Rename all PCI drivers with their own directory under
drivers/media/video into drivers/media/pci and update the
building system.
For some reason the cx18 driver could open the radio device only once.
Remove this limitation.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Acked-by: Andy Walls <awalls@md.metrocast.net>
When we moved to 3.0, we found that the cx18 driver was oopsing on close with:
NULL pointer deref at:
[ 2290.461009] Call Trace:
[ 2290.461009] [<c046007b>] ? pm_qos_add_request+0xc/0x6e
[ 2290.461009] [<c082631c>] __mutex_lock_common+0x87/0x125
[ 2290.461009] [<f8970e92>] ? cx18_queue_flush+0x31/0x87 [cx18]
[ 2290.461009] [<c0436b85>] ? __might_sleep+0x29/0xe4
[ 2290.461009] [<c0826515>] __mutex_lock_slowpath+0x25/0x27
[ 2290.461009] [<c08264b2>] ? mutex_lock+0x2e/0x3b
[ 2290.461009] [<c08264b2>] mutex_lock+0x2e/0x3b
[ 2290.461009] [<f88d3137>] videobuf_queue_lock+0x13/0x15 [videobuf_core]
[ 2290.461009] [<f88d3f86>] __videobuf_free+0xfc/0x112 [videobuf_core]
[ 2290.461009] [<f89741e6>] cx18_v4l2_close+0x158/0x172 [cx18]
[ 2290.461009] [<c0507522>] ? cpumask_next+0x1a/0x1d
[ 2290.461009] [<f88a319d>] v4l2_release+0x35/0x52 [videodev]
[ 2290.461009] [<c04f5717>] fput+0x100/0x1a5
[ 2290.461009] [<c04f2e09>] filp_close+0x5c/0x64
[ 2290.461009] [<c04f2e70>] sys_close+0x5f/0x93
[ 2290.461009] [<c082cd5f>] sysenter_do_call+0x12/0x28
Some digging showed that a merge at some previous point partially
added broken mmap() support, causing this trace. Remove the broken
code completely.
On top of that, the calculation in place for "buffer full" depended on
UYUV instead of HM12, while our GStreamer code was picking HM12 in
some circumstances.
Finally, the V4L2_CAP_STREAMING capability was never exposed. Patch it
into the YUV encoder node only.
Signed-off-by: Simon Farnsworth <simon.farnsworth@onelan.co.uk>
The initialisation of vb_type in serialized_open was preventing
REQBUFS from working reliably. Remove it, and move the spinlock into
stream_init for good measure - it's only used when we have a stream
that supports videobuf anyway.
The initial version of this patch (commit
d5976931639176bb6777755d96b9f8d959f79e9e) had some issues:
* It didn't correctly calculate the size of the YUV buffer for 4:2:2,
resulting in capture sometimes being offset by 1/3rd of a picture.
* There were a lot of variables duplicating information the driver
already knew, which have been removed.
* There was an in-kernel format conversion - libv4l can do this one,
and is the right place to do format conversions anyway.
* Some magic numbers weren't properly explained.
Fix all these issues, leaving just the move from videobuf to videobuf2
to do.
Add support for mmap method streaming of raw YUV video on cx18-based
hardware, in addition to the existing support for read() streaming of
raw YUV and MPEG-2 encoded video.
[simon.farnsworth@onelan.co.uk: I forward-ported this from Steven's original work,
done under contract to ONELAN. The original code is at
http://www.kernellabs.com/hg/~stoth/cx18-videobuf]
Signed-off-by: Steven Toth <stoth@kernellabs.com>
VIDIOC_S/G_PRIORITY handling is now done by the v4l2 core framework.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
A trivial change to update my email address from my dead awalls@radix.net
address to my current awalls@md.metrocast.net address.
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
v4l2_prio_init/open/close returned an int when in fact they would
always return 0. Make these void functions.
v4l2_prio_close and v4l2_prio_check pass an enum v4l2_priority as a
pointer for no good reason. Replace with a normal enum v4l2_priority
argument.
These changes will simplify the work of moving priority handling into
the v4l core.
Expose a couple of symbols in the cx18 module so that locking of the PCM
stream can be shared with the cx18-alsa module.
This work was sponsored by ONELAN Limited.
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
Signed-off-by: Andy Walls <awalls@radix.net>
VIDIOC_G_ENC_INDEX support see the light of day.
Some notes:
1. With default capture parameters, the CX23418 seems to transfer 192 index
entries (4.5 kB worth) at 10 second intervals.
2. Index streams don't seem to be supported for MPEG 2 TS streams
3. The index entries seem to claim every frame is a B-Frame. Possible
firmware bug.
4. The cx18 driver does not try to capture an index stream when inserting
sliced VBI into the MPEg stream as the offsets would need fixup.
associated stream
This change starts the IDX stream along with the MPG stream as an internal
use (only) stream much like the VBI stream can be started as an internal use
stream for inserting sliced VBI packets.
The IDX stream is not started automatically with an MPEG strem if the IDX
stream is disabled (no buffers allocated) or if sliced VBI insertion is being
performed by the cx18 driver. The cx18 driver doing sliced VBI insertion
makes the offsets in the IDX stream inaccurate for the final MPEG stream
presented to user space. Since fixing the IDX offsets ourselves is not easy
and we cannot easily do what ivtv does to fix the offsets, we'll make sliced
VBI insertion and MPEG Index capture mutually exclusive for now.
Instead of using the minor number in kernel log messages, use the device
node name as returned by the video_device_node_name() function. This
makes debug, informational and error messages easier to understand for
end users.
[mchehab.redhat.com: removed tm6000 changes as tm6000 is not ready yet for submission even on staging]
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Add a Memory Descriptor List (MDL) layer to buffer handling to implement
scatter-gather I/O. Currently there is still only 1 buffer per MDL.
cx18_queue.depth
Acked-by: Andy Walls <awalls@radix.net>
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
DVD streams
Both the MPEG-2 SVCD stream format and the MPEG-2 DVD stream format should
use an MPEG-2 PS container. This makes it safe to stuff IVTV Private Stream 1
VBI packets in these stream types using the existing cx18 driver routines.
Reported-by: Helen Buus <mythtv@hbuus.com>
s_std didn't belong in the tuner ops. Stricly speaking it should be part of
the video ops, but it is used by audio and tuner devices as well, so it is
more efficient to make it part of the core ops.
This is a major perturbation to cx18 I2C device handling to convert it to the
v4l2_device/subdeivce framework. This change breaks GPIO audio multiplexer
control for the time being. It will be fixed in a coming change.
v4l2_device.name
Convert card instance handling to a lighter weight mechanism like ivtv.
Also convert name strings and debug messages to use v4l2_device.name.
The old code from ivtv used a CX23415/6 PTS, which was simply left at 0 in the
cx18 driver. Since the CX23418 gives us what I think is a PTS (or some other
90 kHz clock count) with each VBI buffer, this change has the cx18 driver use
that as a PTS.
Removed legacy ivtv state variables, added comments, and cleaned
up sliced VBI related code. Enabled sliced VBI.
to video_dev
Renamed structure member name to be more specific to type in anticipation
of updating to the v4l2_device/v4l2_subdev framework. Too many objects named
"dev" and /v4l2_\{0,1\}dev/ would be to confusing.
Initial addition of controls to set AC-3 audio encoding for the CX23418 - it
does not work yet due to firmware or cx18 driver issues. This change affects
the common cx2341x and ivtv modules due to shared structures and
common functions.
Introduce a struct v4l2_file_operations for v4l2 drivers.
Remove the unnecessary inode argument.
Move compat32 handling (and llseek) into the v4l2-dev core: this is now
handled in the v4l2 core and no longer in the drivers themselves.
Note that this changeset reverts an earlier patch that changed the return
type of__video_ioctl2 from int to long. This change will be reinstated
later in a much improved version.
A combined authorship patch from Hans Verkuil and Andy Walls. Raw
VBI can now be captured but requires a video capture to be in progress as well.
This is a port of the fixes Hans Verkuil made for ivtv/cx25840:
The service_set field was used to determine whether raw or sliced VBI was
desired. This is incorrect since it is perfectly valid to select sliced VBI
with a service_set of 0.
Instead the driver should check on VIDIOC_S_FMT whether the type
field matches the raw or sliced VBI type.
Updated the cx18 driver accordingly, including an additional check in
cx18_start_v4l2_encode_stream() that didn't exist in ivtv.
cx18: Allow more than 63 capture buffers in rotation per stream. Implement
q_busy to hold buffers the firmware has for use. q_free holds truly unused
buffers in a pool. New buffers are given to the firmware as soon as the
firmware returns one, if there are any to give to the firmware.
Eliminate q_io from stream buffer handling in anticipation of upcoming
changes in buffer handling. q_io was a holdover from ivtv and it's function
in cx18 was trivial and not necessary. We just push things back onto the
front of q_full now, instead of maintaining a 1 buffer q_io queue.
Add copyright attribution for files modified by awalls in 2008
cx18: Fix cx18_find_handle() and add error checking. cx18_find_handle() did
not find a good task handle and would use the invalid task handle under common
conditions. Added a define for the invalid task handle and added error checking
as well.
cx18: Convert cx18_queue buffers member to atomic_t. This allows safe
concurrent access to check if a queue has data without having to acquire the
queue spinlock.
cx18: Remove redundant struct cx18_queue length member. It can be trivially
computed from queue->buffers * stream->buf_size, if ever really needed.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
The HVR-1600 can do both analog and digital capture at the same time.
Due to a driver bug -EBUSY would be returned when attempting to setup an
analog capture while a digital capture was already in progress.
Separate the two internally.
Upon error conditions in cx18/ivtv_probe(), the code at the 'err:' label
leaves a NULL entry in cx18/ivtv_cards[]. This can cause a NULL pointer
de-reference in cx18/ivtv_v4l2_open() which is fixed by this patch.
This patch contains the following possible cleanups:
- cx18-i2c.c should #include "cx18-i2c.h" for getting the prototypes of
it's global functions
- make the following needlessly global functions static:
- cx18-fileops.c:cx18_claim_stream()
- cx18-fileops.c:cx18_release_stream()
- cx18-queue.c:cx18_queue_move()
- remove the following unused functions:
- cx18-driver.c:cx18_waitq()
- cx18-queue.c:cx18_buf_copy_from_user()
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl>
Many thanks to Steve Toth from Hauppauge and Nattu Dakshinamurthy from
Conexant for their support. I am in particular thankful to Hauppauge
since without their help this driver would not exist. It should also
be noted that Steve did the work to get the DVB part up and running.
Thank you!
Signed-off-by: Steven Toth <stoth@hauppauge.com>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Signed-off-by: G. Andrew Walls <awalls@radix.net>
