This is the Tegra V4L2 camera host driver, for Tegra2/Tegra3's VI/CSI
controller.
Signed-off-by: Andrew Chew <achew@nvidia.com>
Change-Id: If2d9eefe53c2119c1a6ae518216e1a3c3ed216ef
Reviewed-on: http://git-master/r/145346
GVS: Gerrit_Virtual_Submit
Reviewed-by: Allen Martin <amartin@nvidia.com>
This is based off of videobuf2-dma-contig, except we use Tegra's nvmap for the
buffer allocations.
Change-Id: I15e689c33ee7b4fc0aade794c78701c82483df3f
Reviewed-on: http://git-master/r/145345
Change-Id: Ib3b69ffc5ac3e07c9cc44cc49e9142088eec477e
The tegra_camera device includes all clock and regulator
functionality needed to support camera on tegra.
Change-Id: I281f1cb5f360276af832309e35dbe17c98b62bb3
Signed-off-by: Dima Zavin <dima@android.com>
Rebase-Id: Rb20ede91ac064bfd448ce0a76ba1c08c84b1957a
Add driver for the JPEG codec IP block available in Samsung Exynos SoC series.
The driver is implemented as a V4L2 mem-to-mem device. It exposes two video
nodes to user space, one for the encoding part, and one for the decoding part.
Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com>
Reviewed-by: Sakari Ailus <sakari.ailus@iki.fi>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Reviewed-by: Tomasz Stanislawski <t.stanislaws@samsung.com>
This patch adds the driver for the as3645a LED flash controller. This
controller supports a high power led in flash and torch modes and an
indicator light, sometimes also called privacy light.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Nayden Kanchev <nkanchev@mm-sol.com>
Signed-off-by: Tuukka Toivonen <tuukkat76@gmail.com>
Signed-off-by: Antti Koskipaa <antti.koskipaa@gmail.com>
Signed-off-by: Stanimir Varbanov <svarbanov@mm-sol.com>
Signed-off-by: Vimarsh Zutshi <vimarsh.zutshi@gmail.com>
Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi>
Signed-off-by: Ivan T. Ivanov <iivanov@mm-sol.com>
Signed-off-by: Mika Westerberg <ext-mika.1.westerberg@nokia.com>
Signed-off-by: David Cohen <dacohen@gmail.com>
G2D is a 2D graphics accelerator engine present in the s5p family
of Samsung SoCs. It is capable of bitblt and raster operations on
images having dimensions of up to 8000x8000.
Signed-off-by: Kamil Debski <k.debski@samsung.com>
This driver exposes preview mode operation of the S5K6AAFX sensor with
embedded SoC ISP. The native capture (snapshot) operation mode is not
supported.
Following controls are available:
manual/auto exposure and gain, power line frequency (anti-flicker),
saturation, sharpness, brightness, contrast, white balance temperature,
color effects, horizontal/vertical image flip, frame interval,
auto white balance.
RGB component gains are currently exposed through private controls.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
This driver had the major issues already fixed. Move it out
of staging.
The serious bugs got fixed already.
The MT9T001 is a parallel 3MP sensor from Aptina (formerly Micron)
controlled through I2C.
The driver creates a V4L2 subdevice. It currently supports binning and
cropping, and the gain, exposure, test pattern and black level controls.
The MT9P031 is a parallel 12-bit 5MP sensor from Aptina (formerly
Micron) controlled through I2C.
The driver creates a V4L2 subdevice. It currently supports skipping,
cropping, automatic binning, and gain, exposure, h/v flip and test
pattern controls.
Signed-off-by: Javier Martin <javier.martin@vista-silicon.com>
Usage of these flags has been deprecated for nearly 4 years by:
commit f77bf01425b11947eeb3b5b54685212c302741b8
Author: Sam Ravnborg <sam@neptun.(none)>
Date: Mon Oct 15 22:25:06 2007 +0200
kbuild: introduce ccflags-y, asflags-y and ldflags-y
Moreover, these flags (at least EXTRA_CFLAGS) have been documented for command
line use. By default, gmake(1) do not override command line setting, so this is
likely to result in build failure or unexpected behavior.
Replace their usage by Kbuild's `{as,cc,ld}flags-y'.
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: linux-media@vger.kernel.org
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
This is an initial driver release for the Omnivision 5642 CMOS sensor.
Signed-off-by: Bastian Hecht <hechtb@gmail.com>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Add drivers for HDMI outputs on Samsung platforms from S5P family.
Drivers are using:
- v4l2 framework
- runtime PM
Signed-off-by: Tomasz Stanislawski <t.stanislaws@samsung.com>
Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com>
Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl>
Multi Format Codec 5.1 is a hardware video coding acceleration
module found in the S5PV210 and Exynos4 Samsung SoCs. It is
capable of handling a range of video codecs and this driver
provides a V4L2 interface for video decoding and encoding.
Cc: Jeongtae Park <jtp.park@samsung.com>
This patch adds the driver for the adp1653 LED flash controller. This
The adp1653 is used on the Nokia N900.
This patch is to enable Atmel Image Sensor Interface (ISI) driver support.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Now we have a camera working over the marvell cam controller core. It
works like the cafe driver and has all the same limitations, contiguous DMA
only being one of them. But it's a start.
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
This driver will soon become a family of drivers, so let's give it its own
place to live. This move requires putting ov7670.h into include/media, but
there are no code changes.
Cc: Daniel Drake <dsd@laptop.org>
Add I2C/V4L2 subdev driver for M-5MOLS integrated image signal processor
with 8 Mega Pixel sensor.
Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com>
s5p-fimc now also implements a camera capture video node so move
it under the "Video capture devices" Kconfig menu. Also update
the entry to reflect the driver's coverage of EXYNOS4 SoCs and
separate the Makefile entry from the soc-camera drivers set.
The MT9V032 is a parallel wide VGA sensor from Aptina (formerly Micron)
cropping, and the gain, auto gain, exposure, auto exposure and test
pattern controls.
Signed-off-by: Detlev Casanova <detlev.casanova@gmail.com>
Add the OMAP3 ISP driver to the kernel build system.
Acked-by: Hans Verkuil <hverkuil@xs4all.nl>
Create a device node named subdevX for every registered subdev.
As the device node is registered before the subdev core::s_config
function is called, return -EGAIN on open until initialization
completes.
This soc_camera driver is for Omnivision's OV9740 sensor. This initial
submission provides support for YUV422 output at 1280x720 (720p), which is
the sensor's native resolution. 640x480 (VGA) is also supported, with
cropping and scaling performed by the sensor's ISP.
This driver is heavily based off of the existing OV9640 driver.
Add I2C/V4L2 subdev driver for Siliconfile NOON010PC30 CIF camera.
The driver implements basic functionality, i.e. CIF/QCIF/QQCIF
resolution and color format selection, automatic/manual color
balance control. Other functions like cropping, rotation/flip,
exposure etc. can be easily implemented if needed.
Add an implementation of DMA scatter/gather allocator and handling
routines for videobuf2.
For mmap operation mode it is implemented on top of
alloc_page + sg_set_page/_free_page.
For userptr operation mode it is implemented on top of
get_user_pages + sg_set_page/put_page.
CC: Pawel Osciak <pawel@osciak.com>
Add an implementation of DMA coherent memory allocator and handling
routines for videobuf2, implemented on top of dma_alloc_coherent() call.
Signed-off-by: Pawel Osciak <p.osciak@samsung.com>
Add an implementation of contiguous virtual memory allocator and handling
routines for videobuf2, implemented on top of vmalloc()/vfree() calls.
Add generic memory handling routines for userspace pointer handling,
contiguous memory verification and mapping.
Videobuf2 is a Video for Linux 2 API-compatible driver framework for
multimedia devices. It acts as an intermediate layer between userspace
applications and device drivers. It also provides low-level, modular
memory management functions for drivers.
Videobuf2 eases driver development, reduces drivers' code size and aids in
proper and consistent implementation of V4L2 API in drivers.
Videobuf2 memory management backend is fully modular. This allows custom
memory management routines for devices and platforms with non-standard
memory management requirements to be plugged in, without changing the
high-level buffer management functions and API.
The framework provides:
- implementations of streaming I/O V4L2 ioctls and file operations
- high-level video buffer, video queue and state management functions
- video buffer memory allocation and management
In commit 411674fd189abe5910ea4caf08b7eac5c4a4d967 the tda9875 support was
added to tvaudio. This means that tda9875 is no longer used since mid-2009.
If there are out-of-tree users of this driver, then they can switch to tvaudio
instead.
The original commit message read as follows:
This change allows bttv to use tvaudio for this device. Since this device
has the same i2c address as the tda9874 we need to support both in the same
tvaudio driver. This makes it possible for tvaudio to detect which chip is
used. Originally the tda9875 was only available in the dedicated tda9875
driver, but that makes life very hard for bttv since loading tvaudio might
misdetect a tda9875 as a tda9874.
So there were good reasons for moving the tda9875 code into tvaudio.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Alberto Panizzo <maramaopercheseimorto@gmail.com>
dabusb driver were conceived as an experimental driver for a test
device. The driver never supported any shipped product, and, while
there were some updates on it in 2003, for an ancient product,
those changes were never submitted upstream.
Also, there's no DocBook for its API, nor any upstream discussion.
So, better to remove it, on .39. If later needed, we may rescue it
from git logs. For now, let's move it to staging.
Acked-by: Deti Fliegl <deti@fliegl.de>
Cc: Deti Fliegl <deti@fliegl.de>
The se401 driver is deprecated and is moved to staging. If no one will
convert this driver to V4L2, then it will be removed in 2.6.39.
Move usbvideo to staging and mark it deprecated.
This patch adds the timberdale video-in driver.
The video IP of timberdale delivers the video data via DMA.
The driver uses the DMA api to handle DMA transfers, and make use
of the V4L2 video buffers to handle buffers against user space.
If available the driver uses an encoder to get/set the video standard
Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com>
Add a driver for the video capture port on VIA integrated chipsets. This
version has a remaining OLPCism or two and expects to be talking to an
ov7670; those can be improved as the need arises.
This work was supported by the One Laptop Per Child project.
Thanks to Laurent Pinchart for a number of useful comments.
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Add an I2C/v4l2-subdev driver for Siliconfile SR030PC30 VGA
camera sensor with Image Signal Processor. SR030PC30 is
the low resolution camera sensor on Samsung Aquila boards.
This patch adds an initial driver for the IMXъ74 image sensor from Sony.
Lacking documentation, only very basic functionality in one specific image
format has been implemented and tested.
This patch provides a V4L2 SoC Camera driver for OV6650 camera sensor, found
on OMAP1 SoC based Amstrad Delta videophone.
Since I have no experience with camera sensors, and the sensor documentation I
was able to find was not very comprehensive, I left most settings at their
default (reset) values, except for:
- those required for proper mediabus parameters and picture geometry and
format setup,
- those used by controls.
Resulting picture quality may be far from perfect, but better than nothing.
In order to be able to get / set the sensor frame rate from userspace, I
decided to provide two not yet SoC camera supported operations, g_parm and
s_parm. These can be used after applying patch 4/6 from this series,
"SoC Camera: add support for g_parm / s_parm operations".
Created and tested against linux-2.6.36-rc5 on Amstrad Delta.
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
This is a V4L2 driver for TI OMAP1 SoC camera interface.
Both videobuf-dma versions are supported, contig and sg, selectable with a
module option. The former uses less processing power, but often fails to
allocate contignuous buffer memory. The latter is free of this problem, but
generates tens of DMA interrupts per frame. If contig memory allocation ever
fails, the driver falls back to sg automatically on next open, but still can
be switched back to contig manually. Both paths work stable for me, even
under heavy load, on my OMAP1510 based Amstrad Delta videophone, that is the
oldest, least powerfull OMAP1 implementation.
The interface generally works in pass-through mode. Since input data byte
endianess can be swapped, it provides up to two v4l2 pixel formats per each of
several soc_mbus formats that have their swapped endian counterparts.
Boards using this driver can provide it with the following platform data:
- if and what freqency clock is expected by an on-board camera sensor,
- what is the maximum pixel clock that should be accepted from the sensor,
- what is the polarity of the sensor provided pixel clock,
- if the interface GPIO line is connected to a sensor reset/powerdown input
and what is the input polarity.
The driver author seems to not worked on this driver since its conversion
from 2.2 to 2.4. Nobody is known to have a stradis hardware for testing. As
it still uses V4L1 API, BKL and probably some other old stuff, someone would
need to work on it to preserve the driver. Instead of investing time and
efforts to keep porting it to work with new API's, it seems better to just
drop the driver.
So, let's move it to drivers/staging and label it to die at 2.6.38, if nobody
cares enough to port parallel port support to gspca or to create a new driver
that uses the same gspca-cpia sub-driver.
cpia driver were re-written inside gspca driver, for USB devices. The only
functionality that were not migrated is the support for parallel port,
as:
1) the developer didn't find any hardware;
2) it doesn't seem important to keep support for a parallel port webcam,
as this is an obsolete technology;
3) the changes at gspca for it to work with parallel port would be very large;
4) this driver still uses BKL.
These old i2c teletext drivers are not supported by any hardware and cannot be
tested anymore.
Note that while the mxb board seemingly used the saa5246a driver, in reality
this teletext driver never worked.
These drivers are removed as part of the vtx feature removal, originally
scheduled for 2.6.35.
Add a new framework to handle controls which makes life for driver
developers much easier.
Note that this patch moves some of the control support that used to be in
v4l2-common.c to v4l2-ctrls.c. The tables were copied unchanged. The body
of v4l2_ctrl_query_fill() was copied to a new v4l2_ctrl_fill() function
in v4l2-ctrls.c. This new function doesn't use the v4l2_queryctrl
struct anymore, which makes it more general.
The remainder of v4l2-ctrls.c is all new. Highlights include:
- No need to implement VIDIOC_QUERYCTRL, QUERYMENU, S_CTRL, G_CTRL,
S_EXT_CTRLS, G_EXT_CTRLS or TRY_EXT_CTRLS in either bridge drivers
or subdevs. New wrapper functions are provided that can just be plugged in.
Once everything has been converted these wrapper functions can be removed as well.
- When subdevices are added their controls can be automatically merged
with the bridge driver's controls.
- Most drivers just need to implement s_ctrl to set the controls.
The framework handles the locking and tries to be as 'atomic' as possible.
- Ready for the subdev device nodes: the same mechanism applies to subdevs
and their device nodes as well. Sub-device drivers can make controls
local, preventing them from being merged with bridge drivers.
- Takes care of backwards compatibility handling of VIDIOC_S_CTRL and
VIDIOC_G_CTRL. Handling of V4L2_CID_PRIVATE_BASE is fully transparent.
CTRL_CLASS controls are automatically added.
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
This driver exports a video device node per each camera interface/
video postprocessor (FIMC) device contained in Samsung S5P SoC series.
The driver is based on v4l2-mem2mem framework.
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_2.6.35' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (243 commits)
V4L/DVB: sms: Convert IR support to use the Remote Controller core
V4L/DVB: sms: properly initialize IR phys and IR name
V4L/DVB: standardize names at rc-dib0700 tables
V4L/DVB: smsusb: enable IR port for Hauppauge WinTV MiniStick
V4L/DVB: dib0700: Fix RC protocol logic to properly handle NEC/NECx and RC-5
V4L/DVB: dib0700: properly implement IR change_protocol
V4L/DVB: dib0700: break keytable into NEC and RC-5 variants
V4L/DVB: dib0700: avoid bad repeat
V4L/DVB: Port dib0700 to rc-core
V4L/DVB: Add a keymap file with dib0700 table
V4L/DVB: dvb-usb: add support for rc-core mode
V4L/DVB: dvb-usb: prepare drivers for using rc-core
V4L/DVB: dvb-usb: get rid of struct dvb_usb_rc_key
V4L/DVB: rj54n1cb0c: fix a comment in the driver
V4L/DVB: V4L2: sh_vou: VOU does support the full PAL resolution too
V4L/DVB: V4L2: sh_mobile_camera_ceu: add support for CSI2
V4L/DVB: V4L2: soc-camera: add a MIPI CSI-2 driver for SH-Mobile platforms
V4L/DVB: V4L2: soc-camera: export soc-camera bus type for notifications
V4L/DVB: V4L2: mediabus: add 12-bit Bayer and YUV420 pixel formats
V4L/DVB: mediabus: fix ambiguous pixel code names
