commit ee0fe833d96793853335844b6d99fb76bd12cbeb upstream.
This code copies actual_length-128 bytes from the header, which will
underflow if the received buffer is too small.
Signed-off-by: Alyssa Milburn <amilburn@zall.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
kmalloc will print enough information in case of failure.
Signed-off-by: Wolfram Sang <wsa-dev@sang-engineering.com>
Some USB drivers have a logic at the VB buffer handling like:
if (in_interrupt())
BUG();
Use, instead:
BUG_ON(in_interrupt());
Btw, this logic looks weird on my eyes. We should convert them
to use VB2, in order to avoid those crappy things.
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
The debug field in struct video_device is for internal use only and
drivers should mix that with their own debug module options.
It is handled by the V4L2 core and users can set it using
/sys/class/video4linux/<devX>/debug.
It has been deprecated for some time now, so it is time to remove it
completely from the drivers.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com>
The v4l2_pix_format structure has no reserved field. It is embedded in
the v4l2_framebuffer structure which has no reserved fields either, and
in the v4l2_format structure which has reserved fields that were not
previously required to be zeroed out by applications.
To allow extending v4l2_pix_format, inline it in the v4l2_framebuffer
structure, and use the priv field as a magic value to indicate that the
application has set all v4l2_pix_format extended fields and zeroed all
reserved fields following the v4l2_pix_format field in the v4l2_format
structure.
The availability of this API extension is reported to userspace through
the new V4L2_CAP_EXT_PIX_FORMAT capability flag. Just checking that the
priv field is still set to the magic value at [GS]_FMT return wouldn't
be enough, as older kernels don't zero the priv field on return.
To simplify the internal API towards drivers zero the extended fields
and set the priv field to the magic value for applications not aware of
the extensions.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Since all the drivers that use `struct v4l2_fh' use the core
priority checking, the setting of the flag in the drivers can
be removed.
Signed-off-by: Ramakrishnan Muthukrishnan <ramakrmu@cisco.com>
Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com>
Convert drivers using wall clock time (CLOCK_REALTIME) to timestamp from the
monotonic timer (CLOCK_MONOTONIC).
Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi>
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
drivers/media/usb/zr364xx/zr364xx.c:1010:2: warning: comparison of unsigned expression < 0 is always false [-Wtype-limits]
Cc: Antoine Jacquet <royale@zerezo.com>
Move the 3 remaining usb drivers to their proper space.
