path: root/drivers/media/video/cx18/cx18-controls.c
2011-03-21[media] cx18: Use the control frameworkHans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-30[media] v4l2-ctrls: use const char * const * for the menu arraysHans Verkuil
This prevents checkpatch warnings generated when defining 'static const char *foo[]' arrays. It makes sense to use const char * const * anyway since the pointers in the array are indeed const. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-06-01V4L/DVB: cx18: remove old g/s_fmt from the cx18_av subdevHans Verkuil
cx18 has now switched over completely to the new mediabus subdev ops. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-19V4L/DVB: v4l2-common: simplify prio utility functionsHans Verkuil
v4l2_prio_init/open/close returned an int when in fact they would always return 0. Make these void functions. v4l2_prio_close and v4l2_prio_check pass an enum v4l2_priority as a pointer for no good reason. Replace with a normal enum v4l2_priority argument. These changes will simplify the work of moving priority handling into the v4l core. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-08-13V4L/DVB (12338): cx18: Read buffer overflowAndy Walls
This mistakenly tested against sizeof(freqs) instead of the array size. Due to the mask the only illegal value possible was 3. Reported-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-23V4L/DVB (12104): ivtv/cx18: fix regression: class controls are no longer seenHans Verkuil
A previous change (v4l2-common: remove v4l2_ctrl_query_fill_std) broke the handling of class controls in VIDIOC_QUERYCTRL. The MPEG class control was broken for all drivers that use the cx2341x module and the USER class control was broken for ivtv and cx18. This change adds back proper class control support. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11622): cx18: Allow IVTV format VBI insertion in MPEG-2 SVCD and ↵Andy Walls
DVD streams Both the MPEG-2 SVCD stream format and the MPEG-2 DVD stream format should use an MPEG-2 PS container. This makes it safe to stuff IVTV Private Stream 1 VBI packets in these stream types using the existing cx18 driver routines. Reported-by: Helen Buus <mythtv@hbuus.com> Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10856): cx18: Add interlock so sliced VBI insertion only happens ↵Andy Walls
for an MPEG PS The cx18 private packet insertion code only expects to operate on an MPEG PS when inserting private packets of sliced VBI data. This patch keeps the cx18 driver from corrupting the MPEG TS or other non-PS stream types, in case the user enables sliced VBI insertion for these MPEG stream types. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10759): cx18: Convert GPIO connected functions to act as ↵Andy Walls
v4l2_subdevices Convert GPIO line functions, such a audio routing and device resets, to v4l2_subdevices. This essentially completes the conversion of cx18 to the v4l2_device/v4l2_subdevice framework. No regression testing has taken place as of yet. Also an ivtv legacy bug with GPIO mux routing and going to/from radio mode was commented, but not fixed. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10758): cx18: Convert I2C devices to v4l2_subdevicesAndy Walls
This is a major perturbation to cx18 I2C device handling to convert it to the v4l2_device/subdeivce framework. This change breaks GPIO audio multiplexer control for the time being. It will be fixed in a coming change. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10757): cx18, v4l2-chip-ident: Finish conversion of AV decoder core ↵Andy Walls
to v4l2_subdev Added a new chip identifer to v4l2-chip-ident for the integrated A/V broadcast decoder core internal to the CX23418. Completed separation and encapsulation of the A/V decoder core interface as a v4l2_subdevice. The cx18 driver now compiles and links again. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10544): v4l2-common: add comments warning that about the sort orderHans Verkuil
Control arrays as are used with v4l2_ctrl_next must be sorted from low to high. Add a comment at the top of all such arrays to warn about this. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10439): cx18: Clean-up and enable sliced VBI handlingAndy Walls
Removed legacy ivtv state variables, added comments, and cleaned up sliced VBI related code. Enabled sliced VBI. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9894): cx18: Use a known open task handle when setting stream ↵Andy Walls
CX2341x parameters cx18: Use a known open task handle when setting stream CX2341x parameters Sometimes, we might only have VBI or YUV stream open instead of an MPEG stream. Let's make sure we use a valid task handle to perform the CX2341x control settings. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-07-20V4L/DVB (8113): ivtv/cx18: remove s/g_ctrl, now all controls are handled ↵Hans Verkuil
through s/g_ext_ctrl videodev converts old-style controls to an extended control so the ivtv and cx18 drivers no longer have to handle both. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (8105): cx2341x: add TS capabilityHans Verkuil
The cx18 can support transport streams with newer firmwares. Add a TS capability to the generic cx2341x module. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (8104): cx18/ivtv: ioctl debugging improvementsHans Verkuil
Completely rely on the video_ioctl2 debugging facilities rather than doing it ourselves. Fill in some missing fields in ivtv with VIDIOC_G_FBUF. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (8082): cx18: convert to video_ioctl2()Andy Walls
cx18: convert driver to use video_ioctl2(). Pushed down ioctl debug messages and priority checks as well. Still left serialization lock in place for now. #if 0'ed out sliced vbi ioctl code for now. Patch heavily based on similar changes made to ivtv by Hans Verkuil. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-06-05V4L/DVB (7931): cx18: allow for simultaneous digital and analog captureHans Verkuil
The HVR-1600 can do both analog and digital capture at the same time. Due to a driver bug -EBUSY would be returned when attempting to setup an analog capture while a digital capture was already in progress. Separate the two internally. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29V4L-DVB(7789a): cx18: fix symbol conflict with ivtv driverMauro Carvalho Chehab
LD drivers/media/video/built-in.o drivers/media/video/cx18/built-in.o: In function `get_service_set': /home/v4l/tokernel/git/drivers/media/video/cx18/cx18-ioctl.c:118: multiple definition of `get_service_set' drivers/media/video/ivtv/built-in.o:/home/v4l/tokernel/git/drivers/media/video/ivtv/ivtv-ioctl.c:119: first defined here drivers/media/video/cx18/built-in.o: In function `expand_service_set': /home/v4l/tokernel/git/drivers/media/video/cx18/cx18-ioctl.c:92: multiple definition of `expand_service_set' drivers/media/video/ivtv/built-in.o:/home/v4l/tokernel/git/drivers/media/video/ivtv/ivtv-ioctl.c:92: first defined here drivers/media/video/cx18/built-in.o: In function `service2vbi': /home/v4l/tokernel/git/drivers/media/video/cx18/cx18-ioctl.c:44: multiple definition of `service2vbi' drivers/media/video/ivtv/built-in.o:/home/v4l/tokernel/git/drivers/media/video/ivtv/ivtv-ioctl.c:42: first defined here make[2]: ** [drivers/media/video/built-in.o] Erro 1 make[1]: ** [drivers/media/video] Erro 2 make: ** [drivers/media/] Erro 2 Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29V4L/DVB (7786): cx18: new driver for the Conexant CX23418 MPEG encoder chipHans Verkuil
Many thanks to Steve Toth from Hauppauge and Nattu Dakshinamurthy from Conexant for their support. I am in particular thankful to Hauppauge since without their help this driver would not exist. It should also be noted that Steve did the work to get the DVB part up and running. Thank you! Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: G. Andrew Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
