The initial version of this patch (commit
d5976931639176bb6777755d96b9f8d959f79e9e) had some issues:
* It didn't correctly calculate the size of the YUV buffer for 4:2:2,
resulting in capture sometimes being offset by 1/3rd of a picture.
* There were a lot of variables duplicating information the driver
already knew, which have been removed.
* There was an in-kernel format conversion - libv4l can do this one,
and is the right place to do format conversions anyway.
* Some magic numbers weren't properly explained.
Fix all these issues, leaving just the move from videobuf to videobuf2
to do.
Signed-off-by: Simon Farnsworth <simon.farnsworth@onelan.co.uk>
Acked-by: Andy Walls <awalls@md.metrocast.net>
Add support for mmap method streaming of raw YUV video on cx18-based
hardware, in addition to the existing support for read() streaming of
raw YUV and MPEG-2 encoded video.
[simon.farnsworth@onelan.co.uk: I forward-ported this from Steven's original work,
done under contract to ONELAN. The original code is at
http://www.kernellabs.com/hg/~stoth/cx18-videobuf]
Signed-off-by: Steven Toth <stoth@kernellabs.com>
tuners
A previous changes which added the newer model HVR-1600's and DTV support for
them, neglected to add RF analog TV for them. Fix RF analog TV for the newer
HVR-1600's which have a worldwide analog tuner assembly with a TDA18271 tuner
and TDA8295 demodulator.
Thanks go to Jeff Campbell and Mike Bradley for reproting the problem, and
also to Mike Bradley for doing a lot of the legwork to figure out the tuner
reset GPIO line, the demodulator I2C address, and that the GPIOs have to be
reinitialized after a cardtype switch.
Reported-by: Jeff Campbell <jac1dlists@gmail.com>
Tested-by: Andy Walls <awalls@md.metrocast.net>
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
The Remote Controller subsystem is meant to be used not only by Infra Red
but also for similar types of Remote Controllers. The core is not specific
to Infra Red. As such, rename:
- ir-core.h to rc-core.h
- IR_CORE to RC_CORE
- namespace inside rc-core.c/rc-core.h
To be consistent with the other changes.
No functional change on this patch.
cx88 only depends on VIDEO_IR because it needs ir_extract_bits().
Move that function to ir-core.h and make it inline.
Lots of drivers had dependencies on VIDEO_IR when they really
wanted IR_CORE.
The only remaining drivers to depend on VIDEO_IR are bt8xx and
saa7134 (ir_rc5_timer_end is the only function exported by
ir-functions).
Rename VIDEO_IR -> IR_LEGACY to give a hint to anyone writing or
converting drivers to IR_CORE that they do not want a dependency
on IR_LEGACY.
Signed-off-by: David Härdeman <david@hardeman.nu>
Acked-by: Jarod Wilson <jarod@redhat.com>
warning: (VIDEO_BT848 && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_DEV && PCI && I2C && VIDEO_V4L2 && INPUT || VIDEO_SAA7134 && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && VIDEO_DEV && PCI && I2C && INPUT || VIDEO_CX88 && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && VIDEO_DEV && PCI && I2C && INPUT || VIDEO_IVTV && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && PCI && I2C && INPUT || VIDEO_CX18 && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && DVB_CORE && PCI && I2C && EXPERIMENTAL && INPUT || VIDEO_EM28XX && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && V4L_USB_DRIVERS && USB && VIDEO_DEV && I2C && INPUT || VIDEO_TLG2300 && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && V4L_USB_DRIVERS && USB && VIDEO_DEV && I2C && INPUT && SND && DVB_CORE || VIDEO_CX231XX && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && V4L_USB_DRIVERS && USB && VIDEO_DEV && I2C && INPUT || DVB_BUDGET_CI && MEDIA_SUPPORT && DVB_CAPTURE_DRIVERS && DVB_CORE && DVB_BUDGET_CORE && I2C && INPUT || DVB_DM1105 && MEDIA_SUPPORT && DVB_CAPTURE_DRIVERS && DVB_CORE && PCI && I2C && INPUT || VIDEO_GO7007 && STAGING && !STAGING_EXCLUDE_BUILD && VIDEO_DEV && PCI && I2C && INPUT && SND || VIDEO_CX25821 && STAGING && !STAGING_EXCLUDE_BUILD && DVB_CORE && VIDEO_DEV && PCI && I2C && INPUT) selects VIDEO_IR which has unmet direct dependencies (IR_CORE)
Add cx18-alsa to the Makefile and Kconfig
This work was sponsored by ONELAN Limited.
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
There are several Kconfig items using CUSTOMIZE. Yet, most use the English
writing CUSTOMISE. This generates lots of trouble, because people sometimes type
the Kbuild item different.
Let's standardise every occurrence using the same syntax.
The changes were generated by this small shell script:
for i in `find linux -type f`; do sed s,CUSTOMIZE,CUSTOMISE,g $i >/tmp/a && mv /tmp/a $i; done
When the tuner modules were moved to common/tuners, a separate customize
option were added for tuners. However, the automatic selection of the
tuners were still using the older option.
This causes that the automatic selection to fail, if DVB_FE_CUSTOMISE is
selected. Also, since those tuners are now under MEDIA_TUNER_CUSTOMIZE
menu, if you unset MEDIA_TUNER_CUSTOMIZE, you can't manually select the
tuners.
This patch fixes this error by replacing DVB_FE_CUSTOMISE by
MEDIA_TUNER_CUSTOMIZE on all places were a tuner is selected.
The patch were generated by this small script:
for i in `find drivers/media -name Kconfig`; do
cat $i|perl -ne 's/(MEDIA_TUNER.*)DVB_FE_CUSTOMISE/\1MEDIA_TUNER_CUSTOMIZE/; print $_' >a
mv a $i
done
Also, manually reordered the tuner entries.
After commit d9b19199e4894089456aaad295023263b5225c1a
(always enable FW_LOADER unless EMBEDDED=y) we can remove
the FW_LOADER select's and corresponding dependencies
on HOTPLUG.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
The automatic Kconfig selection for tuners and frontends should be
conditional, based on !DVB_FE_CUSTOMISE.
This patch corrects the selection for VIDEO_CX18 on
MEDIA_TUNER_MXL5005S and DVB_S5H1409
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Adding cx18 Support
Signed-off-by: Steven Toth <stoth@hauppauge.com>
Since:
1) FW_LOADER is defined as:
config FW_LOADER
tristate "Userspace firmware loading support"
depends on HOTPLUG
2) several V4L/DVB driver just selects it;
3) select is not smart enough to auto-select HOTPLUG, if select FW_LOADER.
So, All drivers that select FW_LOADER should also depend on HOTPLUG.
An easier solution (for the end-user perspective) would be to "select HOTPLUG".
However, live is not simple. This would cause recursive dependency issues like
this one:
drivers/usb/Kconfig:62:error: found recursive dependency: USB -> USB_OHCI_HCD
-> I2C -> MEDIA_TUNER -> MEDIA_TUNER_XC2028 -> HOTPLUG -> PCCARD -> PCMCIA ->
USB_ARCH_HAS_HCD -> MOUSE_APPLETOUCH -> USB
VIDEO_TUNER is responsible for compilation of tuners.ko module. This were the
previous behaviour before the creation of MEDIA_TUNER.
Before this patch, tuner.ko were created even for drivers that don't need a
tuner (like webcam drivers).
Some Kconfig names were changed. This patch reapplies the rename script,
fixing for those drivers merged after the patch that renamed those
items.
Many thanks to Steve Toth from Hauppauge and Nattu Dakshinamurthy from
Conexant for their support. I am in particular thankful to Hauppauge
since without their help this driver would not exist. It should also
be noted that Steve did the work to get the DVB part up and running.
Thank you!
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: G. Andrew Walls <awalls@radix.net>
