *not*
override them.
So, fix obj-$(config) logic at sti makefiles, using "+=",
instead of ":=".
[ Upstream commit 59087b66ea6730c130c57d23bd9fd139b78c1ba5 ]
The pm_runtime_get_sync() internally increments the
dev->power.usage_count without decrementing it, even on errors.
Replace it by the new pm_runtime_resume_and_get(), introduced by:
commit dd8088d5a896 ("PM: runtime: Add pm_runtime_resume_and_get to deal with usage counter")
in order to properly decrement the usage counter, avoiding
a potential PM usage counter leak.
As a bonus, as pm_runtime_get_sync() always return 0 on
success, the logic can be simplified.
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
[ Upstream commit c44eac5b72e23c31eefc0e10a71d9650036b8341 ]
The bdisp_start_streaming() doesn't take it into account, which
would unbalance PM usage counter at bdisp_stop_streaming().
The logic at bdisp_probe() is correct, but the best is to use
the same call along the driver.
So, replace it by the new pm_runtime_resume_and_get(), introduced by:
[ Upstream commit 10343de268d10cf07b092b8b525e12ad558ead77 ]
As a plus, pm_runtime_resume_and_get() doesn't return
positive numbers, so the return code validation can
be removed.
Acked-by: Andrzej Pietrasiewicz <andrzejtp2010@gmail.com>
[ Upstream commit 908711f542c17fe61e5d653da1beb8e5ab5c7b50 ]
Currently, the driver just assumes that PM runtime logic
succeded resuming the device.
That may not be the case, as pm_runtime_get_sync()
can fail (but keeping the usage count incremented).
Replace the code to use pm_runtime_resume_and_get(),
and letting it return the error code.
This way, if mtk_vcodec_dec_pw_on() fails, the logic
under fops_vcodec_open() will do the right thing and
return an error, instead of just assuming that the
device is ready to be used.
[ Upstream commit 6e8b1526db164c9d4b9dacfb9bc48e365d7c4860 ]
While here, check if the PM runtime error was caught at open time.
[ Upstream commit fdc34e82c0f968ac4c157bd3d8c299ebc24c9c63 ]
s5p_cec_adap_enable().
Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
[ Upstream commit d07bb9702cf5f5ccf3fb661e6cab54bbc33cd23f ]
While here, fix the return contition of mtk_mdp_m2m_start_streaming(),
as it doesn't make any sense to return 0 if the PM runtime failed
to resume.
This is the 5.4.122 stable release
correct or not.
This is the 5.4.119 stable release
