It is based of...
* Empia EM28174
* NXP TDA10071 & Conexant CX24118A combo
* Allegro A8293
Signed-off-by: Antti Palosaari <crope@iki.fi>
Not working yet. There are some fixes at the DRX-K that are needed
for it to work.
Supports DVB-T/T2/C, USB ID: 2013:024f.
Empia EM28174, Sony CXD2820R and NXP TDA18271HD/C2.
The Remote Controller subsystem is meant to be used not only by Infra Red
but also for similar types of Remote Controllers. The core is not specific
to Infra Red. As such, rename:
- ir-core.h to rc-core.h
- IR_CORE to RC_CORE
- namespace inside rc-core.c/rc-core.h
To be consistent with the other changes.
No functional change on this patch.
cx88 only depends on VIDEO_IR because it needs ir_extract_bits().
Move that function to ir-core.h and make it inline.
Lots of drivers had dependencies on VIDEO_IR when they really
wanted IR_CORE.
The only remaining drivers to depend on VIDEO_IR are bt8xx and
saa7134 (ir_rc5_timer_end is the only function exported by
ir-functions).
Rename VIDEO_IR -> IR_LEGACY to give a hint to anyone writing or
converting drivers to IR_CORE that they do not want a dependency
on IR_LEGACY.
Signed-off-by: David Härdeman <david@hardeman.nu>
Acked-by: Jarod Wilson <jarod@redhat.com>
This device uses an em2874B + Sharp 921 One Seg frontend.
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
warning: (VIDEO_BT848 && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_DEV && PCI && I2C && VIDEO_V4L2 && INPUT || VIDEO_SAA7134 && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && VIDEO_DEV && PCI && I2C && INPUT || VIDEO_CX88 && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && VIDEO_DEV && PCI && I2C && INPUT || VIDEO_IVTV && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && PCI && I2C && INPUT || VIDEO_CX18 && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && DVB_CORE && PCI && I2C && EXPERIMENTAL && INPUT || VIDEO_EM28XX && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && V4L_USB_DRIVERS && USB && VIDEO_DEV && I2C && INPUT || VIDEO_TLG2300 && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && V4L_USB_DRIVERS && USB && VIDEO_DEV && I2C && INPUT && SND && DVB_CORE || VIDEO_CX231XX && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && V4L_USB_DRIVERS && USB && VIDEO_DEV && I2C && INPUT || DVB_BUDGET_CI && MEDIA_SUPPORT && DVB_CAPTURE_DRIVERS && DVB_CORE && DVB_BUDGET_CORE && I2C && INPUT || DVB_DM1105 && MEDIA_SUPPORT && DVB_CAPTURE_DRIVERS && DVB_CORE && PCI && I2C && INPUT || VIDEO_GO7007 && STAGING && !STAGING_EXCLUDE_BUILD && VIDEO_DEV && PCI && I2C && INPUT && SND || VIDEO_CX25821 && STAGING && !STAGING_EXCLUDE_BUILD && DVB_CORE && VIDEO_DEV && PCI && I2C && INPUT) selects VIDEO_IR which has unmet direct dependencies (IR_CORE)
Support for Reddo DVB-C USB TV Box device. Remote is not working yet.
Thanks to Benjamin Larsson <banan@ludd.ltu.se>
Cc: Benjamin Larsson <banan@ludd.ltu.se>
This webcam uses a em2710 chipset, that identifies itself as em2820,
plus a mt9v011 sensor, and a DY-301P lens.
It needs a few different initializations than a normal em28xx device.
Thanks to Hans de Goede <hdegoede@redhat.com> and Douglas Landgraf
<dougsland@redhat.com> for providing the acces for the webcam during
this weekend, I could make a patch for it while returning back from
FISL/Fudcom LATAM 2009.
em28xx-dvb doesn't need FW_LOADER. Instead, tuner-xc2028 needs to select
FW_LOADER.
Also, this can happen only if HOTPLUG is selected, since FW_LOADER
is dependent on HOTPLUG.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
VIDEO_TUNER is responsible for compilation of tuners.ko module. This were the
previous behaviour before the creation of MEDIA_TUNER.
Before this patch, tuner.ko were created even for drivers that don't need a
tuner (like webcam drivers).
namespace for all of them.
Adds the correct GPIOs and demod attach code for the HVR-900
This patch adds DVB support for Hauppauge HVR950.
Thanks to Michael Krufky <mkrufky@linuxtv.org> for getting those values.
Some devices have msp3400 audio decoder chip. Selects it, if em28xx.
This patch adds em28xx-dvb. This driver is highly based on cx88-dvb and
saa7134-dvb.
This code currently loads and unloads successfully. However, some
changes are needed to properly support the mpeg streams and to setup
em28xx to work on DVB mode.
Without this you get undefined symbol errors with CONFIG_SND=N:
ERROR: "snd_pcm_period_elapsed" [drivers/media/video/em28xx/em28xx-alsa.ko] undefined!
ERROR: "snd_pcm_hw_constraint_integer" [drivers/media/video/em28xx/em28xx-alsa.ko] undefined!
ERROR: "snd_pcm_set_ops" [drivers/media/video/em28xx/em28xx-alsa.ko] undefined!
ERROR: "snd_pcm_lib_ioctl" [drivers/media/video/em28xx/em28xx-alsa.ko] undefined!
ERROR: "snd_card_new" [drivers/media/video/em28xx/em28xx-alsa.ko] undefined!
ERROR: "snd_card_free" [drivers/media/video/em28xx/em28xx-alsa.ko] undefined!
ERROR: "snd_card_register" [drivers/media/video/em28xx/em28xx-alsa.ko] undefined!
ERROR: "snd_pcm_new" [drivers/media/video/em28xx/em28xx-alsa.ko] undefined!
Signed-off-by: S.Çağlar Onur <caglar@pardus.org.tr>
Also fixes the remaining CodingStyle issues that Lindent didn't fix.
There were some vestiges of an old V4L1 I2C driver that were called by em28xx.
This patch removes this dead code, and replaces videodev.h to videodev2.h
Now, this driver doesn't require V4L1 anymore.
All of these drivers select VIDEO_IR, which uses the input subsystem,
so they should also depend on INPUT.
Problem examples:
drivers/built-in.o: In function `ir_input_key_event':
ir-functions.c:(.text+0x10849a): undefined reference to `input_event'
ir-functions.c:(.text+0x1084ac): undefined reference to `input_event'
drivers/built-in.o: In function `saa7134_set_i2c_ir':
(.text+0x11cc0a): undefined reference to `get_key_pinnacle_color'
(.text+0x11cc4f): undefined reference to `get_key_pinnacle_grey'
drivers/built-in.o: In function `saa7134_input_fini':
(.text+0x11cd8b): undefined reference to `input_unregister_device'
drivers/built-in.o: In function `saa7134_input_init1':
(.text+0x11d1fa): undefined reference to `input_allocate_device'
(.text+0x11d317): undefined reference to `input_register_device'
(.text+0x11d6ca): undefined reference to `input_free_device'
(.text+0x11c3f3): undefined reference to `ir_codes_hauppauge_new'
(.text+0x11c450): undefined reference to `ir_codes_pinnacle_color'
(.text+0x11c480): undefined reference to `ir_codes_purpletv'
(.text+0x11c495): undefined reference to `ir_codes_pinnacle_grey'
drivers/built-in.o: In function `saa7134_ir_start':
(.text+0x11c622): undefined reference to `ir_rc5_timer_end'
(.text+0x11c637): undefined reference to `ir_rc5_timer_keyup'
drivers/built-in.o: In function `build_key':
saa7134-input.c:(.text+0x11c769): undefined reference to `ir_extract_bits'
saa7134-input.c:(.text+0x11c7ad): undefined reference to `ir_input_keydown'
saa7134-input.c:(.text+0x11c7f0): undefined reference to `ir_input_keydown'
saa7134-input.c:(.text+0x11c7f9): undefined reference to `ir_input_nokey'
saa7134-input.c:(.text+0x11c806): undefined reference to `ir_input_nokey'
(.text+0x11ca07): undefined reference to `ir_codes_encore_enltv'
(.text+0x11caf6): undefined reference to `ir_input_init'
(.text+0x11cbf2): undefined reference to `ir_codes_avermedia'
(.text+0x11cc24): undefined reference to `ir_codes_pctv_sedna'
(.text+0x11cc53): undefined reference to `ir_codes_flydvb'
(.text+0x11cc85): undefined reference to `ir_codes_videomate_tv_pvr'
(.text+0x11ccb7): undefined reference to `ir_codes_pixelview'
(.text+0x11cce9): undefined reference to `ir_codes_eztv'
(.text+0x11cd1b): undefined reference to `ir_codes_manli'
(.text+0x11cda8): undefined reference to `ir_codes_cinergy'
(.text+0x11cdd7): undefined reference to `ir_codes_flyvideo'
(.text+0x11ce06): undefined reference to `ir_codes_asus_pc39'
(.text+0x11ce7d): undefined reference to `ir_codes_gotview7135'
(.text+0x11cee1): undefined reference to `ir_codes_proteus_2309'
.. because video-buf.c requires PCI, and VIDEO_EM28XX selects it.
Change Kconfig objects from "menu, config" into "menuconfig" so
that the user can disable the whole feature without having to
enter the menu first.
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
There are several boards on V4L that can work with several different
helper modules for audio/video encoding/decoding and similar stuff.
This patch adds the capability of choicing between autoselecting the
pertinent helper modules for each driver, or to manually selecting
them.
Acked-by: Michael Krufky <mkrufky@linuxtv.org>
Acked-by: Mike Isely <isely@pobox.com>
V4L1 API is depreciated and should be removed soon from kernel. This patch
adds two new options, one to disable V4L1 drivers, and another to disable
V4L1 compat module. This way, it would be easy to check what still depends
on V4L1 stuff, allowing also to test if app works fine with V4L2 only support.
- created Kconfig menu item, VIDEO_SAA711X, for the saa7115 module,
which supports SAA7113, SAA7114 and SAA7115 video decoders.
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
- Fixed typo.
Signed-off-by: Michael Krufky <mkrufky@m1k.net>
Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
- Add em28xx to kernel build.
