Fix the following build warning:
warning: (VIDEO_AU0828) selects DVB_AU8522 which has unmet direct dependencies (MEDIA_SUPPORT && DVB_CAPTURE_DRIVERS && DVB_CORE && I2C && VIDEO_V4L2)
Fix this build error:
ERROR: "videobuf_queue_vmalloc_init" [drivers/media/video/au0828/au0828.ko] undefined!
ERROR: "videobuf_vmalloc_free" [drivers/media/video/au0828/au0828.ko] undefined!
ERROR: "videobuf_to_vmalloc" [drivers/media/video/au0828/au0828.ko] undefined!
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
There are several Kconfig items using CUSTOMIZE. Yet, most use the English
writing CUSTOMISE. This generates lots of trouble, because people sometimes type
the Kbuild item different.
Let's standardise every occurrence using the same syntax.
The changes were generated by this small shell script:
for i in `find linux -type f`; do sed s,CUSTOMIZE,CUSTOMISE,g $i >/tmp/a && mv /tmp/a $i; done
au8522 is now dependent of V4L2, as reported by Randy Dunlap
<randy.dunlap@oracle.com>:
au8522_decoder.c:(.text+0x199898): undefined reference to `v4l2_ctrl_query_fill'
au8522_decoder.c:(.text+0x1998b3): undefined reference to `v4l2_ctrl_query_fill'
au8522_decoder.c:(.text+0x199944): undefined reference to `v4l2_device_unregister_subdev'
au8522_decoder.c:(.text+0x19997c): undefined reference to `v4l2_chip_ident_i2c_client'
au8522_decoder.c:(.text+0x199f1e): undefined reference to `v4l2_i2c_subdev_init'
Cc: Devin Heitmueller <devin.heitmueller@gmail.com>
There are still more places where DVB_FE_CUSTOMIZE is used, instead of
DVB_FE_CUSTOMISE.
The name of the option is DVB_FE_CUSTOMISE. However, on a few places, a wrong
name were used, due to a typo (DVB_FE_CUSTOMIZE).
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Fix undefined references in au0828:
depends on USB and select VIDEO_TVEEPROM
x86.git testing found the following build failure in v2.6.26-rc1:
MODPOST 424 modules
ERROR: "tveeprom_hauppauge_analog" [drivers/media/video/au0828/au0828.ko] undefined!
ERROR: "tveeprom_read" [drivers/media/video/au0828/au0828.ko] undefined!
with this config:
http://redhat.com/~mingo/misc/config-Sat_May__3_22_28_58_CEST_2008.bad
this patch does what other video drivers do to utilize the
VIDEO_TVEEPROM functionality (and this resolves the build problem) - but
i have not checked it on real hardware and i have not checked whether
the fix is complete.
selections, so some items might still be missing - just not triggered
with this specific config.
namespace for all of them.
Encountered this error when testing.
Kernel: arch/x86/boot/bzImage is ready (#76)
MODPOST 813 modules
ERROR: "dvb_dmx_init" [drivers/media/video/au0828/au0828.ko] undefined!
ERROR: "dvb_unregister_adapter" [drivers/media/video/au0828/au0828.ko] undefined!
ERROR: "dvb_register_frontend" [drivers/media/video/au0828/au0828.ko] undefined!
ERROR: "dvb_unregister_frontend" [drivers/media/video/au0828/au0828.ko] undefined!
ERROR: "dvb_net_release" [drivers/media/video/au0828/au0828.ko] undefined!
ERROR: "dvb_frontend_detach" [drivers/media/video/au0828/au0828.ko] undefined!
ERROR: "dvb_dmxdev_release" [drivers/media/video/au0828/au0828.ko] undefined!
ERROR: "dvb_net_init" [drivers/media/video/au0828/au0828.ko] undefined!
ERROR: "dvb_dmx_release" [drivers/media/video/au0828/au0828.ko] undefined!
ERROR: "dvb_dmx_swfilter_packets" [drivers/media/video/au0828/au0828.ko] undefined!
ERROR: "dvb_register_adapter" [drivers/media/video/au0828/au0828.ko] undefined!
ERROR: "dvb_dmxdev_init" [drivers/media/video/au0828/au0828.ko] undefined!
WARNING: modpost: Found 9 section mismatch(es).
To see full details build your kernel with:
'make CONFIG_DEBUG_SECTION_MISMATCH=y'
make[1]: *** [__modpost] Error 1
make: *** [modules] Error 2
Signed-off-by: Brandon Philips <bphilips@suse.de>
au0828: Typo
Signed-off-by: Steven Toth <stoth@hauppauge.com>
DVB_TUNER_XC5000
VIDEO_AU0828 should select DVB_AU8522 and DVB_TUNER_XC5000 if !DVB_FE_CUSTOMIZE
Including support for the AU0828 USB Bridge.
Including support for the AU8522 ATSC/QAM Demodulator.
