Signed-off-by: Jean-François Moine <moinejf@free.fr>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Currently all probed sensor types are emitted in the kernel log, generating unnecessary noise. Be less verbose and only report what sensor is found (if any)
Signed-off-by: Erik Andrén <erik.andren@gmail.com>
Error handling code following a kmalloc should free the allocated data.
Acked-by: Erik Andrén <erik.andren@gmail.com>
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
The C99 specification states in section 6.11.5:
The placement of a storage-class specifier other than at the
beginning of the declaration specifiers in a declaration is an
obsolescent feature.
[mchehab@redhat.com: Fix a trivial merge conflict]
Cc: Erik Andrén <erik.andren@gmail.com>
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Signed-off-by: Lukas Karas <lukas.karas@centrum.cz>
init
Signed-off-by: Erik Andr?n <erik.andren@gmail.com>
All hail the static keyword
member
The power_down sensor struct member is almost has no purpose in the current driver abstraction. Remove it.
ctrls.
s5k83a sensor mounted on many acer laptops have a swiwel allowing it to be rotated. When the camera is in its rotated state, the image needs to be flipped. The only way to check for if the camera has been flipped is to continously poll a register in the m5602. This patch creates a kernel thread which does this. This patch renames some v4l2 ctrls and finally implements a cache in order to prevent unnecessary sensor reads.
Signed-off-by: Luk?? Karas <lukas.karas@centrum.cz>
Move over the v4l2 controls to the sensor specific source file.
Remove the now redundant sensor struct member.
By separating the supported for each sensor into a separate vector we can
eliminate the nmodes variable and instead calculate it at runtime.
Previously, all sensors allocated a part of a large ctrl vector.
Define this vector separately for each sensor instead.
This patch toggles the led seen on many laptops having a m5602 connected
to a Samsung s5k83a sensor.
Simplfy error handling by replacing goto statements with return equivalents.
anysee.c:44:5: warning: symbol 'dvb_usb_anysee_delsys' was not declared. Should it be static?
cx24116.c:378:3: warning: symbol 'CX24116_MODFEC_MODES' was not declared. Should it be static?
stb0899_algo.c:57:5: warning: symbol 'stb0899_get_srate' was not declared. Should it be static?
stb0899_algo.c:766:6: warning: symbol 'Log2Int' was not declared. Should it be static?
stb0899_drv.c:137:20: warning: symbol 'stb0899_quant_tab' was not declared. Should it be static?
stb0899_drv.c:180:20: warning: symbol 'stb0899_est_tab' was not declared. Should it be static?
stb0899_drv.c:220:5: warning: symbol '_stb0899_read_reg' was not declared. Should it be static?
budget-ci.c:1348:23: warning: symbol 'tt3200_stb6100_config' was not declared. Should it be static?
/home/v4l/master/v4l/cx25840-core.c:190:6: warning: symbol 'cx25840_work_handler' was not declared. Should it be static?
/home/v4l/master/v4l/m5602_s5k83a.c:116:6: warning: symbol 's5k83a_dump_registers' was not declared. Should it be static?
Convert the s5k83a sensor to use the common read_sensor function
Signed-off-by: Erik Andren <erik.andren@gmail.com>
Signed-off-by: Jean-Francois Moine <moinejf@free.fr>
This patch adds support for the ALi m5602 usb bridge and is based on
the gspca framework.
It contains code for communicating with 5 different sensors:
OmniVision OV9650, Pixel Plus PO1030, Samsung S5K83A, S5K4AA and
finally Micron MT9M111.
[mchehab@redhat.com: fix m5602/Makefile]
[mchehab@redhat.com: extern debug caused conflicts. Renamed to m5602_debug]
