[ Upstream commit 1b257870a78b0a9ce98fdfb052c58542022ffb5b ]
Make sure to use the current alternate setting, which need not be the
first one by index, when verifying the endpoint descriptors and
initialising the URBs.
Failing to do so could cause the driver to misbehave or trigger a WARN()
in usb_submit_urb() that kernels with panic_on_warn set would choke on.
Fixes: 26ff63137c45 ("[media] Add support for the IguanaWorks USB IR Transceiver")
Fixes: ab1cbdf159be ("media: iguanair: add sanity checks")
Cc: stable <stable@vger.kernel.org> # 3.6
Cc: Oliver Neukum <oneukum@suse.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
Signed-off-by: Sean Young <sean@mess.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab+huawei@kernel.org>
[ Upstream commit ab1cbdf159beba7395a13ab70bc71180929ca064 ]
The driver needs to check the endpoint types, too, as opposed
to the number of endpoints. This also requires moving the check earlier.
Reported-by: syzbot+01a77b82edaa374068e1@syzkaller.appspotmail.com
Signed-off-by: Oliver Neukum <oneukum@suse.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
LIRC_SET_SEND_CARRIER should return 0 on success or -errno.
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
The basic API of rc-core used to be:
dev = rc_allocate_device();
dev->x = a;
dev->y = b;
dev->z = c;
rc_register_device();
which is a pretty common pattern in the kernel, after the introduction of
protocol arrays the API looks something like:
dev->x = a;
rc_set_allowed_protocols(dev, RC_BIT_X);
dev->z = c;
There's no real need for the protocols to be an array, so change it
back to be consistent (and in preparation for the following patches).
[m.chehab@samsung.com: added missing changes at some files]
Signed-off-by: David Härdeman <david@hardeman.nu>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
The allowed and enabled protocol masks need to be expanded to be per
filter type in order to support wakeup filter protocol selection. To
ease that process abstract access to the rc_dev::allowed_protos and
rc_dev::enabled_protocols members with inline functions.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Reviewed-by: Antti Seppälä <a.seppala@gmail.com>
Make the code simpler.
Just comments. No functional changes.
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media build fixes from Mauro Carvalho Chehab:
"A series of patches that fix compilation on non-x86 archs.
While most of them are just build fixes, there are some fixes for real
bugs, as there are a number of drivers using dynamic stack allocation.
A few of those might be considered a security risk, if the i2c-dev
module is loaded, as someone could be sending very long I2C data that
could potentially overflow the Kernel stack. Ok, as using /dev/i2c-*
devnodes usually requires root on usual distros, and exploiting it
would require a DVB board or USB stick, the risk is not high"
* 'topic/kbuild-fixes-for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (28 commits)
[media] platform drivers: Fix build on frv arch
[media] lirc_zilog: Don't use dynamic static allocation
[media] mxl111sf: Don't use dynamic static allocation
[media] af9035: Don't use dynamic static allocation
[media] af9015: Don't use dynamic static allocation
[media] dw2102: Don't use dynamic static allocation
[media] dibusb-common: Don't use dynamic static allocation
[media] cxusb: Don't use dynamic static allocation
[media] v4l2-async: Don't use dynamic static allocation
[media] cimax2: Don't use dynamic static allocation
[media] tuner-xc2028: Don't use dynamic static allocation
[media] tuners: Don't use dynamic static allocation
[media] av7110_hw: Don't use dynamic static allocation
[media] stv090x: Don't use dynamic static allocation
[media] stv0367: Don't use dynamic static allocation
[media] stb0899_drv: Don't use dynamic static allocation
[media] dvb-frontends: Don't use dynamic static allocation
[media] s5h1420: Don't use dynamic static allocation
[media] uvc/lirc_serial: Fix some warnings on parisc arch
Use this new function to make code more comprehensible, since we are
reinitialzing the completion, not initializing.
[akpm@linux-foundation.org: linux-next resyncs]
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13)
Simplify the logic that calculates the carrier, and removes a warning
on avr32 arch:
drivers/media/rc/iguanair.c: In function 'iguanair_set_tx_carrier':
drivers/media/rc/iguanair.c:304: warning: 'sevens' may be used uninitialized in this function
Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com>
All lirc drivers that can transmit, return EINVAL when they are passed
more than IR data than they can send. That is, except for two drivers
which I touched.
On cold boot the device does not initialize until the first packet is
received, and that packet is not processed.
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
The RC_TYPE_* defines are currently used both where a single protocol is
expected and where a bitmap of protocols is expected.
Functions like rc_keydown() and functions which add/remove entries to the
keytable want a single protocol. Future userspace APIs would also
benefit from numeric protocols (rather than bitmap ones). Keytables are
smaller if they can use a small(ish) integer rather than a bitmap.
Other functions or struct members (e.g. allowed_protos,
enabled_protocols, etc) accept multiple protocols and need a bitmap.
Using different types reduces the risk of programmer error. Using a
protocol enum whereever possible also makes for a more future-proof
user-space API as we don't need to worry about a sufficient number of
bits being available (e.g. in structs used for ioctl() calls).
The use of both a number and a corresponding bit is dalso one in e.g.
the input subsystem as well (see all the references to set/clear bit when
changing keytables for example).
This patch separate the different usages in preparation for
upcoming patches.
Where a single protocol is expected, enum rc_type is used; where one or more
protocol(s) are expected, something like u64 is used.
The patch has been rewritten so that the format of the sysfs "protocols"
file is no longer altered (at the loss of some detail). The file itself
should probably be deprecated in the future though.
Cc: Andy Walls <awalls@md.metrocast.net>
Cc: Maxim Levitsky <maximlevitsky@gmail.com>
Cc: Antti Palosaari <crope@iki.fi>
Cc: Mike Isely <isely@pobox.com>
Note that the firmware already disables the receiver before transmit,
there is no need to do this from the driver.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Since commit "[media] rc-core: move timeout and checks to lirc", the
incoming buffer is used after the driver transmits.
The TechnoTrend USB IR Receiver sends 125 ISO URBs per second, even when
there is no IR activity. Reduce the number of wake ups from the other
drivers too.
This saves about 0.25ms/s on a 2.4GHz Core 2 according to powertop.
The Pioneer CU-700 remote causes receiver overflows if you hold down any
button. The remote does not send NEC IR repeats, it repeats the entire
NEC code after 20ms.
The iguanair hardware advertises an interval of 10 which just not enough;
with 100 URBs per second and at most 7 edges per URB, we handle at most
700 edges per second. The remote generates about 900.
With the timeout supplied the interface can go idle. The keymap is
the same one as other drivers which do not come with a remote.
Also fix error codes returned from open.
Now unbind also stops the receiver.
Firmware versions lower than 0x0205 use a different interface which is not
supported. Also report the firmware version in the standard format.
Rather than using usb_interrupt_msg() to receive responses, reuse the
urb callback we already have in place.
