Add support for mmap method streaming of raw YUV video on cx18-based
hardware, in addition to the existing support for read() streaming of
raw YUV and MPEG-2 encoded video.
[simon.farnsworth@onelan.co.uk: I forward-ported this from Steven's original work,
done under contract to ONELAN. The original code is at
http://www.kernellabs.com/hg/~stoth/cx18-videobuf]
Signed-off-by: Steven Toth <stoth@kernellabs.com>
Signed-off-by: Simon Farnsworth <simon.farnsworth@onelan.co.uk>
Expose a couple of symbols in the cx18 module so that locking of the PCM
stream can be shared with the cx18-alsa module.
This work was sponsored by ONELAN Limited.
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
Introduce a struct v4l2_file_operations for v4l2 drivers.
Remove the unnecessary inode argument.
Move compat32 handling (and llseek) into the v4l2-dev core: this is now
handled in the v4l2 core and no longer in the drivers themselves.
Note that this changeset reverts an earlier patch that changed the return
type of__video_ioctl2 from int to long. This change will be reinstated
later in a much improved version.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
This patch contains the following possible cleanups:
- cx18-i2c.c should #include "cx18-i2c.h" for getting the prototypes of
it's global functions
- make the following needlessly global functions static:
- cx18-fileops.c:cx18_claim_stream()
- cx18-fileops.c:cx18_release_stream()
- cx18-queue.c:cx18_queue_move()
- remove the following unused functions:
- cx18-driver.c:cx18_waitq()
- cx18-queue.c:cx18_buf_copy_from_user()
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Many thanks to Steve Toth from Hauppauge and Nattu Dakshinamurthy from
Conexant for their support. I am in particular thankful to Hauppauge
since without their help this driver would not exist. It should also
be noted that Steve did the work to get the DVB part up and running.
Thank you!
Signed-off-by: Steven Toth <stoth@hauppauge.com>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Signed-off-by: G. Andrew Walls <awalls@radix.net>
