Since internal to v4l2 the ioctl prototype is the same regardless of it
being called through .ioctl or .unlocked_ioctl, we need to convert it all
to the long return type of unlocked_ioctl.
Thanks to Jean-Francois Moine for posting an initial patch for this and
thus bringing it to our attention.
Cc: Jean-Francois Moine <moinejf@free.fr>
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Introduce a struct v4l2_file_operations for v4l2 drivers.
Remove the unnecessary inode argument.
Move compat32 handling (and llseek) into the v4l2-dev core: this is now
handled in the v4l2 core and no longer in the drivers themselves.
Note that this changeset reverts an earlier patch that changed the return
type of__video_ioctl2 from int to long. This change will be reinstated
later in a much improved version.
dev_set_name()
This patch is part of a larger patch series which will remove
the "char bus_id[20]" name string from struct device. The device
name is managed in the kobject anyway, and without any size
limitation, and just needlessly copied into "struct device".
To set and read the device name dev_name(dev) and dev_set_name(dev)
must be used. If your code uses static kobjects, which it shouldn't
do, "const char *init_name" can be used to statically provide the
name the registered device should have. At registration time, the
init_name field is cleared, to enforce the use of dev_name(dev) to
access the device name at a later time.
We need to get rid of all occurrences of bus_id in the entire tree
to be able to enable the new interface. Please apply this patch,
and possibly convert any remaining remaining occurrences of bus_id.
We want to submit a patch to -next, which will remove bus_id from
"struct device", to find the remaining pieces to convert, and finally
switch over to the new api, which will remove the 20 bytes array
and does no longer have a size limitation.
Thanks,
Kay
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
The kernel number of a v4l2 node (e.g. videoX, radioX or vbiX) is now
independent of the minor number. So instead of using the minor field
of the video_device struct one has to use the num field: this always
contains the kernel number of the device node.
I forgot about this when I did the v4l2 core change, so this patch
converts all drivers that use it in one go. Luckily the change is
trivial.
Cc: michael@mihu.de
Cc: mchehab@infradead.org
Cc: corbet@lwn.net
Cc: luca.risolia@studio.unibo.it
Cc: isely@pobox.com
Cc: pe1rxq@amsat.org
Cc: royale@zerezo.com
Cc: mkrufky@linuxtv.org
Cc: stoth@linuxtv.org
video_drvdata(filp)
Use the new video_drvdata(filp) function where it is safe to do so.
While doing some testing using Luca Risolia's sonix driver I noticed that
the video device did not get ACL's set to allow access by locally logged in
users, nor does it show up as a video device in lshal, causing cheese to not
see it.
This turns out to be caused by all of Luca Risolia's drivers not setting
the parent member of the video_device struct. This patch fixes this.
Cc: Luca Risolia <luca.risolia@studio.unibo.it>
Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl>
The type and type2 fields were unused and so could be removed.
Instead add a vfl_type field that contains the type of the video
device.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
According to an old comment this should have been removed in 2.6.15.
Better late than never...
v4l2-common.h or v4l2-ioctl.h
The functions in a header should not belong to another module. The prio functions
belong to v4l2-common.c, so move them to v4l2-common.h.
The ioctl functions belong to v4l2-ioctl.c, so create a new v4l2-ioctl.h header
and move those functions to it.
The class_dev field is a normal device, not a class device. This is very
confusing and now that the old 'dev' field has been renamed to 'parent'
we can rename 'class_dev' to just 'dev'.
Use asm/byteorder.h instead.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Added macro CONFIG_COMPAT for v4l_compat_ioctl32.
Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com>
- Static memory is always initialized with 0.
- Replaced in some cases C99 comments for /* */
warnings
drivers/media/video/et61x251/et61x251_core.c:390: warning: 'et61x251_i2c_read' defined but not used
drivers/media/video/et61x251/et61x251_core.c:397: warning: 'et61x251_i2c_write' defined but not used
This patch makes the following needlessly global functions in
et61x251_core.c static:
- et61x251_read_reg()
- et61x251_i2c_try_read()
- et61x251_i2c_try_write()
- et61x251_i2c_read()
- et61x251_i2c_write()
Signed-off-by: Adrian Bunk <bunk@kernel.org>
struct video_device used to define a .hardware field. While
initialized on severl drivers, this field is never used inside V4L.
However, drivers using it need to include the old V4L1 header.
This seems to cause compilation troubles with some random configs.
Better just to remove it from all drivers.
The currently used "struct class_device" will be removed from the
kernel. Here is a patch that converts all users in drivers/media/video/
to struct device.
Reviewed-by: Thierry Merle <thierry.merle@free.fr>
Reviewed-by: Mike Isely <isely@pobox.com>
Reviewed-by: Luca Risolia <luca.risolia@studio.unibo.it>
Since at least kernel 2.6.12-rc2, module.h includes moduleparm.h. This
patch removes all occurences of moduleparm.h from drivers/media files.
- Make the driver depend on V4L2 only (KConfig)
- Better and safe locking mechanism of the device structure on open(),
close() and disconnect()
- Use kref for handling device deallocation
- Generic cleanups
Signed-off-by: Luca Risolia <luca.risolia@studio.unibo.it>
- Implement audio ioctl's and VIDIOC_ENUM_FRAMESIZES
- Documentation updates
- Generic improvements
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
[akpm@sdl.org: dvb fix]
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
The patch fix bug 5748.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
V4L core functions handle VIDIOC_*_OLD older ioctls.
Because of historic reasons, there are two separate directories with
V4L stuff. Most drivers are located at driver/media/video. However, some
code for USB Webcams were inserted under drivers/usb/media.
This makes difficult for module authors to know were things should be.
Also, makes Kconfig menu confusing for normal users.
This patch moves all V4L content under drivers/usb/media to
drivers/media/video, and fixes Kconfig/Makefile entries.
