path: root/drivers/media/video/cx23885/cx23885-dvb.c
2009-06-16V4L/DVB (11769): cx23885: add ATSC/QAM tuning support for Hauppauge ↵Michael Krufky
WinTV-HVR1275 Signed-off-by: Michael Krufky <mkrufky@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11768): cx23885: add ATSC/QAM tuning support for Hauppauge ↵Michael Krufky
WinTV-HVR1270 Signed-off-by: Michael Krufky <mkrufky@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11698): cx23885: For tda10048 boards ensure we specify the I/FSteven Toth
Signed-off-by: Steven Toth <stoth@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-05-09V4L/DVB (11664): cx23885: Frontend wasn't locking on HVR-1500Steven Toth
The boards control struct wasn't updated when (presumably) all of the other drivers migrated from using scode_table to specifying the demod. Signed-off-by: Steven Toth <stoth@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-29V4L/DVB (11626): cx23885: Two fixes for DViCO FusionHDTV DVB-T Dual ExpressChristopher Pascoe
Two fixes for DViCO FusionHDTV DVB-T Dual Express: * Reset correct tuner when reinitializing xc3028. * Disable the I2C gate control to avoid locking up the I2C bus. Tested-by: John Knops <jknops@australiaonline.net.au> Reviewed-by: Steven Toth <stoth@linuxtv.org> Signed-off-by: Christopher Pascoe <linuxdvb@itee.uq.edu.au> Signed-off-by: Devin Heitmueller <dheitmueller@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11368): v4l2-subdev: move s_standby from core to tuner.Hans Verkuil
s_standby is only used to put the tuner in powersaving mode, so move it from core to tuner. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (11297): cx23885: convert to v4l2_subdev.Hans Verkuil
Convert this driver to v4l2_subdev. Note that currently the only card with analog support in this driver is the HVR-1800. The analog tuner support in this driver is limited to what is needed for this board. When analog support is added for other cards, then the tuner load code will probably have to be expanded to take care of those boards. For example, there is currently no support for either radio tuners or tda9887 demods. I'd like to thank Steven Toth for testing this on his HVR-1800. Tested-by: Steven Toth <stoth@linuxtv.org> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10987): cx23885: fix crash on non-netup cardsHans Verkuil
The new support for the CX23885_BOARD_NETUP_DUAL_DVBS2_CI board broke the existing boards. Interrupts for the netup part were enabled and handled without testing whether the current board actually had a netup -> instant and fatal crash. I've added tests to do this only for the CX23885_BOARD_NETUP_DUAL_DVBS2_CI board. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Reviewed-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10805): Add support for NetUP Dual DVB-S2 CI cardIgor M. Liplianin
Add support for NetUP Dual DVB-S2 CI card The card based on cx23885 PCI-e bridge, CiMax SP2 Common Interface chips, STM lnbh24 LNB power chip, stv6110 tuners and stv0900 demodulator. http://www.linuxtv.org/wiki/index.php/NetUP_Dual_DVB_S2_CI Signed-off-by: Igor M. Liplianin <liplianin@netup.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10269): Add support for DVBWorld DVBS2 PCI-e 2005.Igor M. Liplianin
DVBWorld DVBS2 PCI-e 2005 card contains cx23885 PCI-e bridge and cx24116 demodulator. http://www.linuxtv.org/wiki/index.php/DVBWorld_DVB-S2_2005_PCI-Express_Card The card tested by me (Igor). Signed-off-by: Igor M. Liplianin <liplianin@me.by> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10267): Add support for TeVii S470 DVB-S2 PCI-e card.Igor M. Liplianin
TeVii S470 DVB-S2 PCI-e card contains cx23885 PCI-e bridge and cx24116 demodulator. http://www.linuxtv.org/wiki/index.php/TeVii_S470 The card tested by me (Igor). Signed-off-by: Igor M. Liplianin <liplianin@me.by> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10266): Add support for TurboSight TBS6920 DVB-S2 PCI-e card.Igor M. Liplianin
TurboSight TBS6920 DVB-S2 PCI-e card contains cx23885 PCI-e bridge and cx24116 demodulator. http://www.linuxtv.org/wiki/index.php/TBS_6920 The card tested by me (Igor). Signed-off-by: Igor M. Liplianin <liplianin@me.by> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9795): Add Compro VideoMate E650F (DVB-T part only).Igor M. Liplianin
Add Compro VideoMate E650F (DVB-T part only). The card based on cx23885 PCI-Express chip, xc3028 tuner and ce6353 demodulator. Cc: Steven Toth <stoth@linuxtv.org> Signed-off-by: Igor M. Liplianin <liplianin@me.by> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9271): videobuf: data storage optimisation (2)Darron Broad
To optimise data storage even further one other redundant var has been removed. This also removes a redundant assignment. Signed-off-by: Steven Toth <stoth@linuxtv.org> Signed-off-by: Darron Broad <darron@kewl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9251): cx23885: Checkpatch complianceSteven Toth
cx23885: Checkpatch compliance Signed-off-by: Steven Toth <stoth@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9232): cx23885: Move the MFE frontend allocation into the correct placeSteven Toth
cx23885 frontend allocation code needs to exist in the higher function, and it also needs to ensure videobug is also correctly initialised on a per frontend basis. This code uses the previous num_frontends patch to safely init each future MFE frontend on a single tsport as as safely as possible - given that we don't have any of those boards. Again, better to add all of this safety code now, while the MFE patch set is fresh in everyone mind, than to try and add it 12-24 months from now, when the subject is cold. Signed-off-by: Steven Toth <stoth@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9230): cx23885: MFE related OOPS fixSteven Toth
Bug: the tree generated an oops when the cx23885 was laoded. This avoids the oops by ensuring the mutex is correctly initialised before it's used. Signed-off-by: Steven Toth <stoth@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9227): MFE: Add multi-frontend mutual exclusionDarron Broad
This add frontend R/W mutual exclusion. Prior to this point in time it was possible to open both frontends simultaneously which an MFE card cannot support. In order to stop this, a delayed open is performed which has the following function: - Return EBUSY after a configurable amount of time if a frontend is unavailable due to the other being in use. - Only allow opening of a frontend if the kernel thread of the other has stopped. This solution was chosen to allow switching between frontends to work as seamlessly as possible. When both frontends are actually opened simultaneously then one will only open, but if quick switching is performed between one of many then the new open will succeed in a clean fashion rather than interrupting a kernel thread. Signed-off-by: Darron Broad <darron@kewl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9224): MFE: bugfix: add missing frontend allocationDarron Broad
When using MFE on a setup with both and HVR-3000 and ASUS P7131 card it was noticed that frontend allocation for saa7134 adapters was missing. This patch adds that allocation for both saa7134 and cx23885 adapters. Signed-off-by: Darron Broad <darron@kewl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9223): MFE: Fix a number of bugs and some tidying upDarron Broad
A number of reference to videobuf_dvb_get_frontend used an invalid index. This has been fixed. The section for the HVR3000 in advise_acquire was redundant as the same logic is used on the HVR4000. This has been removed and both cards now use the same function. A number of small errors and whitespace errors are also fixed. Signed-off-by: Darron Broad <darron@kewl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9222): S2API: Add Multiple-frontend on a single adapter support.Steven Toth
A detailed description from the original patches 2 years ago: "The WinTV-HVR3000 has a single transport bus which is shared between a DVB-T and DVB-S modulator. These patches build on the bus acquisition cx88 work from a few weeks ago to add support for this. So to applications the HVR3000 looks like this: /dev/dvb/adapter0/fe0 (cx24123 DVB-S demod) /dev/dvb/adapter0/fe1 (cx22702 DVB-T demod) Additional boards continue as before, eg: /dev/dvb/adapter1/fe0 (lgdt3302 ATSC demod) The basic change is removing the single instance of the videobuf_dvb in cx8802_dev and saa7134_dev(?) and replacing it with a list and some supporting functions. *NOTE* This branch was taken before v4l-dvb was closed for 2.6.19 so two or three current cx88 patches appear to be reversed by this tree, this will be cleaned up in the near future. The patches missing change the mutex handing to core->lock, fix an enumeration problem." It should be recognised that a number of people have been maintaining this patchset. Significant levels of Kudos to everyone one involved, including but not limited to: Darron Broad Fabio M. Di Nitto Carlo Scarfoglio Hans Werner Without the work of these people, and countless others, my two year old patches would of died on the Mercurial linuxtv.org vine a long time ago. TODO: Revise these patches a little further so that the need for demux1 and dvr0 is optional, not mandatory on the HVR3000. HISTORY (darron): This is the last update to MFE prepared by Hans which is based upon the `scratchpad' diff created by Carlo. All MFE work prior to that point must be attributed to Fabio who ported and maintained Steve's original patch up to that time. Signed-off-by: Steven Toth <stoth@linuxtv.org> Signed-off-by: Darron Broad <darron@kewl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (9055): tuner-xc2028: Do a better job selecting firmware typeMauro Carvalho Chehab
Firmware selection is very tricky on this device. This patch do a better selection of the proper firmware type, by using a code to hint if the firmware to be loaded should be D2620 or D2633. It also allows overriding the hint at the control structure. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (9049): convert tuner drivers to use dvb_frontend->callbackMichael Krufky
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8968): replace xc3028 firmware filenames with defined default ↵Michael Krufky
firmware names Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8951): xc5000: dont pass devptr in xc5000_attach()Michael Krufky
Dont pass devptr in xc5000_attach, dont store it in xc5000_priv. This pointer is passed into the tuner_callback function, which always expects a pointer to fe->dvb->priv or i2c_adapter->algo_data. This prevents future possible bugs in new drivers, such as using a "devptr" other that the standard fe->dvb->priv in a DVB driver. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8807): Add DVB support for the Leadtek Winfast PxDVR3200 HSteven Toth
This patch is on behalf of Stephen Backway <stev391@email.com>, and represents two patches I received (and some subsequent whitespace cleanup I had due to how I pulled the patches). From the original author: a) Add DVB support for the Leadtek Winfast PxDVR3200 H. b) The tuner callback previously checked the command 3 times: 1) To see if it was the XC2028_RESET_CLK 2) To see if it was not the XC2028_RESET_TUNER 3) To see if it was the XC2028_RESET_TUNER This patch removes the third check. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Stephen Backway <stev391@email.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8646): cx23885: Convert framework to use a single tuner callback ↵Steven Toth
function. Code reduction. Tuner callback now assumes that tsport is passed as the void arg. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8644): Add support for DViCO FusionHDTV DVB-T Dual ExpressSteven Toth
Add support for the DViCO FusionHDTV DVB-T Dual Express card, based on work by Chris Pascoe and Stephen Backway. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8643): Switch Hauppauge HVR1400 and HVR1500 to common cx23885 tuner ↵Steven Toth
callback The Hauppauge HVR1400 and HVR1500 can now use the common cx23885 tuner callback. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8642): cx23885: Factor out common cx23885 tuner callbackSteven Toth
Tuners currently hook different things to the private pointer in their callback function. Longer term we should make that private pointer consistent, but for now separate out the guts of the cx23885 tuner callback so we can reuse it. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-09-03V4L/DVB (8805): Steven Toth email address changeSteven Toth
I need this so I can better isolate my linux email from my corporate email. Signed-off-by: Steven Toth <stoth@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-07-20V4L/DVB (8236): cx23885: add support for new revision of FusionHDTV7 Dual ↵Michael Krufky
Express The new revision of this board uses the same pci subsystem id as the first revision, but uses a S5H1411 demodulator instead of the S5H1409. In the case of the FusionHDTV7 Dual Express, if s5h1409_attach fails, try s5h1411_attach. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (7986): cx23885: add initial support for DViCO FusionHDTV7 Dual ExpressMichael Krufky
Only one frontend is enabled right now. The second frontend can lock, but transport doesn't work yet. The device will be supported as a single tuner device until the second frontend is working. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7893): xc5000: bug-fix: allow multiple devices in a single systemMichael Krufky
The current code passes a context pointer in the xc5000_config struct. This context pointer is used in the tuner_callback function, used to reset the device after firmware download. The xc5000_config struct is a static structure, whose .priv member was being assigned before calling xc5000_attach(). If there are more than one of the same device type installed on a single system, the last one to assign xc5000_config.priv will "win", and all others will cease to function properly. This patch passes the context pointer in xc5000_attach() rather that storing it within the static struct xc5000_config. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7829): cx23885: remove remaining references to dvb-pllMichael Krufky
The cx23885 driver used to use dvb-pll for LG-TDVS-H064F support on the FusionHDTV5 Express. This has since been converted to use tuner-simple instead, once digital tuning support was added to tuner-simple. Since cx23885 no longer uses dvb-pll, remove the #include "dvb-pll.h", and the DVB_PLL Kconfig selection. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-25v4l/dvb: add statics to avoid multiple definitionsHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24V4L/DVB (7673): cx23885: Add support for the Hauppauge HVR1400Steven Toth
DVB-T mode is now supported using the DiBcom dib7000p demodulator and the Xceive xc3028L silicon tuner. Analog mode is not supported. Signed-off-by: Steven Toth <stoth@hauppauge.com> Reviewed-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7651): tuner-xc2028: Several fixes to SCODEMauro Carvalho Chehab
This patch fixes several issues on SCODE: 1) The extracting tool weren't generating the proper tags for SCODE. This has almost no effect, since those tags shouldn't be used; 2) DIBCOM52 were using a wrong IF. It should be 5200, instead of 5700; 3) seek_firmware were wanting an exact match for firmware type. This is wrong. As result, no SCODE firmware were loaded; 4) A few files were including the wrong file for seeking demod firmwares; 5) XC3028_FE_DEFAULT can be used, if user doesn't want to load a firmware. However, this weren't documentated. This feature require more testing. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7647): Add support for the Hauppauge HVR-1700 digital modeSteven Toth
This adds support for DVB-T mode only, analog is not supported. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7645): Add support for the Hauppauge HVR-1200Steven Toth
This adds support for DVB-T mode only, analog mode is not supported. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7538): Adds selectable adapter numbers as per module optionJanne Grunau
The adapter_nr module options can be used to allocate static adapter numbers on a driver level. It avoids problems with changing DVB apapter numbers after warm/cold boot or device unplugging and repluging. Each driver holds DVB_MAX_ADAPTER long array of the preferred order of adapter numbers. options dvb-usb-dib0700 adapter_nr=7,6,5,4,3,2,1,0 would result in a reversed allocation of adapter numbers. With adapter_nr=2,5 it tries first to get adapter number 2 and 5. If both are already in use it will allocate the lowest free adapter number. Signed-off-by: Janne Grunau <janne-dvb@grunau.be> Acked-by: Hermann Pitton <hermann.pitton@arcor.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7520): media/video/cx23885 replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7432): tda18271: allow device-specific configuration of rf agc topMichael Krufky
allow device-specific configuration of rf agc rf top and if top Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7431): tda18271: allow device-specific configuration of IF levelMichael Krufky
2008-04-24V4L/DVB (7412): use tuner-simple for LG TDVS-H06xF digital tuning supportMichael Krufky
Convert cx88-dvb, dvb-bt8xx, b2c2-flexcop, cxusb and cx23885 to use tuner-simple instead of dvb-pll for LG TDVS-H06xF Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7399): Removes video_dev from tuner-xc2028 config structMauro Carvalho Chehab
The video_dev parameter, on tuner-xc2028 were used to pass i2c private data to tuner_callback. Since the driver already have a pointer to i2c_adap->algo_data, uses this instead. This parameter were used also as a magic number to idenfity if two drivers are trying to register the same xc3028 tuner. This occurs with boards with DVB support, where both DVB and V4L drivers will share the same tuner. Instead of using the algo_data as a private number, after this patch, the driver will use i2c_adap->dev, with seems more consistent. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7385): tda18271: store agc_mode configuration independently of std_bitsMichael Krufky
2008-04-24V4L/DVB (7237): Convert videobuf-dma-sg to generic DMA APIGuennadi Liakhovetski
videobuf-dma-sg does not need to depend on PCI. Switch it to using generic DMA API, convert all affected drivers, relax Kconfig restriction, improve compile-time type checking, fix some Coding Style violations while at it. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (7045): xc5000: Small amount of cleanup and commentingSteven Toth
xc5000: Small amount of cleanup and commenting, just for clarification. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (7044): XC5000: Fix support for HVR1500Q broken by patch 1Steven Toth
From Zhang: This patch fixes support for the HVR1500Q which was broken when the xc5000 analog patch was added. Patch committed as-is, cleanups to follows .... Steve Signed-off-by: Chaogui Zhang <czhang1974@gmail.com> Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
