path: root/drivers/media/video/cx18/cx18-i2c.c
2008-05-18i2c: Convert remaining new-style drivers to use module aliasingJean Delvare
Update all the remaining new-style i2c drivers to use standard module aliasing instead of the old driver_name/type driver matching scheme. Note that the tuner driver is a bit quirky at the moment, as it overwrites i2c_client.name with arbitrary strings. We write "tuner" back on remove, to make sure that driver cycling will work properly, but there may still be troublesome corner cases. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-05-14V4L/DVB (7856): cx18/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - cx18-i2c.c should #include "cx18-i2c.h" for getting the prototypes of it's global functions - make the following needlessly global functions static: - cx18-fileops.c:cx18_claim_stream() - cx18-fileops.c:cx18_release_stream() - cx18-queue.c:cx18_queue_move() - remove the following unused functions: - cx18-driver.c:cx18_waitq() - cx18-queue.c:cx18_buf_copy_from_user() Signed-off-by: Adrian Bunk <bunk@kernel.org> Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29V4L/DVB (7786): cx18: new driver for the Conexant CX23418 MPEG encoder chipHans Verkuil
Many thanks to Steve Toth from Hauppauge and Nattu Dakshinamurthy from Conexant for their support. I am in particular thankful to Hauppauge since without their help this driver would not exist. It should also be noted that Steve did the work to get the DVB part up and running. Thank you! Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: G. Andrew Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
