path: root/drivers/media/video/cx18/cx18-streams.c
2008-06-05V4L/DVB (7964): cx18 iomem annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-06-05V4L/DVB (7931): cx18: allow for simultaneous digital and analog captureHans Verkuil
The HVR-1600 can do both analog and digital capture at the same time. Due to a driver bug -EBUSY would be returned when attempting to setup an analog capture while a digital capture was already in progress. Separate the two internally. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-06-05V4L/DVB (7885): ivtv/cx18: add compat_ioctl entriesHans Verkuil
2008-05-14V4L/DVB (7854): cx18/ivtv: improve and fix out-of-memory handlingHans Verkuil
- don't show kernel backtrace when the allocation of the buffers fails: the normal ivtv/cx18 messages are clear enough and the backtrace scares users. - fix cleanup after the buffer allocation fails (caused kernel panic). Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29V4L/DVB (7786): cx18: new driver for the Conexant CX23418 MPEG encoder chipHans Verkuil
Many thanks to Steve Toth from Hauppauge and Nattu Dakshinamurthy from Conexant for their support. I am in particular thankful to Hauppauge since without their help this driver would not exist. It should also be noted that Steve did the work to get the DVB part up and running. Thank you! Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: G. Andrew Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
