A trivial change to update my email address from my dead awalls@radix.net
address to my current awalls@md.metrocast.net address.
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
drivers/media/video/cx18/cx18-driver.c:252: warning: ‘request_modules’ used but never defined
Codingstyle fixes, some introduced as a result of the ALSA work, some
pre-existing. This patch is a whitespace change only.
This work was sponsored by ONELAN Limited.
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
Restructure the way the module gets loaded so that it gets loaded automatically
when cx18 is loaded, and make it work properly if there are multiple cards
present (since the old code would only take one opportunity to connect to cx18
instances when the module first loaded).
Update the module options related to INDEX stream buffer allocation. A single
CX2341[5678] index entry is only 24 bytes. Large buffers for the IDX stream
will prevent the CX23418 from transferring index data over at all. Buffers
of around 1.5 kB or 64 index entries seem to be just fine. We'll default to
63 buffers/MDLs as that is the firmware limit per stream and IDX stream buffers
are not high rate. There is no reason on earth to allocate the previous 1 MB
default of buffer space for the IDX stream.
This is in anticipation of implementing the G_ENC_INDEX ioctl() in the cx18
driver.
Signed-off-by: Andy Walls <awalls@radix.net>
The cx18 av core implemented an init call for no good reason. It's now
turned into an internal function.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Reviewed-by: Andy Walls <awalls@radix.net>
worth of VBI data
per transfer
Fix YUV capture such that the encoder will pass one frame per transfer. This
will allow the application to maintain frame alignment when a transfer from
the encoder is missed due to high system latency in service the CX23418 IRQ.
Also force YUV buffer sizes to be specified in multiples of 33.75 kB, the
smalled amount of buffer sizes need to store a complete set of HM12 4:2:0
macroblocks specifying 32 lines of the frame. A full 60Hz/525 line
screen requires 15 * 33.75 kB per frame and a full 50Hz/625 line screen
requires 18 * 33.75 kB per frame so the default buffer size is 3 * 33.75 kB,
requiring exactly 5 or 6 buffers per MDL respectively. The bytes needed per
frame and hence MDL need not be the bytes in an integer number of buffers.
However, if frame artifacts are seen with scaled screen sizes, the YUV buffer
size can be set 34 kB (33.75 kB) to get rid of the artifacts at the cost of more
copies between the kernel and userspace.
Add a Memory Descriptor List (MDL) layer to buffer handling to implement
scatter-gather I/O. Currently there is still only 1 buffer per MDL.
Trivial patch which adds the __init/__exit macros to the module_init/
module_exit functions of the following drivers in media video:
drivers/media/video/ivtv/ivtv-driver.c
drivers/media/video/davinci/dm355_ccdc.c
drivers/media/video/davinci/dm644x_ccdc.c
drivers/media/video/saa7164/saa7164-core.c
drivers/media/video/saa7134/saa7134-core.c
drivers/media/video/cx23885/cx23885-core.c
Cc: Hermann Pitton <hermann-pitton@arcor.de>
Acked-by: Steven Toth <stoth@kernellabs.com>
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
Acked-by: Andy Walls <awalls@radix.net>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Muralidharan Karicheri <m-karicheri2@ti.com>
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
future cards
Add a routine for dumping the EEPROM of the MPC718. It is generic enough
to use for other cards in the future that may have an EEPROM.
card entries
Simplify the way outgoing work handler gets scheduled to send empty buffers
back to the firmware for use. Also reduced the memory required for scheduling
this outgoing work, by using a single, per stream work object.
to the firmware
This change defers sending all CX18_CPU_DE_SET_MDL commands, for a stream with
an ongoing capture, by adding a work queue to handle sending such commands when
needed. This prevents any sleeps, caused by notifying the firmware of new
usable buffers, when a V4L2 application read() is being satisfied or when
an incoming buffer is processed by the cx18-NN-in work queue thread.
Rename the work queue to "in_work_queue" to indicate it is handling
incoming mailbox commands. This is preparation for adding a work queue
for handling deferrable outgoing mailbox commands.
core->init.
The init callback was used in several places to load firmware. Make a separate
load_fw callback for that. This makes the code a lot more understandable.
i2c_client setup
Remove variables that were holdovers from ivtv for supporting the CX23415
MPEG decoder output.
tveeprom reads
Give messages originating from internal subdevs a header using the subdev's
name. Fixed an uninitialized variable problem with reading the EEPROM, noticed
from log output. Got rid of the unused cx18_av_exit() function.
insertion
We leaked buffers every time a device was removed, if the user had enabled
sliced VBI insertion into the MPEG stream. MythTV uses that.
v4l2_subdevices
Convert GPIO line functions, such a audio routing and device resets, to
v4l2_subdevices. This essentially completes the conversion of cx18 to the
v4l2_device/v4l2_subdevice framework. No regression testing has taken place as
of yet. Also an ivtv legacy bug with GPIO mux routing and going to/from radio
mode was commented, but not fixed.
This is a major perturbation to cx18 I2C device handling to convert it to the
v4l2_device/subdeivce framework. This change breaks GPIO audio multiplexer
control for the time being. It will be fixed in a coming change.
to v4l2_subdev
Added a new chip identifer to v4l2-chip-ident for the integrated A/V broadcast
decoder core internal to the CX23418. Completed separation and encapsulation
of the A/V decoder core interface as a v4l2_subdevice. The cx18 driver now
compiles and links again.
v4l2_device.name
Convert card instance handling to a lighter weight mechanism like ivtv.
Also convert name strings and debug messages to use v4l2_device.name.
systems at least
Sliced VBI, in the manner that ivtv implements it as a separate data stream,
now works for 525 line 60 Hz systems like NTSC-M. It may work for 625 line
50 Hz systems, but I have more engineering work to do, to verify it is operating
properly. Sliced data insertion into the MPEG PS should be working, but is
untested.
buffer size
The cx23418 appears to send Raw VBI buffers with a PTS on a per frame
basis, not per field, so process Raw VBI on a whole frame basis and reduce
some complexity. Fix VBI buffer size computation to handle a whole
frame of Raw VBI for a 625 line system, which is the worst case and will
work for 525 lines systems as well.
Removed legacy ivtv state variables, added comments, and cleaned
up sliced VBI related code. Enabled sliced VBI.
Card report provided by Patryk on the ivtv-devel list:
http://ivtvdriver.org/pipermail/ivtv-devel/2009-January/005922.html
Reported-by: Pat <tatyrza@mm.pl>
request_module() needs to be called with a string literal for a
format string or with 1 or more variable arguments to avoid
compiler warnings and possible exploits, if someone could cause
us to get a format string with a '%' code in the format string
when we make the call.
Reported-by: Brandon Jenkins <bcjenkins@tvwhere.com>
First step in conversion to the new V4L2 framework. Added per cx18 device
instance of the v4l2_device and its registration.
to video_dev
Renamed structure member name to be more specific to type in anticipation
of updating to the v4l2_device/v4l2_subdev framework. Too many objects named
"dev" and /v4l2_\{0,1\}dev/ would be to confusing.
Normalize the APU state before the second firmware load so that audio
for the first analog capture is correct.
Many thanks to Conexant for supporting me in finding a solution for this
problem.
V4L2 spec
Fix bugs in the cx18 AC3 control implementation that would have affected
ivtv and other drivers via the cx2341x module. Bring AC3 controls
behavior into comliance with V4L2 specification. Thanks to Hans Verkuil
for reviewing the previous patch and pointing out the problems.
Reported-by: Hans Verkuil <hverkuil@xs4all.nl>
Initial addition of controls to set AC-3 audio encoding for the CX23418 - it
does not work yet due to firmware or cx18 driver issues. This change affects
the common cx2341x and ivtv modules due to shared structures and
common functions.
Refine the firmware load and firmware startup process. Significant changes
are to ensure the SCB and IPC area are correct before starting up the firmware,
and letting the CPU firmware start up the APU firmware for us.
VBI comment corrections to avoid future confusion about standards.
Comments on cx18 VBI implementation shortcomings that need resolution.
A combined authorship patch from Hans Verkuil and Andy Walls. Raw
VBI can now be captured but requires a video capture to be in progress as well.
This is a port of the fixes Hans Verkuil made for ivtv/cx25840:
The service_set field was used to determine whether raw or sliced VBI was
desired. This is incorrect since it is perfectly valid to select sliced VBI
with a service_set of 0.
Instead the driver should check on VIDIOC_S_FMT whether the type
field matches the raw or sliced VBI type.
Updated the cx18 driver accordingly, including an additional check in
cx18_start_v4l2_encode_stream() that didn't exist in ivtv.
allocations
cx18: Add module parameters for finer control over buffer allocations.
User now has the option of setting smaller buffers to get lower
latency transfers from the encoder. User can also now set the number
of buffers used for a stream explicitly.
deferrable work handling
cx18: Change to per CX23418 device work queues for deferrable work handling.
Needed to support 2.6.22 and earlier kernels that can't selectively cancel
work orders. Also will provide slightly better performance on SMP systems.
logging
cx18: Adjust outgoing mailbox timeouts and remove statistics logging.
This saves some wasted storage in struct cx18 for each card. Cutting
the outgoing mailbox timeouts in half from the previous value appears to
be safe with MythTV. Got rid of interrupted case code path after
a wait uninterruptable returns.
strategy
cx18: Streamline cx18-io[ch] wrappers and enforce MMIO retry strategy so that
write retries always occur and read retries never occur (as they never help).
Remove MMIO statistics logging to speed up MMIO accesses. Deprecate & ignore
retry_mmio and mmio_ndelay module parameters, to essentially force
retry_mmio=1 and mmio_ndelay=0.
deferable work
Change to singlethreaded global work queue thread for deferable work,
instead of the kernel default multithreaded work queue. This ensures
execution of deferable work is always in the proper order, so caputred buffers
don't get reordered.
mailbox processing
A major rewrite of interrupt handling for incoming mailbox processing, to split
the timing critical steps from the the deferrable steps as the sending XPU on
the CX23418 will time out and overwrite our incoming mailboxes rather quickly.
Setup a pool of work "order forms" for the irq handler to send jobs to the new
work handler routine which uses the kernel default work queue to do the
deferrable work. Started optimizing some of the cx18-io calls as they are now
the low hanging fruit for recoving microseconds back from the timeline.
Future optimizations will get rid of mmio read retries, mmio stats logging, and
combine smaller functions in the irq path into the larger ones to save ~2 us
each.
& performnce
All waits for cx18 mailbox API commands are now uninterruptable. Added
code to collect mailbox ack statistics. Tweaked timeouts based on collected
stats and video vertical frame and field rates.
