commit 7e0bb5828311f811309bed5749528ca04992af2f upstream.
Like a bunch of other MSI laptops the MS-1039 uses a 0c45:627b
SN9C201 + OV7660 webcam which is mounted upside down.
Add it to the sn9c20x flip_dmi_table to deal with this.
Cc: stable@vger.kernel.org
Reported-by: Rui Salvaterra <rsalvaterra@gmail.com>
Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
[ Upstream commit 4843a543fad3bf8221cf14e5d5f32d15cee89e84 ]
If reg_r() fails, then gspca_dev->usb_buf was left uninitialized,
and some drivers used the contents of that buffer in logic.
This caused several syzbot errors:
https://syzkaller.appspot.com/bug?extid=397fd082ce5143e2f67d
https://syzkaller.appspot.com/bug?extid=1a35278dd0ebfb3a038a
https://syzkaller.appspot.com/bug?extid=06ddf1788cfd048c5e82
I analyzed the gspca drivers and zeroed the buffer where needed.
Reported-and-tested-by: syzbot+1a35278dd0ebfb3a038a@syzkaller.appspotmail.com
Reported-and-tested-by: syzbot+397fd082ce5143e2f67d@syzkaller.appspotmail.com
Reported-and-tested-by: syzbot+06ddf1788cfd048c5e82@syzkaller.appspotmail.com
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Declare v4l2_file_operations structures as const as they are only stored
in the fops field of video_device structures. This field is of type
const, so declare v4l2_file_operations structures with similar properties
as const.
Signed-off-by: Bhumika Goyal <bhumirks@gmail.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
Don't populate array gamma_par_mask on the stack but instead make it
static. Makes the object code smaller by 148 bytes:
Before:
2993 1104 0 4097 1001 drivers/staging/fbtft/fb_st7789v.o
After:
2757 1192 0 3949 f6d drivers/staging/fbtft/fb_st7789v.o
Function kthread_create() returns an ERR_PTR on error. However, in
function s5k83a_start(), its return value is used without validation.
This may result in a bad memory access bug. This patch fixes the bug.
Signed-off-by: Pan Bian <bianpan2016@163.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Avoid warnings like those:
drivers/media/pci/ddbridge/ddbridge-core.c: In function 'dvb_input_detach':
drivers/media/pci/ddbridge/ddbridge-core.c:787:6: warning: this statement may fall through [-Wimplicit-fallthrough=]
if (input->fe) {
drivers/media/pci/ddbridge/ddbridge-core.c:792:2: note: here
case 4:
On several cases, it is just that gcc 7.1 is not capable of
understanding the comment, but on other places, we need an
annotation.
Make sure to check the number of endpoints to avoid accessing memory
beyond the endpoint array should a device lack the expected endpoints.
Note that, as far as I can tell, the gspca framework has already made
sure there is at least one endpoint in the current alternate setting so
there should be no risk for a NULL-pointer dereference here.
Fixes: b517af722860 ("V4L/DVB: gspca_konica: New gspca subdriver for
konica chipset using cams")
Cc: stable <stable@vger.kernel.org> # 2.6.37
Cc: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
Signed-off-by: Hans Verkuil <hansverk@cisco.com>
<linux/sched.h> into <linux/sched/signal.h>
Fix up affected files that include this signal functionality via sched.h.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Fix typos and add the following to the scripts/spelling.txt:
neded||needed
While we are here, fix the "overriden", "wont", and "etc" in the same
hunk in drivers/media/usb/tm6000/tm6000-input.c.
Link: http://lkml.kernel.org/r/1481573103-11329-14-git-send-email-yamada.masahiro@socionext.com
The comparison of err < 0 is redundant as err has been previously
been assigned to 0 and has not changed. Remove the redundant check.
Fixes CoverityScan CID#703363 ("Logically dead code")
Drop the FSF's postal address from the source code files that typically
contain mostly the license text. Of the 628 removed instances, 578 are
outdated.
The patch has been created with the following command without manual edits:
git grep -l "675 Mass Ave\|59 Temple Place\|51 Franklin St" -- \
drivers/media/ include/media|while read i; do i=$i perl -e '
open(F,"< $ENV{i}");
$a=join("", <F>);
$a =~ s/[ \t]*\*\n.*You should.*\n.*along with.*\n.*(\n.*USA.*$)?\n//m
&& $a =~ s/(^.*)Or, (point your browser to) /$1To obtain the license, $2\n$1/m;
close(F);
open(F, "> $ENV{i}");
print F $a;
close(F);'; done
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Remove unneeded variables and assignments.
That makes easier to parse the names, in order to sync it
with gspca-cardlist.rst.
Keeping Documentation/media/v4l-drivers/gspca-cardlist.rst in
sync with the gspca script requires a parser. Simplify the
commented line, to make the parser work better.
Due to the 80-cols restrictions, and latter due to checkpatch
warnings, several strings were broken into multiple lines. This
is not considered a good practice anymore, as it makes harder
to grep for strings at the source code.
As we're right now fixing other drivers due to KERN_CONT, we need
to be able to identify what printk strings don't end with a "\n".
It is a way easier to detect those if we don't break long lines.
So, join those continuation lines.
The patch was generated via the script below, and manually
adjusted if needed.
</script>
use Text::Tabs;
while (<>) {
if ($next ne "") {
$c=$_;
if ($c =~ /^\s+\"(.*)/) {
$c2=$1;
$next =~ s/\"\n$//;
$n = expand($next);
$funpos = index($n, '(');
$pos = index($c2, '",');
if ($funpos && $pos > 0) {
$s1 = substr $c2, 0, $pos + 2;
$s2 = ' ' x ($funpos + 1) . substr $c2, $pos + 2;
$s2 =~ s/^\s+//;
$s2 = ' ' x ($funpos + 1) . $s2 if ($s2 ne "");
print unexpand("$next$s1\n");
print unexpand("$s2\n") if ($s2 ne "");
} else {
print "$next$c2\n";
$next="";
next;
} else {
print $next;
$next="";
} else {
if (m/\"$/) {
if (!m/\\n\"$/) {
$next=$_;
next;
print $_;
</script>
The workqueue "work_thread" is involved in streaming the camera data.
It has a single work item(&dev->work_struct) and hence doesn't require
ordering. Also, it is not being used on a memory reclaim path.
Hence, the singlethreaded workqueue has been replaced with the use of
system_wq.
System workqueues have been able to handle high level of concurrency
for a long time now and hence it's not required to have a singlethreaded
workqueue just to gain concurrency. Unlike a dedicated per-cpu workqueue
created with create_singlethread_workqueue(), system_wq allows multiple
work items to overlap executions even on the same CPU; however, a
per-cpu workqueue doesn't have any CPU locality or global ordering
guarantee unless the target CPU is explicitly specified and thus the
increase of local concurrency shouldn't make any difference.
Work item has been flushed in sd_stop0() to ensure that there are no
pending tasks while disconnecting the driver.
Signed-off-by: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Frank Zago <frank@zago.net>
It has a single work item(&sd->work_struct) and hence doesn't require
system_wq.
system_wq.
The workqueue "work_thread" is involved in updating the JPEG quality
of the gspca_dev. It has a single work item(&sd->work) and hence doesn't
require ordering. Also, it is not being used on a memory reclaim path.
system_wq.
kmalloc will print enough information in case of failure.
Signed-off-by: Wolfram Sang <wsa-dev@sang-engineering.com>
The workqueue "work_thread" is involved in updating parameters for
transfers. It has a single work item(&sd->work) and hence
doesn't require ordering. Also, it is not being used on a memory
reclaim path. Hence, the singlethreaded workqueue has been replaced with
the use of system_wq.
When CONFIG_INPUT is disabled, multiple gspca backend drivers
print compile-time warnings about unused variables:
media/usb/gspca/cpia1.c: In function 'sd_stopN':
media/usb/gspca/cpia1.c:1627:13: error: unused variable 'sd' [-Werror=unused-variable]
media/usb/gspca/konica.c: In function 'sd_stopN':
media/usb/gspca/konica.c:246:13: error: unused variable 'sd' [-Werror=unused-variable]
This annotates the variables as __maybe_unused, to let the compiler
know that they are declared intentionally.
Fixes: ee186fd96a5f ("[media] gscpa_t613: Add support for the camera button")
Fixes: c2f644aeeba3 ("[media] gspca_cpia1: Add support for button")
Fixes: b517af722860 ("V4L/DVB: gspca_konica: New gspca subdriver for konica chipset using cams")
Allow for SS+ devices
Signed-off-by: Oliver Neukum <ONeukum@suse.com>
The workqueue "work_thread" is involved in JPEG quality update.
It has a single work item(&sd->work) and hence doesn't require ordering.
Also, it is not being used on a memory reclaim path. Hence, the
singlethreaded workqueue has been replaced with the use of system_wq.
v4l2-compliance fails with this message:
fail: v4l2-test-buffers.cpp(250): \
timestamp != V4L2_BUF_FLAG_TIMESTAMP_MONOTONIC && \
timestamp != V4L2_BUF_FLAG_TIMESTAMP_COPY
test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: FAIL
When setting the frame time, gspca uses v4l2_get_timestamp() which uses
ktime_get_ts() which uses ktime_get_ts64() which returns a monotonic
timestamp, so it's safe to initialize the buffer flags to
V4L2_BUF_FLAG_TIMESTAMP_MONOTONIC to fix the failure.
Signed-off-by: Antonio Ospite <ao2@ao2.it>
According to v4l2-compliance VIDIOC_ENUM_FRAMEINTERVALS should fail for
unsupported frame sizes, but gspca is too tolerant and tries to find
the frame intervals for the frame size nearest to the requested one.
This makes v4l2-compliance fail with this message:
fail: v4l2-test-formats.cpp(123): \
found frame intervals for invalid size 321x240
test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: FAIL
Fix this by using an exact match for the frame size when enumerating
frame intervals, and retuning an error if the frame size for which the
frame intervals have been asked is not supported.
The name wxh_to_nearest_mode() reflects better what the function does.
Set the frame _interval_ type to V4L2_FRMIVAL_TYPE_DISCRETE instead of
using V4L2_FRMSIZE_TYPE_DISCRETE which is meant for frame _size_.
The old and new values happen to be the same so there is no functional
change.
When writing the change in commit dcc7fdbec53a ("[media] gspca:
ov534/topro: prevent a division by 0") I used magic numbers for the
default framerate to minimize the code footprint to make it easier to
backport the patch to the stable trees.
However it's better if the default framerate has its own define to avoid
risking using different values in different places, and for readability.
While at it also remove some trivial comments about the framerates which
don't add much to the code anymore.
The header file has some private static structures that
are used only by the C file. Move those structures to the C file,
in order to shut up gcc 6.1 warnings.
The mc5602_s5k4aa.h has some private static structures that
The mc5602_brigde.h is included at m5602 submodules. This
causes Gcc 6.1 to complain:
drivers/media/usb/gspca/m5602/m5602_bridge.h:124:28: warning: 'sensor_urb_skeleton' defined but not used [-Wunused-const-variable=]
static const unsigned char sensor_urb_skeleton[] = {
drivers/media/usb/gspca/m5602/m5602_bridge.h:119:28: warning: 'bridge_urb_skeleton' defined but not used [-Wunused-const-variable=]
static const unsigned char bridge_urb_skeleton[] = {
Let's shut up gcc 6.1 warnings by moving those data structures
to the core, as they're used only there.
This fixes those two smatch warnings:
drivers/media/usb/gspca/touptek.c:206 val_reply() warn: argument 3 to %02x specifier has type 'char'
drivers/media/usb/gspca/touptek.c:222 reg_w() warn: argument 4 to %02x specifier has type 'char'
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
As warned by smatch:
drivers/media/usb/gspca/touptek.c:220 reg_w() error: doing dma on the stack (buff)
drivers/media/usb/gspca/touptek.c:458 configure() error: doing dma on the stack (buff)
This can fail, as the stack may not be in a memory that would
allod DMA. So, use the usb_buf instead.
Remove the unused ovfx2_vga_mode/ovfx2_cif_mode arrays from the ov519
driver.
Fix the ov519 driver not working (unable to talk to the sensor) when
plugged into a xhci host. The root cause here is that uhci/ohci/ehci
hosts typically will send any pending async requests every milli-second
and then go to sleep for the rest if the milli-second, where as xhci hosts
send them immediately, causing things to go too fast for the ov519 bridge.
This commit adds a few delays fixing this.
Signed-off-by: Wesley Post <pa4wdh@xs4all.nl>
[hdegoede@redhat.com: Also add delays to w996Xcf.c, as that needs them too]
v4l2-compliance sends a zeroed struct v4l2_streamparm in
v4l2-test-formats.cpp::testParmType(), and this results in a division by
0 in some gspca subdrivers:
divide error: 0000 [#1] SMP
Modules linked in: gspca_ov534 gspca_main ...
CPU: 0 PID: 17201 Comm: v4l2-compliance Not tainted 4.3.0-rc2-ao2 #1
Hardware name: System manufacturer System Product Name/M2N-E SLI, BIOS
ASUS M2N-E SLI ACPI BIOS Revision 1301 09/16/2010
task: ffff8800818306c0 ti: ffff880095c4c000 task.ti: ffff880095c4c000
RIP: 0010:[<ffffffffa079bd62>] [<ffffffffa079bd62>] sd_set_streamparm+0x12/0x60 [gspca_ov534]
RSP: 0018:ffff880095c4fce8 EFLAGS: 00010296
RAX: 0000000000000000 RBX: ffff8800c9522000 RCX: ffffffffa077a140
RDX: 0000000000000000 RSI: ffff880095e0c100 RDI: ffff8800c9522000
RBP: ffff880095e0c100 R08: ffffffffa077a100 R09: 00000000000000cc
R10: ffff880067ec7740 R11: 0000000000000016 R12: ffffffffa07bb400
R13: 0000000000000000 R14: ffff880081b6a800 R15: 0000000000000000
FS: 00007fda0de78740(0000) GS:ffff88012fc00000(0000) knlGS:0000000000000000
CR2: 00000000014630f8 CR3: 00000000cf349000 CR4: 00000000000006f0
Stack:
ffffffffa07a6431 ffff8800c9522000 ffffffffa077656e 00000000c0cc5616
ffff8800c9522000 ffffffffa07a5e20 ffff880095e0c100 0000000000000000
ffff880067ec7740 ffffffffa077a140 ffff880067ec7740 0000000000000016
Call Trace:
[<ffffffffa07a6431>] ? v4l_s_parm+0x21/0x50 [videodev]
[<ffffffffa077656e>] ? vidioc_s_parm+0x4e/0x60 [gspca_main]
[<ffffffffa07a5e20>] ? __video_do_ioctl+0x280/0x2f0 [videodev]
[<ffffffffa07a5ba0>] ? video_ioctl2+0x20/0x20 [videodev]
[<ffffffffa07a59b9>] ? video_usercopy+0x319/0x4e0 [videodev]
[<ffffffff81182dc1>] ? page_add_new_anon_rmap+0x71/0xa0
[<ffffffff811afb92>] ? mem_cgroup_commit_charge+0x52/0x90
[<ffffffff81179b18>] ? handle_mm_fault+0xc18/0x1680
[<ffffffffa07a15cc>] ? v4l2_ioctl+0xac/0xd0 [videodev]
[<ffffffff811c846f>] ? do_vfs_ioctl+0x28f/0x480
[<ffffffff811c86d4>] ? SyS_ioctl+0x74/0x80
[<ffffffff8154a8b6>] ? entry_SYSCALL_64_fastpath+0x16/0x75
Code: c7 93 d9 79 a0 5b 5d e9 f1 f3 9a e0 0f 1f 00 66 2e 0f 1f 84 00
00 00 00 00 66 66 66 66 90 53 31 d2 48 89 fb 48 83 ec 08 8b 46 10 <f7>
76 0c 80 bf ac 0c 00 00 00 88 87 4e 0e 00 00 74 09 80 bf 4f
RIP [<ffffffffa079bd62>] sd_set_streamparm+0x12/0x60 [gspca_ov534]
RSP <ffff880095c4fce8>
---[ end trace 279710c2c6c72080 ]---
Following what the doc says about a zeroed timeperframe (see
http://www.linuxtv.org/downloads/v4l-dvb-apis/vidioc-g-parm.html):
To reset manually applications can just set this field to zero.
fix the issue by resetting the frame rate to a default value in case of
an unusable timeperframe.
The fix is done in the subdrivers instead of gspca.c because only the
subdrivers have notion of a default frame rate to reset the camera to.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
This is a preparation for a change to the type of v4l2 timestamps.
v4l2_get_timestamp() is a helper function that reads the monotonic
time and stores it into a 'struct timeval'. Multiple drivers implement
the same thing themselves for historic reasons.
Changing them all to use v4l2_get_timestamp() is more consistent
and reduces the amount of code duplication, and most importantly
simplifies the following changes.
Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
[hans.verkuil@cisco.com: dropped the v4l2-dev.c patch that didn't belong here]
API compliance scanning with coccinelle flagged:
./drivers/media/usb/gspca/m5602/m5602_s5k83a.c:180:9-25:
WARNING: timeout (100) seems HZ dependent
Numeric constants passed to schedule_timeout() make the effective
timeout HZ dependent which makes little sense in a polling loop for
the cameras rotation state.
Fixed up by converting the constant to jiffies with msecs_to_jiffies()
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
We already know status is negative because of the earlier check so there
is no need to check again.
Autogain algorithm is very simple, if average luminance is low - increase gain,
if it's high - decrease gain. Gain granularity is low enough for this algo to
stabilize quickly.
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
This cam seems to return different values on long commands, so make status check
in sn9c2028_long_command() more tolerant. Anyway, read value isn't used anywhere
later.
drivers/media/usb/gspca/xirlink_cit.c:1776 cit_start_model2() info: ignoring unreachable code.
drivers/media/usb/gspca/xirlink_cit.c:1858 cit_start_model2() info: ignoring unreachable code.
drivers/media/usb/gspca/xirlink_cit.c:1910 cit_start_model2() info: ignoring unreachable code.
