path: root/drivers/media/video/cx88/cx88-vp3054-i2c.h
2007-07-18V4L/DVB (5629): Cx88: VP3054 support can't be a module when cx88 is compiled inTrent Piepho
If cx88 support is compiled into the kernel while vp3054 is left as a module, the kernel will fail to link. Adjust the existing "#if" code in cx88 so that it won't consider vp3054 to be supported in this case. It might make sense to move vp3054 selection into the "customisation" menu instead of a cx88 sub-option (though this is a cx88 feature, there is no extra chip involved). It might also make sense to use dvb_attach() to load vp3054 support. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-09V4L/DVB (5618): Cx88: Drop the generic i2c client from cx88-vp3054-i2cJean Delvare
Drop the generic client declared in cx88-vp3054-i2c: it's not used anywhere. This shrinks cx88-vp3054-i2c.o by 29% on x86_64. Unless it was there for later use? Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09V4L/DVB (3220): Add support for VP-3054 HDTV boardChris Pascoe
- Added support for VP-3054 (aka DigitalNow DNTV Live! DVB-T Pro!). - This board has a secondary I2C bus and remote control. - Added a new module to handle secondary I2C bus on this board. Signed-off-by: Chris Pascoe <c.pascoe@itee.uq.edu.au> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
