commit 9bed77ee2fb46b74782d0d9d14b92e9d07f3df6e upstream.
This device is not using the proper demod IF. Instead of using the
IF macro, it is specifying a IF frequency. This doesn't work, as xc3028
needs to load an specific SCODE for the tuner. In this case, there's
no IF table for 5 MHz.
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6:
[media] tuner-core: fix a 2.6.39 regression with mt20xx
[media] dvb_frontend: fix race condition in stopping/starting frontend
[media] media: fix radio-sf16fmr2 build when SND is not enabled
[media] MEDIA: Fix non-ISA_DMA_API link failure of sound code
[media] nuvoton-cir: make idle timeout more sane
[media] mceusb: increase default timeout to 100ms
[media] mceusb: Timeout unit corrections
[media] Revert "V4L/DVB: cx23885: Enable Message Signaled Interrupts(MSI)"
This reverts commit e38030f3ff02684eb9e25e983a03ad318a10a2ea.
MSI flat-out doesn't work right on cx2388x devices yet. There are now
multiple reports of cards that hard-lock systems when MSI is enabled,
including my own HVR-1250 when trying to use its built-in IR receiver.
Disable MSI and it works just fine. Similar for another user's HVR-1270.
Issues have also been reported with the HVR-1850 when MSI is enabled,
and the 1850 behavior sounds similar to an as-yet-undiagnosed issue I've
seen with an 1800.
CC: stable@kernel.org
CC: Steven Toth <stoth@kernellabs.com>
CC: Kusanagi Kouichi <slash@ac.auone-net.jp>
Signed-off-by: Jarod Wilson <jarod@redhat.com>
Acked-by: Andy Walls <awalls@md.metrocast.net>
The cx23885 driver was including staging/altera.h, but that file has
moved back into the driver directory.
Why a non-staging driver was including a staging driver is beyond me,
but this fixes the build so everything is happy for now.
For the record, it's not ok for a non-staging driver to depend on a
staging one, as that implies that the non-staging one should also be in
the staging tree if that's needed.
Cc: Igor M. Liplianin <liplianin@netup.ru>
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
We leak the memory allocated to 'fw' (the firmware) when the variable goes
out of scope.
Fix the leak by calling release_firmware(fw) before 'fw' goes out of
scope.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
pci_setup_device() has saved the PCI revision in the pci_dev
struct since Linux 2.6.23. Use it.
Cc: Auke Kok <auke-jan.h.kok@intel.com>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (42 commits)
[media] media: vb2: correct queue initialization order
[media] media: vb2: fix incorrect v4l2_buffer->flags handling
[media] s5p-fimc: Add support for the buffer timestamps and sequence
[media] s5p-fimc: Fix bytesperline and plane payload setup
[media] s5p-fimc: Do not allow changing format after REQBUFS
[media] s5p-fimc: Fix FIMC3 pixel limits on Exynos4
[media] tda18271: update tda18271c2_rf_cal as per NXP's rev.04 datasheet
[media] tda18271: update tda18271_rf_band as per NXP's rev.04 datasheet
[media] tda18271: fix bad calculation of main post divider byte
[media] tda18271: prog_cal and prog_tab variables should be s32, not u8
[media] tda18271: fix calculation bug in tda18271_rf_tracking_filters_init
[media] omap3isp: queue: Don't corrupt buf->npages when get_user_pages() fails
[media] v4l: Don't register media entities for subdev device nodes
[media] omap3isp: Don't increment node entity use count when poweron fails
[media] omap3isp: lane shifter support
[media] omap3isp: ccdc: support Y10/12, 8-bit bayer fmts
[media] media: add missing 8-bit bayer formats and Y12
[media] v4l: add V4L2_PIX_FMT_Y12 format
cx23885: Fix stv0367 Kconfig dependency
[media] omap3isp: Use isp xclk defines
Fix up trivial conflict (spelink errurs) in drivers/media/video/omap3isp/isp.c
There are two "hauppauge-new" keymaps, one with protocol
unknown, and the other with the protocol marked accordingly.
However, both tables are miss-named.
Also, the old rc-hauppauge-new is broken, as it mixes
three different controllers as if they were just one.
This patch solves half of the problem by renaming the
correct keycode table as just rc-hauppauge. This table
contains the codes for the four different types of
remote controllers found on Hauppauge cards, properly
mapped with their different addresses.
create mode 100644 drivers/media/rc/keymaps/rc-hauppauge.c
delete mode 100644 drivers/media/rc/keymaps/rc-rc5-hauppauge-new.c
[Jarod: fix up RC_MAP_HAUPPAUGE defines]
Two xc5000 tuners connected to same i2c bus.
Experiments shows that situation when one tuner is not initialized
while other is tuned to channel causes TS errors.
Signed-off-by: Abylay Ospan <aospan@netup.ru>
CI reset takes several seconds on some CAM,
so there is no need to lock mutex all that time.
Also we need not to preserve CI's reset bits in
CIBUSCTRL register, they are handled automatically by FPGA.
Set it to 0 explicitly in order to not reset wrong CAM.
It decreases I2C traffic.
Signed-off-by: Igor M. Liplianin <liplianin@netup.ru>
Functions defined in a header should be static inline. This prevents
compile warnings like:
'altera_ci_tuner_reset' defined but not used
(Actually appeared in the media backwards compatibility build).
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
drivers/media/video/cx23885/altera-ci.c: In function 'altera_hw_filt_init':
drivers/media/video/cx23885/altera-ci.c:671:2: warning: cast from pointer to integer of different size
drivers/media/video/cx23885/altera-ci.c: In function 'altera_ci_init':
drivers/media/video/cx23885/altera-ci.c:739:2: warning: cast from pointer to integer of different size
Use %p instead of 0x%x to print addresses.
filter
It takes too long time to scan due to low symbol rate PID's
like PAT, PMT, CAT, NIT.
For that matter we enabled permanently all PID's
less 0x20 in hardware PID filter for NetUP Dual DVB-T/C CI RF card
to combine rates.
cx23885_board structure
This is needed for multifrontend support.
NetUP Dual DVB-T/C CI RF card has frontends connected to port B & C
Each frontend has two switchable cores - DVB-T & DVB-C
There is two external I2C buses in cx23885 chip.
Currently, analog tuners supported for second I2C bus only
In NetUP Dual DVB-T/C CI RF card tuners connected to first bus
So, in order to support analog tuners sitting on first bus
we need modifications.
The card based on cx23885 PCI-e brige. Altera FPGA for CI,
multistandard demods stv0367 from STM for QAM & OFDM, Xcieve xc5000 tuners
and additional cx25840 for second analog input.
An Altera FPGA CI module for NetUP Dual DVB-T/C RF CI card.
The previous revert-commit, that affected cx23885-i2c.c, left some
unused labels that the compiler griped about. Clean them up.
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
This reverts commit 44835f197bf1e3f57464f23dfb239fef06cf89be.
With the CX23885 hardware I2C master, checking for I2C slave ACK/NAK
is not valid when the I2C_EXTEND or I2C_NOSTOP bits are set.
Revert the commit that checks for I2C slave ACK/NAK on all transactions,
so that XC5000 tuners work with the CX23885 again.
Thanks go to Mark Zimmerman for reporting and bisecting this problem.
Bisected-by: Mark Zimmerman <markzimm@frii.com>
Reported-by: Mark Zimmerman <markzimm@frii.com>
Cc: stable@kernel.org
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (33 commits)
usb: don't use flush_scheduled_work()
speedtch: don't abuse struct delayed_work
media/video: don't use flush_scheduled_work()
media/video: explicitly flush request_module work
ioc4: use static work_struct for ioc4_load_modules()
init: don't call flush_scheduled_work() from do_initcalls()
s390: don't use flush_scheduled_work()
rtc: don't use flush_scheduled_work()
mmc: update workqueue usages
mfd: update workqueue usages
dvb: don't use flush_scheduled_work()
leds-wm8350: don't use flush_scheduled_work()
mISDN: don't use flush_scheduled_work()
macintosh/ams: don't use flush_scheduled_work()
vmwgfx: don't use flush_scheduled_work()
tpm: don't use flush_scheduled_work()
sonypi: don't use flush_scheduled_work()
hvsi: don't use flush_scheduled_work()
xen: don't use flush_scheduled_work()
gdrom: don't use flush_scheduled_work()
Fixed up trivial conflict in drivers/media/video/bt8xx/bttv-input.c
as per Tejun.
For example boot up with two CAM inserted.
The v4l core sets the v4l2_input.capabilities field based on the supplied
v4l2_ioctl_ops. However, several drivers do a memset or memcpy of the v4l2_input
struct, thus overwriting that field incorrectly.
Either remove the memset (which is already done by the v4l core), or add the
proper capabilities field in case of a memcpy.
The same is also true for v4l2_output, but that only affected the ivtv driver.
Some comments:
1. Everything initialize properly except radio.
2. All analog inputs (TV, composite, S-Video) are tested by myself in several
TV norms (SECAM-D, PAL, NTSC), everything work fine.
So the patch adds general support/detection of the card with working analog
part, DVB part is not supported for now.
Signed-off-by: Alexey Chernov <4ernov@gmail.com>
Reviewed-by: Steven Toth <stoth@kernellabs.com>
for i in `find drivers/staging -type f -name *.[ch]` `find include/media -type f -name *.[ch]` `find drivers/media -type f -name *.[ch]`; do sed s,IR_TYPE,RC_TYPE,g <$i >a && mv a $i; done
for i in `find drivers/staging -type f -name *.[ch]` `find include/media -type f -name *.[ch]` `find drivers/media -type f -name *.[ch]`; do sed s,ir_type,rc_type,g <$i >a && mv a $i; done
The Remote Controller subsystem is meant to be used not only by Infra Red
but also for similar types of Remote Controllers. The core is not specific
to Infra Red. As such, rename:
- ir-core.h to rc-core.h
- IR_CORE to RC_CORE
- namespace inside rc-core.c/rc-core.h
To be consistent with the other changes.
No functional change on this patch.
This patch merges the ir_input_dev and ir_dev_props structs into a single
struct called rc_dev. The drivers and various functions in rc-core used
by the drivers are also changed to use rc_dev as the primary interface
when dealing with rc-core.
This means that the input_dev is abstracted away from the drivers which
is necessary if we ever want to support multiple input devs per rc device.
The new API is similar to what the input subsystem uses, i.e:
rc_device_alloc()
rc_device_free()
rc_device_register()
rc_device_unregister()
[mchehab@redhat.com: Fix compilation on mceusb and cx231xx, due to merge conflicts]
Signed-off-by: David Härdeman <david@hardeman.nu>
Acked-by: Jarod Wilson <jarod@redhat.com>
Tested-by: Jarod Wilson <jarod@redhat.com>
This patch converts the remaining users of flush_scheduled_work() in
media/video.
* bttv-input.c and cx23885-input.c don't use workqueue at all. No
need to flush.
* Make omap24xxcam.c and saa7134-empress.c flush the used work
directly.
* In fd_defio.c, replace cancel_delayed_work() +
flush_scheduled_work() with cancel_delayed_work_sync(). While at
it, replace the deprecated cancel_rearming_delayed_work() with
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
The argument isn't used anymore by the functions, remove it.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
All of the hard problems for BKL removal appear to be solved in the
v4l-dvb/master tree. This removes the BKL from the various open
functions that do not need it, or only use it to protect an
open count.
The zoran driver is nontrivial in this regard, so I introduce
a new mutex that locks both the open/release and the ioctl
functions. Someone with access to the hardware can probably
improve that by using the existing lock in all cases.
Finally, all drivers that still use the locked version of the
ioctl function now get called under a new mutex instead of
the BKL.
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (505 commits)
[media] af9015: Fix max I2C message size when used with tda18271
[media] IR: initialize ir_raw_event in few more drivers
[media] Guard a divide in v4l1 compat layer
[media] imon: fix nomouse modprobe option
[media] imon: remove redundant change_protocol call
[media] imon: fix my egregious brown paper bag w/rdev/idev split
[media] cafe_ccic: Configure ov7670 correctly
[media] ov7670: allow configuration of image size, clock speed, and I/O method
[media] af9015: support for DigitalNow TinyTwin v3 [1f4d:9016]
[media] af9015: map DigitalNow TinyTwin v2 remote
[media] DigitalNow TinyTwin remote controller
[media] af9015: RC fixes and improvements
videodev2.h.xml: Update to reflect the latest changes at videodev2.h
[media] v4l: document new Bayer and monochrome pixel formats
[media] DocBook/v4l: Add missing formats used on gspca cpia1 and sn9c2028
[media] firedtv: add parameter to fake ca_system_ids in CA_INFO
[media] tm6000: fix a macro coding style issue
tm6000: Remove some ugly debug code
[media] Nova-S-Plus audio line input
[media] [RFC,1/1] V4L2: Use new CAP bits in existing RDS capable drivers
Few drivers still have assumption that ir_raw_event
consists of duration and pulse flag.
Fix that.
Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
With the v4l2_i2c_new_subdev* functions now supporting loading modules
based on modaliases, replace the hardcoded module name passed to those
functions by NULL.
All corresponding I2C modules have been checked, and all of them include
a module aliases table with names corresponding to what the drivers
modified here use.
cx23885_dev_checkrevision()
It was missing the `break'.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=18672
Reported-by: Igor <i2g2r2@gmail.com>
videobuf_waiton() must unlock and relock ext_lock if it has to wait.
For that to happen it needs the videobuf_queue pointer.
Don't attempt to unlock/relock q->ext_lock unless it was locked in the
first place.
vb->state has to be protected by a spinlock to be safe.
This patch is based on code from Mauro Carvalho Chehab <mchehab@redhat.com>.
[mchehab@redhat.com: add extra argument to a few missing places]
Add an ext_lock argument to the videobuf init functions. This allows
drivers to pass the vdev->lock pointer (or any other externally held lock)
to videobuf. For now all drivers just pass NULL.
Signed-off-by: Andy Shevchenko <andy.shevchenko@gmail.com>
In cx23885/cx23885-video.c, cx88/cx88-video.c, davinci/vpif_capture.c, and
davinci/vpif_display.c, group the aligned code into a single if branch.
In saa7134/saa7134-video.c, outdent the code following the if.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r disable braces4@
position p1,p2;
statement S1,S2;
if (...) { ... }
if (...) S1@p1 S2@p2
@script:python@
p1 << r.p1;
p2 << r.p2;
if (p1[0].column == p2[0].column):
cocci.print_main("branch",p1)
cocci.print_secs("after",p2)
// </smpl>
The patch below updates broken web addresses in the kernel
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Acked-by: Ben Pfaff <blp@cs.stanford.edu>
Acked-by: Hans J. Koch <hjk@linutronix.de>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
V4L/DVB: v4l2-ctrls.c: needs to include slab.h
V4L/DVB: fix Kconfig to depends on VIDEO_IR
V4L/DVB: Fix IR_CORE dependencies
As pointed by Randy Dunlap <randy.dunlap@oracle.com>:
> ERROR: "ir_keydown" [drivers/media/video/ir-kbd-i2c.ko] undefined!
> ERROR: "__ir_input_register" [drivers/media/video/ir-kbd-i2c.ko] undefined!
> ERROR: "get_rc_map" [drivers/media/video/ir-kbd-i2c.ko] undefined!
> ERROR: "ir_input_unregister" [drivers/media/video/ir-kbd-i2c.ko] undefined!
> ERROR: "get_rc_map" [drivers/media/video/cx88/cx88xx.ko] undefined!
> ERROR: "ir_repeat" [drivers/media/video/cx88/cx88xx.ko] undefined!
> ERROR: "ir_input_unregister" [drivers/media/video/cx88/cx88xx.ko] undefined!
> ERROR: "ir_keydown" [drivers/media/video/cx88/cx88xx.ko] undefined!
> ERROR: "__ir_input_register" [drivers/media/video/cx88/cx88xx.ko] undefined!
> ERROR: "get_rc_map" [drivers/media/video/bt8xx/bttv.ko] undefined!
> ERROR: "ir_input_unregister" [drivers/media/video/bt8xx/bttv.ko] undefined!
> ERROR: "__ir_input_register" [drivers/media/video/bt8xx/bttv.ko] undefined!
> ERROR: "ir_g_keycode_from_table" [drivers/media/IR/ir-common.ko] undefined!
> #5101:
> (.text+0x8306e2): undefined reference to `ir_core_debug'
> (.text+0x830729): undefined reference to `ir_core_debug'
> ir-functions.c:(.text+0x830906): undefined reference to `ir_core_debug'
> (.text+0x8309d8): undefined reference to `ir_g_keycode_from_table'
> (.text+0x830acf): undefined reference to `ir_core_debug'
> (.text+0x830b92): undefined reference to `ir_core_debug'
> (.text+0x830bef): undefined reference to `ir_core_debug'
> (.text+0x830c6a): undefined reference to `ir_core_debug'
> (.text+0x830cf7): undefined reference to `ir_core_debug'
> budget-ci.c:(.text+0x89f5c8): undefined reference to `ir_keydown'
> budget-ci.c:(.text+0x8a0c58): undefined reference to `get_rc_map'
> budget-ci.c:(.text+0x8a0c80): undefined reference to `__ir_input_register'
> budget-ci.c:(.text+0x8a0ee0): undefined reference to `get_rc_map'
> budget-ci.c:(.text+0x8a11cd): undefined reference to `ir_input_unregister'
> (.text+0x8a8adb): undefined reference to `ir_input_unregister'
> dvb-usb-remote.c:(.text+0x8a9188): undefined reference to `get_rc_map'
> dvb-usb-remote.c:(.text+0x8a91b1): undefined reference to `__ir_input_register'
> dvb-usb-remote.c:(.text+0x8a9238): undefined reference to `get_rc_map'
> dib0700_core.c:(.text+0x8b04ca): undefined reference to `ir_keydown'
> dib0700_devices.c:(.text+0x8b2ea8): undefined reference to `ir_keydown'
> dib0700_devices.c:(.text+0x8b2ef0): undefined reference to `ir_keydown'
Those breakages seem to be caused by two bad things at IR_CORE Kconfig:
1) cx23885 is using select for IR_CORE;
2) the dvb-usb and sms dependency for IR_CORE were missing.
While here, allow users to un-select IR.
Now that i2c-core offers the possibility to provide custom probing
function for I2C devices, let's make use of it.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
ir_raw_event
The CX23885 and CX25840 modules were using their own simple
IR pulse width measurement record type which required conversion
when passing to the new IR core. This change makes that record type
consistent with the new IR core and removes a data conversion.
Instead of reporting an IR Rx timeout event as a ridiculously
long space, report it as a space of the lenght of the timeout.
This partially fixes operation with LIRC without breaking
interoperation with the in kernel decoders. The gaps lengths
reported to LIRC are still not real however.
