path: root/drivers/media/radio/radio-aztech.c
2011-07-27[media] radio: Use the subsystem version control for VIDIOC_QUERYCAPMauro Carvalho Chehab
Just like the video drivers, the right thing to do is to use the per-subsystem version control. Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-01[media] BKL: trivial BKL removal from V4L2 radio driversHans Verkuil
The patch converts a bunch of V4L2 radio drivers to unlocked_ioctl. These are all simple conversions: most already had a lock and so the ioctl fop could simply be replaced by unlocked_ioctl. radio-miropcm20.c was converted to use the new V4L2 core lock. While doing this work I noticed that many of these drivers initialized some more fields or muted audio or something like that *after* creating the device node. This should be done before the device node is created to prevent problems. Especially hal tends to grab a device node as soon as it is created. In one or two cases the mutex_init was even done after the device creation! Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13547): radio: add trivial checks on the tuner and type args.Hans Verkuil
Many radio drivers did not check the tuner and type field correctly for g/s_frequency. These checks have now been added. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11391): pci-isa radios: remove open and release functionsAlexey Klimov
Patch removes empty open and release functions in pci and isa radio drivers, setting them to NULL. V4L module doesn't call for them due to previous patch. Signed-off-by: Alexey Klimov <klimov.linux@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10959): radio: remove uaccess includeHans Verkuil
This include isn't needed and so can be removed. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10894): ISA radio drivers: improve kernel log messageHans Verkuil
It's much nicer if the log message tells you which io ports are possible, rather than having to run modinfo or look it up in the source or manual. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10881): radio-aztech: convert to v4l2_device.Hans Verkuil
2009-01-02V4L/DVB (10135): v4l2: introduce v4l2_file_operations.Hans Verkuil
Introduce a struct v4l2_file_operations for v4l2 drivers. Remove the unnecessary inode argument. Move compat32 handling (and llseek) into the v4l2-dev core: this is now handled in the v4l2 core and no longer in the drivers themselves. Note that this changeset reverts an earlier patch that changed the return type of__video_ioctl2 from int to long. This change will be reinstated later in a much improved version. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8788): v4l: replace video_get_drvdata(video_devdata(filp)) with ↵Hans Verkuil
video_drvdata(filp) Use the new video_drvdata(filp) function where it is safe to do so. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8786): v4l2: remove the priv field, use dev_get_drvdata insteadHans Verkuil
Remove the priv field and let video_get/set_drvdata use dev_get_drvdata and dev_set_drvdata instead. Convert all drivers that still used priv directly. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8783): v4l: add all missing video_device release callbacksHans Verkuil
All drivers that call video_device_register where checked to see if they set the release callback of struct video_device. Where that callback was missing it was added. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8776): radio: replace video_exclusive_open/releaseHans Verkuil
Move the video_exclusive_open/release functionality into the driver itself. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-09-03V4L/DVB (8778): radio: fix incorrect video_register_device result checkHans Verkuil
2008-07-27V4L/DVB (8523): v4l2-dev: remove unused type and type2 field from video_deviceHans Verkuil
The type and type2 fields were unused and so could be removed. Instead add a vfl_type field that contains the type of the video device. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-26V4L/DVB (8483): Remove obsolete owner field from video_device struct.Hans Verkuil
According to an old comment this should have been removed in 2.6.15. Better late than never... Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-26V4L/DVB (8482): videodev: move all ioctl callbacks to a new v4l2_ioctl_ops ↵Hans Verkuil
struct All ioctl callbacks are now stored in a new v4l2_ioctl_ops struct. Drivers fill in a const struct v4l2_ioctl_ops and video_device just contains a const pointer to it. This ensures a clean separation between the const ops struct and the non-const video_device struct. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-23V4L/DVB (8430): videodev: move some functions from v4l2-dev.h to ↵Hans Verkuil
v4l2-common.h or v4l2-ioctl.h The functions in a header should not belong to another module. The prio functions belong to v4l2-common.c, so move them to v4l2-common.h. The ioctl functions belong to v4l2-ioctl.c, so create a new v4l2-ioctl.h header and move those functions to it. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7402): add macro validation for v4l_compat_ioctl32Douglas Schilling Landgraf
Added macro CONFIG_COMPAT for v4l_compat_ioctl32. Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5705): Removed unnecessary .hardware from video_device struct.Douglas Schilling Landgraf
From: Douglas Schilling Landgraf <dougsland@gmail.com> Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5152): Implements VIDIOC_[S|G]_INPUT on radio-aztech/radio-maxiradioMauro Carvalho Chehab
fmtools use VIDIOCSTUNER, with, in turn, calls VIDIOC_S_INPUT on v4l1-compat. So, those ioctls are required for V4L1 to work properly. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5151): Implement VIDIOC_[GS]_AUDIO on aztechMauro Carvalho Chehab
v4l1-compat requires those two ioctls to translate VIDIOC[SG]RADIO into V4L2 calls. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5148): Convert radio-aztech to use video_ioctl2Mauro Carvalho Chehab
2007-02-12[PATCH] mark struct file_operations const 4Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. [akpm@sdl.org: dvb fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-26V4L/DVB (4348): Fix: compile for radio aimslab and aztech with V4L2 onlyMauro Carvalho Chehab
All radio devices use an obsolete mode of opening/release driver. Since this is not V4L1 core, better to keep the method available for more time than to rewrite open/release without a radio device to test, since the newer method is much more complex than the previous one (although providing support for multiple opens and multiple devices). Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4347): V4L2 conversion: radio_aztechMauro Carvalho Chehab
Driver conversion to V4L2 API. Require some testing, since this obsolete hardware is not common those days. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4339): Removed the remaining config.h stuffMauro Carvalho Chehab
Since kernel include autoconf.h via command line, those config.h inclusion can be removed. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4068): Removed all references to kernel stuff from videodev.h and ↵Mauro Carvalho Chehab
videodev2.h The videodev.h and videodev2.h describe the public API for V4L and V4L2. It shouldn't have there any kernel-specific stuff. Those were moved to v4l2-dev.h. This patch removes some uneeded headers and include v4l2-common.h on all V4L driver. This header includes device implementation of V4L2 API provided on v4l2-dev.h as well as V4L2 internal ioctls that provides connections between master driver and its i2c devices. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3753): Whitespace cleanups at media/radioMauro Carvalho Chehab
2006-02-07V4L/DVB (3318b): sem2mutex: drivers/media/, #2Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09V4L (926_2): Moves compat32 functions from fs to v4l subsystemArnd Bergmann
This moves the 32 bit ioctl compatibility handlers for Video4Linux into a new file and adds explicit calls to them to each v4l device driver. Unfortunately, there does not seem to be any code handling the v4l2 ioctls, so quite often the code goes through two separate conversions, first from 32 bit v4l to 64 bit v4l, and from there to 64 bit v4l2. My patch does not change that, so there is still much room for improvement. Also, some drivers have additional ioctl numbers, for which the conversion should be handled internally to that driver. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-09-13[PATCH] Remove unnecessary check_region references in commentsPeter Osterlund
Remove check_region references from comments and printk statements so that searching for real users of this deprecated function gets easier. Signed-off-by: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
