commit c0f71bbb810237a38734607ca4599632f7f5d47f upstream.
Here, hdpvr_register_videodev() is responsible for setup and
register a video device. Also defining and initializing a worker.
hdpvr_register_videodev() is calling by hdpvr_probe at last.
So no need to flush any work here.
Unregister v4l2, free buffers and memory. If hdpvr_probe() will fail.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Tested-by: Andrey Konovalov <andreyknvl@google.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
usb_device_id are not supposed to change at runtime. All functions
working with usb_device_id provided by <linux/usb.h> work with
const usb_device_id. So mark the non-const structs as const.
'drivers/media/usb/b2c2/flexcop-usb.c' Fix checkpatch.pl error:
ERROR: space prohibited before open square bracket '['.
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Due to the 80-cols restrictions, and latter due to checkpatch
warnings, several strings were broken into multiple lines. This
is not considered a good practice anymore, as it makes harder
to grep for strings at the source code.
As we're right now fixing other drivers due to KERN_CONT, we need
to be able to identify what printk strings don't end with a "\n".
It is a way easier to detect those if we don't break long lines.
So, join those continuation lines.
The patch was generated via the script below, and manually
adjusted if needed.
</script>
use Text::Tabs;
while (<>) {
if ($next ne "") {
$c=$_;
if ($c =~ /^\s+\"(.*)/) {
$c2=$1;
$next =~ s/\"\n$//;
$n = expand($next);
$funpos = index($n, '(');
$pos = index($c2, '",');
if ($funpos && $pos > 0) {
$s1 = substr $c2, 0, $pos + 2;
$s2 = ' ' x ($funpos + 1) . substr $c2, $pos + 2;
$s2 =~ s/^\s+//;
$s2 = ' ' x ($funpos + 1) . $s2 if ($s2 ne "");
print unexpand("$next$s1\n");
print unexpand("$s2\n") if ($s2 ne "");
} else {
print "$next$c2\n";
$next="";
next;
} else {
print $next;
$next="";
} else {
if (m/\"$/) {
if (!m/\\n\"$/) {
$next=$_;
next;
print $_;
</script>
The workqueue "workqueue" is involved in transmitting hdpvr buffers.
It has a single work item(&dev->worker) and hence doesn't require
ordering. Also, it is not being used on a memory reclaim path. Hence,
the singlethreaded workqueue has been replaced with the use of system_wq.
System workqueues have been able to handle high level of concurrency
for a long time now and hence it's not required to have a singlethreaded
workqueue just to gain concurrency. Unlike a dedicated per-cpu workqueue
created with create_singlethread_workqueue(), system_wq allows multiple
work items to overlap executions even on the same CPU; however, a
per-cpu workqueue doesn't have any CPU locality or global ordering
guarantee unless the target CPU is explicitly specified and thus the
increase of local concurrency shouldn't make any difference.
Work item has been flushed in hdpvr_device_release() to ensure
that there are no pending tasks while disconnecting the driver.
Signed-off-by: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Acked-by: Tejun Heo <tj@kernel.org>
The i2c client pointer is only used when CONFIG_I2C is set, and
otherwise produces a compile-time warning:
drivers/media/usb/hdpvr/hdpvr-core.c: In function 'hdpvr_probe':
drivers/media/usb/hdpvr/hdpvr-core.c:276:21: error: unused variable 'client' [-Werror=unused-variable]
This uses the same #ifdef to hide the variable when the code using
it is hidden.
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Embed the video_device struct to simplify the error handling and in
order to (eventually) get rid of video_device_alloc/release.
There is no need to use hex_dump_to_buffer() since we have a kernel helper to
dump up to 64 bytes just via printk().
cppcheck reported memory leak in device_authorizatio()
within hdpvr-core.c.
When the debug option is specified and the code jump to
"unlock:" label, print_buf was not freed.
Confirm the module succesfully compiled without error.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
drivers/media/usb/hdpvr/hdpvr-core.c:110:54: warning: incorrect type in argument 1 (different base types)
drivers/media/usb/hdpvr/hdpvr-core.c:112:39: warning: invalid assignment: +=
drivers/media/usb/hdpvr/hdpvr-core.c:304:26: warning: Using plain integer as NULL pointer
free_buff_list and rec_buff_list are initialized in the middle of hdpvr_probe(),
but if something bad happens before that, error handling code calls hdpvr_delete(),
which contains iteration over the lists (via hdpvr_free_buffers()).
The patch moves the lists initialization to the beginning and by the way fixes
goto label in error handling of registering videodev.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Cc: stable@vger.kernel.org
hdpvr_device_init()
Signed-off-by: Leonid Kegulskiy <leo@lumanate.com>
This is the latest firmware version and - it seems - the most reliable.
Video nodes can be used at once after registration, so make sure the full
initialization is done before registering them.
This patch fixes the print_buf leaking.
Signed-off-by: Syam Sidhardhan <s.syam@samsung.com>
replace:
#if defined(CONFIG_I2C) || \
defined(CONFIG_I2C_MODULE)
with:
#if IS_ENABLED(CONFIG_I2C)
This change was made for: CONFIG_I2C
Reported-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
if@p1 (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret@p1 = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
// </smpl>
Rename all USB drivers with their own directory under
drivers/media/video into drivers/media/usb and update the
building system.
