Not working yet. There are some fixes at the DRX-K that are needed
for it to work.
This board were used for testing the em28xx-alsa using a separate interface.
So, it is obviously validated ;)
Some devices use a separate interface for the vendor audio class.
Fixes most cases of initializing a var but not using it.
There are still 3 cases at em28xx-alsa, were those vars should
probably be used.
All boards use EM28xxx_BOARD, to identify that the macro
refers to a card entry. So:
EM2874_LEADERSHIP_ISDBT -> EM2874_BOARD_LEADERSHIP_ISDBT
PCTV Systems nanoStick T2 290e => PCTV nanoStick T2 290e
Signed-off-by: Antti Palosaari <crope@iki.fi>
Supports DVB-T/T2/C, USB ID: 2013:024f.
Empia EM28174, Sony CXD2820R and NXP TDA18271HD/C2.
EM28174 is very similar as already supported EM2874.
I am not sure what are differences, but it could be analog support.
Add support for the PCTV 330e remote control
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
Remove the flag indicating the 330e board is not validated, based on the half
dozen users who have reported today that everything is working.
Add the calls necessary to use the new drx-d driver for the PCTV 330e
Given how PCTV has multiple products with the same model name, include the
model number in the description and #define to make it a little more clear.
The em28xx bridge strobes the reset pin on the drx-d on every ts_ctrl call.
This results in the state of the chip getting out of the sync with the
state of the driver (and hence all tuning requests after the first one fail).
Make sure the drx-d is not being held in reset, but don't actually perform a
hardware reset on the chip.
The GPIO block has been split out from the other HVR-9x0 variants to reduce
the risk of regression, although in theory they would not have any issues
since none of those cases have the frontend driver managing any internal
state.
Add the required board initialization required for the drx-d to work with
the 900R2.
The rc-hauppauge-new map is a messy thing, as it bundles 3
different remote controllers as if they were just one,
discarding the address byte. Also, some key maps are wrong.
With the conversion to the new rc-core, it is likely that
most of the devices won't be working properly, as the i2c
driver and the raw decoders are now providing 16 bits for
the remote, instead of just 8.
delete mode 100644 drivers/media/rc/keymaps/rc-hauppauge-new.c
Signed-off-by: Jarod Wilson <jarod@redhat.com>
There are two "hauppauge-new" keymaps, one with protocol
unknown, and the other with the protocol marked accordingly.
However, both tables are miss-named.
Also, the old rc-hauppauge-new is broken, as it mixes
three different controllers as if they were just one.
This patch solves half of the problem by renaming the
correct keycode table as just rc-hauppauge. This table
contains the codes for the four different types of
remote controllers found on Hauppauge cards, properly
mapped with their different addresses.
create mode 100644 drivers/media/rc/keymaps/rc-hauppauge.c
delete mode 100644 drivers/media/rc/keymaps/rc-rc5-hauppauge-new.c
[Jarod: fix up RC_MAP_HAUPPAUGE defines]
The core.s_config op was meant for legacy drivers that needed to work with old
pre-2.6.26 kernels. This is no longer relevant. Unfortunately, this op was
incorrectly called from several drivers.
Replace those occurences with proper i2c_board_info structs and call
v4l2_i2c_new_subdev_board.
After these changes v4l2_i2c_new_subdev_cfg() was no longer used, so remove
that function as well.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Due to a lack of a break inside the switch, it were getting the
wrong keytable and get_key function.
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (33 commits)
usb: don't use flush_scheduled_work()
speedtch: don't abuse struct delayed_work
media/video: don't use flush_scheduled_work()
media/video: explicitly flush request_module work
ioc4: use static work_struct for ioc4_load_modules()
init: don't call flush_scheduled_work() from do_initcalls()
s390: don't use flush_scheduled_work()
rtc: don't use flush_scheduled_work()
mmc: update workqueue usages
mfd: update workqueue usages
dvb: don't use flush_scheduled_work()
leds-wm8350: don't use flush_scheduled_work()
mISDN: don't use flush_scheduled_work()
macintosh/ams: don't use flush_scheduled_work()
vmwgfx: don't use flush_scheduled_work()
tpm: don't use flush_scheduled_work()
sonypi: don't use flush_scheduled_work()
hvsi: don't use flush_scheduled_work()
xen: don't use flush_scheduled_work()
gdrom: don't use flush_scheduled_work()
Fixed up trivial conflict in drivers/media/video/bt8xx/bttv-input.c
as per Tejun.
The audio input line was wrong. Fix it.
Cc: stable@kernel.org
I found that the problems people have reported with the USB-TV-stick
"Terratec Cinergy Hybrid T USB XS" (USB-ID: 0ccd:0042)
are coming from a wrong header file in the v4l-sources.
Attached is a diff, which fixes the problem (tested successfully here).
Obviously the USB-ID has been associated with a wrong chip: EM2880
instead of EM2882, which would be correct.
Reported-by: Philippe Bourdin <richel@AngieBecker.ch>
This device uses an em2874B + Sharp 921 One Seg frontend.
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
Video drivers request submodules using a work during probe and calls
flush_scheduled_work() on exit to make sure the work is complete
before being unloaded. This patch makes these drivers flush the work
directly instead of using flush_scheduled_work().
While at it, relocate request_submodules() call in saa7134_initdev()
right right before successful return as in other drivers to avoid
failing after the work is scheduled and returning failure without the
work still active.
This is in preparation for the deprecation of flush_scheduled_work().
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
The argument isn't used anymore by the functions, remove it.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
With the v4l2_i2c_new_subdev* functions now supporting loading modules
based on modaliases, replace the hardcoded module name passed to those
functions by NULL.
All corresponding I2C modules have been checked, and all of them include
a module aliases table with names corresponding to what the drivers
modified here use.
This patch allows this device successfully to show video, at least from
its composite input.
I have no information about the true hardware contents of this device and so
this patch is based solely on fiddling with things until it worked. The
chip appears to be em2860, and the closest device with equivalent inputs
is the Typhoon DVD Maker. Copying the settings for that device appears
to do the trick. That's what this patch does.
[mchehab@redhat.com: update CARDLIST.em28xx accordingly, via script]
Signed-off-by: Adrian Taylor <adrian.taylor@realvnc.com>
Reviewed-by: Jarod Wilson <jarod@redhat.com>
Signed-off-by: Michel Garnier <catimimi@orange.fr>
The probe method used by i2c_new_probed_device() may not be suitable
for all cases. Let the caller provide its own, optional probe
function.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
This adds support for the KWorld PlusTV 340U and KWorld UB345-Q ATSC
sticks, which are really the same device. The sticks have an eMPIA
em2870 usb bridge chipset, an LG Electronics LGDT3304 ATSC/QAM
demodulator and an NXP TDA18271HD tuner -- early versions of the 340U
have a a TDA18271HD/C1, later models and the UB435-Q have a C2.
The stick has been tested succesfully with both VSB_8 and QAM_256 signals.
Its using lgdt3304 support added to the lgdt3305 driver by a prior patch,
rather than the current lgdt3304 driver, as its severely lacking in
functionality by comparison (see said patch for details).
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com>
Instead of using the ugly keymap sequences, use the new rc-*.ko keymap
files. For now, it is still needed to have one keymap loaded, for the
RC code to work. Later patches will remove this depenency.
Replaces most of the occurences of IR keytables on V4L drivers by a macro
that evaluates to provide the name of the exported symbol.
Add support for design which has an em2863/tvp5150 and uses the standard
empia USB ID. In Sander's case, it was branded as an "Eminent model EM3705"
Thanks to Sander Van Ginkel for testing and help debugging the support.
[mchehab@redhat.com: move it to a vague card number slot (card=29)]
This patch adapts the changes submitted by Dainius Ridzevicius to the
linux-media mailing list on 8/14/09, to the current sources in order
to make the Kworld VS-DVB-T 323UR usb device work.
I also removed the "not validated" flag since I own the device and validated
that it works fine after the patch is applied.
Thanks to Devin Heitmueller for his guidance with the code.
Signed-off-by: Antonio Larrosa <larrosa@kde.org>
Acked-by: Devin Heitmueller <dheitmueller@kernellabs.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
I succeeded in running Cinergy Hybrid T USB XS FR in both modes.
Signed-off-by: Franklin Meng <fmeng2002@yahoo.com>
Adds digital and analogue tv support for Dikom DK300 hybrid usb card.
Not working: remote controller
To be done: it seems that with the proposed patch the digital demodulator
remains activated if the tuner is switched from digital to analogue mode.
Workaround is to unplug and replug the device when switching from digital to
analogue. If someone can explain how to verify the gpio settings using the
usbsnoop, the above issue perhaps can be resolved.
Signed-off-by: Andrea Amorosi <Andrea.Amorosi76@gmail.com>
As pointed by Magnus Alm <magnus.alm@gmail.com>, commit 99dbd128bb applied
a hunk at the wrong place. This patch moves the code to the right place.
fix Video/Sound support "Leadtek winfast tv usbii deluxe".
Now, it is working Stereo, IR, Radio, TV, Svideo and Composite.
USB2
This device uses an i2c chip to retrieve the keycode from a RC5 remote.
Instead of just getting 6 bits, improve the routine to get 11 bits.
This means that the complete RC5 table for Hauppauge Grey IR can be used
with this device.
Unfortunately, it seems that this IR receiver is not capable of getting
the full 14 (or 13 bits) from the RC5 protocol.
At lest now, with the new code, it is possible to replace this IR table
by another RC5 table.
Fix all device drivers to use the video_drvdata function instead of
maintaining a local list of minor to private data mappings. Call
video_set_drvdata to register the driver private pointer when not
already done.
Where applicable, the local list of mappings is completely removed when
it becomes unused.
[mchehab.redhat.com: removed tm6000 changes as tm6000 is not ready yet for submission even on staging]
Fix all device drivers to use the new video_device_node_name function.
This also strips kernel log messages from the "/dev/" prefix, has the device
node location is a userspace policy decision unknown to the kernel.
Modifies the IR table for HVR-950 to use the newer Hauppauge RC5 table,
and adds the RC5 address to the functions that get the scancode for this
device.
It is easy to add support for all other RC5 IR's on em2880 boards, but
the scancode table needs to be re-generated. So, keep using the old
7bits tables while we don't have all tables converted.
Also, the 7bits tables are still used on other drivers, so this small
patch needs to be ported to all drivers.
Adds support to VC211A em2800 card. As this board doesn't have eeprom,
and uses a common set of i2c address, it has no way to add any
autodetection for it.
The patch were tested by me and by Raimundo on his board. Thanks to
those tests, several bugs related to em2800 support were corrected.
for producing the usbsnoop dump, used to get the gpio's and allowing me
to remotelly access his machine and to the needed tests.
Thanks-to: Raimundo Eduvirgnes de Oliveira <eduvirgens@yahoo.com.br>
Upcoming I2C v4l2_subdev drivers need a way to control the subdevice
power state from the core. This use case is already partially covered by
the tuner s_standby operation, but no way to explicitly come back from
the standby state is available.
Rename the tuner s_standby operation to core s_power, and fix tuner
drivers accordingly. The tuner core will call s_power(0) instead of
s_standby(). No explicit call to s_power(1) is required for tuners as
they are supposed to wake up from standby automatically.
[mchehab@redhat.com: CodingStyle fix]
Recent fixes to the em28xx and saa7134 drivers have been overzealous.
While the ir-kbd-i2c platform data indeed needs to be persistent, the
struct i2c_board_info doesn't, as it is only used by i2c_new_device().
So revert a part of the original fixes, to save some memory.
Acked-by: Jarod Wilson <jarod@redhat.com>
