path: root/drivers/media/video/cx18/cx18-i2c.c
2012-08-15[media] rename most media/video pci drivers to media/pciMauro Carvalho Chehab
Rename all PCI drivers with their own directory under drivers/media/video into drivers/media/pci and update the building system. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-24[media] video: Drop undue references to i2c-algo-bitJean Delvare
There's one comment that has been copied from bttv to many other media/video drivers: /* init + register i2c algo-bit adapter */ Meanwhile, many drivers use hardware I2C implementations instead of relying on i2c-algo-bit, so this comment is misleading. Remove the reference to "algo-bit" from all drivers, to avoid any confusion. This is the best way to ensure that the comments won't go out of sync again. Anyone interested in the implementation details would rather look at the code itself. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] remove the old RC_MAP_HAUPPAUGE_NEW RC mapMauro Carvalho Chehab
The rc-hauppauge-new map is a messy thing, as it bundles 3 different remote controllers as if they were just one, discarding the address byte. Also, some key maps are wrong. With the conversion to the new rc-core, it is likely that most of the devices won't be working properly, as the i2c driver and the raw decoders are now providing 16 bits for the remote, instead of just 8. delete mode 100644 drivers/media/rc/keymaps/rc-hauppauge-new.c Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Jarod Wilson <jarod@redhat.com>
2010-12-29[media] rc: Rename remote controller type to rc_type instead of ir_typeMauro Carvalho Chehab
for i in `find drivers/staging -type f -name *.[ch]` `find include/media -type f -name *.[ch]` `find drivers/media -type f -name *.[ch]`; do sed s,IR_TYPE,RC_TYPE,g <$i >a && mv a $i; done for i in `find drivers/staging -type f -name *.[ch]` `find include/media -type f -name *.[ch]` `find drivers/media -type f -name *.[ch]`; do sed s,ir_type,rc_type,g <$i >a && mv a $i; done Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-11-22[media] v4l: Remove module_name argument to the v4l2_i2c_new_subdev* functionsLaurent Pinchart
The argument isn't used anymore by the functions, remove it. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-22[media] cx18: Don't use module names to load I2C modulesLaurent Pinchart
With the v4l2_i2c_new_subdev* functions now supporting loading modules based on modaliases, replace the hardcoded module name passed to those functions by NULL. The sub-devices without a listed module name don't result in and I2C sub-device being created, as they either are IR devices or don't have an I2C address listed. It's thus safe to rely on modaliases only. All corresponding I2C modules have been checked, and all of them include a module aliases table with names corresponding to what the cx18 driver uses. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-11i2c: Add support for custom probe functionJean Delvare
The probe method used by i2c_new_probed_device() may not be suitable for all cases. Let the caller provide its own, optional probe function. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-06-01V4L/DVB: cx18, cx23885, v4l2 doc, MAINTAINERS: Update Andy Walls' email addressAndy Walls
A trivial change to update my email address from my dead awalls@radix.net address to my current awalls@md.metrocast.net address. Signed-off-by: Andy Walls <awalls@md.metrocast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-19V4L/DVB: ir-core: Make use of the new IR keymap modulesMauro Carvalho Chehab
Instead of using the ugly keymap sequences, use the new rc-*.ko keymap files. For now, it is still needed to have one keymap loaded, for the RC code to work. Later patches will remove this depenency. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-19V4L/DVB: ir: use IR_KEYTABLE where an IR table is neededMauro Carvalho Chehab
Replaces most of the occurences of IR keytables on V4L drivers by a macro that evaluates to provide the name of the exported symbol. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13445): cx18: Use per cx18 instance init data for ir-kbd-i2c ↵Andy Walls
instead of const data This change creates per cx18 instances of IR_i2c_init_data for handing over initialization data to ir-kbd-i2c, since that module wants non-const data even though it never modifies the data. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12540): v4l: simplify v4l2_i2c_new_subdev and friendsHans Verkuil
Rewrite v4l2_i2c_new_subdev as a simplified version of v4l2_i2c_new_subdev_cfg and remove v4l2_i2c_new_probed_subdev and v4l2_i2c_new_probed_subdev_addr. This simplifies this API substantially. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12884): cx18: Eliminate warning about discarding 'const' is ↵Andy Walls
assignment for IR init i2c-kbd-i2c allows a bridge driver to pass information about IR configuration, but uses a "void *" to pass along what is essentially constant data. This change casts a const * to a void * to remove the warning. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12699): cx18: ir-kbd-i2c initialization data should point to a ↵Andy Walls
persistent object ir-kbd-i2c's ir_probe() function can be called much later (i.e. at ir-kbd-i2c module load), than the lifetime of a struct IR_i2c_init_data allocated off of the stack in cx18_i2c_new_ir() at registration time. Make sure we pass a pointer to a persistent IR_i2c_init_data object at i2c registration time. Thanks to Brian Rogers for pointing out a solution, and Dustin Mitchell for testing against a 2.6.30 kernel. Reported-by: Dustin Mitchell <soxslayer@gmail.com> Reported-by: Brian Rogers <brian@xyzw.org> Tested-by: Dustin Mitchell <soxslayer@gmail.com> Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12595): common/ir: use a struct for keycode tablesMauro Carvalho Chehab
Currently, V4L uses a scancode table whose index is the scancode and the value is the keycode. While this works, it has some drawbacks: 1) It requires that the scancode to be at the range 00-7f; 2) keycodes should be masked on 7 bits in order for it to work; 3) due to the 7 bits approach, sometimes it is not possible to replace the default keyboard to another one with a different encoding rule; 4) it is different than what is done with dvb-usb approach; 5) it requires a typedef for it to work. This is not a recommended Linux CodingStyle. This patch is part of a larger series of IR changes. It basically replaces the IR_KEYTAB_TYPE tables by a structured table: struct ir_scancode { u16 scancode; u32 keycode; }; This is very close to what dvb does. So, a further integration with DVB code will be easy. While we've changed the tables, for now, the IR keycode handling is still based on the old approach. The only notable effect is the redution of about 35% of the ir-common module size: text data bss dec hex filename 6721 29208 4 35933 8c5d old/ir-common.ko 5756 18040 4 23800 5cf8 new/ir-common.ko In thesis, we could be using above u8 for scancode, reducing even more the size of the module, but defining it as u16 is more convenient, since, on dvb, each scancode has up to 16 bits, and we currently have a few troubles with rc5, as their scancodes are defined with more than 8 bits. This patch itself shouldn't be doing any functional changes. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12367): cx18: Add i2c initialization for Z8F0811/Hauppage IR ↵Andy Walls
transceivers This patch add support to the cx18 driver for setting up the Z8F0811/Hauppauge IR Tx/Rx chip with the i2c binding model in newer kernels. Signed-off-by: Andy Walls <awalls@radix.net> Reviewed-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12343): Stop defining I2C adapter IDs nobody usesJean Delvare
There is no point in defining I2C adapter IDs when no code is using them. As this field might go away in the future, stop using it when we don't need to. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-29V4L/DVB (11568): cx18: Fix the handling of i2c bus registration errorJean Delvare
* Return actual error values as returned by the i2c subsystem, rather than 0 or 1. * If the registration of the second bus fails, unregister the first one before exiting, otherwise we are leaking resources. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11373): v4l2-common: add explicit v4l2_device pointer as first arg ↵Hans Verkuil
to new_(probed)_subdev The functions v4l2_i2c_new_subdev and v4l2_i2c_new_probed_subdev relied on i2c_get_adapdata to return the v4l2_device. However, this is not always possible on embedded platforms. So modify the API to pass the v4l2_device pointer explicitly. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10759): cx18: Convert GPIO connected functions to act as ↵Andy Walls
v4l2_subdevices Convert GPIO line functions, such a audio routing and device resets, to v4l2_subdevices. This essentially completes the conversion of cx18 to the v4l2_device/v4l2_subdevice framework. No regression testing has taken place as of yet. Also an ivtv legacy bug with GPIO mux routing and going to/from radio mode was commented, but not fixed. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10758): cx18: Convert I2C devices to v4l2_subdevicesAndy Walls
This is a major perturbation to cx18 I2C device handling to convert it to the v4l2_device/subdeivce framework. This change breaks GPIO audio multiplexer control for the time being. It will be fixed in a coming change. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10757): cx18, v4l2-chip-ident: Finish conversion of AV decoder core ↵Andy Walls
to v4l2_subdev Added a new chip identifer to v4l2-chip-ident for the integrated A/V broadcast decoder core internal to the CX23418. Completed separation and encapsulation of the A/V decoder core interface as a v4l2_subdevice. The cx18 driver now compiles and links again. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10756): cx18: Slim down instance handling, build names from ↵Andy Walls
v4l2_device.name Convert card instance handling to a lighter weight mechanism like ivtv. Also convert name strings and debug messages to use v4l2_device.name. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10280): cx18: Rename structure members: dev to pci_dev and v4l2dev ↵Andy Walls
to video_dev Renamed structure member name to be more specific to type in anticipation of updating to the v4l2_device/v4l2_subdev framework. Too many objects named "dev" and /v4l2_\{0,1\}dev/ would be to confusing. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10141): v4l2: debugging API changed to match against driver name ↵Hans Verkuil
instead of ID. Since the i2c driver ID will be removed in the near future we have to modify the v4l2 debugging API to use the driver name instead of driver ID. Note that this API is not used in applications other than v4l2-dbg.cpp as it is for debugging and testing only. Should anyone use the old VIDIOC_G_CHIP_IDENT, then this will be logged with a warning that it is deprecated and will be removed in 2.6.30. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9728): cx18: Copyright attribution update for files modified by awallsAndy Walls
Add copyright attribution for files modified by awalls in 2008 Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9724): cx18: Streamline cx18-io[ch] wrappers and enforce MMIO retry ↵Andy Walls
strategy cx18: Streamline cx18-io[ch] wrappers and enforce MMIO retry strategy so that write retries always occur and read retries never occur (as they never help). Remove MMIO statistics logging to speed up MMIO accesses. Deprecate & ignore retry_mmio and mmio_ndelay module parameters, to essentially force retry_mmio=1 and mmio_ndelay=0. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9512): cx18: Fix write retries for registers that always change - ↵Andy Walls
part 3. cx18: Fix write retries for registers that always change - part 3. Fix the io for the rest of the registers that will often not read back the value just written. Modified register readback checks to make sure the intended effect was achieved without constantly rewriting the registers. The one outstanding register remaining is 0xc72014 CX18_AUDIO_ENABLE, whose behavior on writes I have yet to determine. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8913): cx18: Create cx18_ specific wrappers for all pci mmio ↵Andy Walls
accessesors. cx18: Create cx18_ specific wrappers for all pci mmio accessesors. This is a first step in instrumenting all CX23418 PCI bus IO, to debug problems with accessing the CX23418's PCI memory mapped IO. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8856): v4l: fix assorted compile warnings/errorsHans Verkuil
BIT define conflicts on kernels < 2.6.24, byteorder/swab.h doesn't need to be included at all. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-07-20v4l-dvb: remove legacy checks to allow support for kernels < 2.6.10Hans Verkuil
Also remove some blank lines that were used to split compat code at -devel tree. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (8188): cx18: Add missing reset recovery delay in cx18-i2c.cAndy Walls
cx18: Add a missing reset recovery delay in cx18-i2c.c after the final deassert. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (8089): cx18: add support for Conexant Raptor PAL/SECAM cardSri Deevi
Patch provided courtesy of Conexant http://www.conexant.com. Signed-off-by: Srinivasa Deevi <srinivasa.deevi@conexant.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-06-26V4L/DVB (8068): cx18: Add I2C slave reset via GPIO upon initializationAndy Walls
cx18: Add I2C slave reset via GPIO upon initialization. One user, Michael <msd4824@yahoo.com>, has reported this allows his HVR-1600 EEPROM to be consistently recognized when using (long,) 100 msec delays. The delays in this commit are nominal (10 & 40 msec) and need testing/tuning on boards with I2C problems to find the right values. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-18i2c: Convert remaining new-style drivers to use module aliasingJean Delvare
Update all the remaining new-style i2c drivers to use standard module aliasing instead of the old driver_name/type driver matching scheme. Note that the tuner driver is a bit quirky at the moment, as it overwrites i2c_client.name with arbitrary strings. We write "tuner" back on remove, to make sure that driver cycling will work properly, but there may still be troublesome corner cases. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-05-14V4L/DVB (7856): cx18/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - cx18-i2c.c should #include "cx18-i2c.h" for getting the prototypes of it's global functions - make the following needlessly global functions static: - cx18-fileops.c:cx18_claim_stream() - cx18-fileops.c:cx18_release_stream() - cx18-queue.c:cx18_queue_move() - remove the following unused functions: - cx18-driver.c:cx18_waitq() - cx18-queue.c:cx18_buf_copy_from_user() Signed-off-by: Adrian Bunk <bunk@kernel.org> Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29V4L/DVB (7786): cx18: new driver for the Conexant CX23418 MPEG encoder chipHans Verkuil
Many thanks to Steve Toth from Hauppauge and Nattu Dakshinamurthy from Conexant for their support. I am in particular thankful to Hauppauge since without their help this driver would not exist. It should also be noted that Steve did the work to get the DVB part up and running. Thank you! Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: G. Andrew Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
