path: root/drivers/media/video/cx25840/cx25840-firmware.c
2008-04-24V4L/DVB (7241): cx25840: code cleanupTyler Trafford
- Use min() - Eliminate extraneous variables Signed-off-by: Tyler Trafford <ttrafford@gmail.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (7002): cx25840: Add basic CX23885 AVCore supportSteven Toth
The cx23885/7/8 PCIe bridge has an internal AVCore modelled on the cx2584x family. Many of the registers positions are identical but some moved. The register values are also different because the different bridges run at different clock rates. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5380): Cx25840-firmware include cleanupJean Delvare
There is no reason why cx25840-firmware.c would need to include <linux/i2c-algo-bit.h>. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-03-01V4L/DVB (5255): Fix cx25840 firmware loading.Hans Verkuil
Due to changes in the i2c handling in 2.6.20 this cx25840 bug surfaced, causing the firmware load to fail for the ivtv driver. The correct sequence is to first attach the i2c client, then use the client's device to load the firmware. Acked-by: Mike Isely <isely@pobox.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-05-12V4L/DVB (3825): Remove broken 'fast firmware load' from cx25840.Hans Verkuil
The fast firmware load hack in cx25840 uses private data. In fact, it breaks pvrusb2 and doesn't work at all with ivtv. It is a unsafe implementation and so it is removed. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-04-02V4L/DVB (3639): Reduce FWSEND due to certain I2C bus adapter limitsMike Isely
The FWSEND parameter controls the size of the firmware chunks sent down the I2C bus to the chip. Previously this had been set to 1024 but unfortunately some I2C implementations can't transfer data in such big gulps. Specifically, the pvrusb2 driver has a hard limit of around 60 bytes, due to the encapsulation there of I2C traffic into USB messages. So we have to significantly reduce this parameter. Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mike Isely <isely@pobox.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-04-02V4L/DVB (3610): Added the new routing commands to cx25840.Hans Verkuil
2006-01-09V4L/DVB (3279): Added VIDIOC_QUERYCTRL to cx25840.Hans Verkuil
- Added VIDIOC_QUERYCTRL - Removed unnecessary inlines. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3278): convert diagnostics over to the new v4l2-common.h macros.Hans Verkuil
- Convert diagnostics over to the new v4l2-common.h macros. - deprecated tuner_debug option, the new option is debug. - renamed cx25840_debug to debug. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3198): make cx25840 recover from some firmware load failuresTyler Trafford
- In the rare event that a 333MHz i2c firmware load fails after writing some data, this fix makes the driver reset the DL_ADDR registers to the proper values before continuing on with 100MHz transfers. Signed-off-by: Tyler Trafford <tatrafford@comcast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-11-13[PATCH] v4l: 976: ensure consistent v4l firmware prefixesHans Verkuil
Ensure consistent v4l firmware prefixes. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (958) Make cx25840 use firmware image named 'cx25840.fw'Tyler Trafford
Change default filename of firmware image to 'cx25840.fw' Signed-off-by: Tyler Trafford <tatrafford@comcast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (946) adds support for cx25840 video decoderHans Verkuil
Adds support for cx25840 video decoder. Driver authors: Hans Verkuil, Chris Kennedy, Tyler Trafford, Ulf Eklund. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Chris Kennedy <c@groovy.org> Signed-off-by: Tyler Trafford <tatrafford@comcast.net> Thanks-to: Ulf Eklund <ivtv@eklund.to>. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
