The hdpvr's IR part, in short, sucks. As observed with a usb traffic
sniffer, the Windows software for it uses a polling interval of 405ms.
Its still not behaving as well as I'd like even with this change, but
this inches us closer and closer to that point...
Signed-off-by: Jarod Wilson <jarod@redhat.com>
The rc-hauppauge-new map is a messy thing, as it bundles 3
different remote controllers as if they were just one,
discarding the address byte. Also, some key maps are wrong.
With the conversion to the new rc-core, it is likely that
most of the devices won't be working properly, as the i2c
driver and the raw decoders are now providing 16 bits for
the remote, instead of just 8.
delete mode 100644 drivers/media/rc/keymaps/rc-hauppauge-new.c
Make the hdpvr's i2c master implementation more closely mirror that of
the pvrusb2 driver. Currently makes no significant difference in IR
reception behavior with ir-kbd-i2c (i.e., it still sucks).
We have to actually call i2c_new_device() once for each of the rx and tx
addresses. Also improve error-handling and device remove i2c cleanup.
Reviewed-by: Andy Walls <awalls@md.metrocast.net>
The current hdpvr code kmalloc's a new buffer for every i2c read and
write. Rather than do that, lets allocate a buffer in the driver's
device struct and just use that every time.
The size I've chosen for the buffer is the maximum size I could
ascertain might be used by either ir-kbd-i2c or lirc_zilog, plus a bit
of padding (lirc_zilog may use up to 100 bytes on tx, rounded that up
to 128).
Note that this might also remedy user reports of very sluggish behavior
of IR receive with hdpvr hardware.
v2: make sure (len <= (dev->i2c_buf)) [Jean Delvare]
Reported-by: Jean Delvare <khali@linux-fr.org>
Acked-by: Jean Delvare <khali@linux-fr.org>
A number of things going on here, but the end result is that the IR part
on the hdpvr gets enabled, and can be used with ir-kbd-i2c and/or
lirc_zilog.
First up, there are some conditional build fixes that come into play
whether i2c is built-in or modular. Second, we're swapping out
i2c_new_probed_device() for i2c_new_device(), as in my testing, probing
always fails, but we *know* that all hdpvr devices have a z8 chip at
0x70 and 0x71. Third, we're poking at an i2c address directly without a
client, and writing some magic bits to actually turn on this IR part
(this could use some improvement in the future). Fourth, some of the
i2c_adapter storage has been reworked, as the existing implementation
used to lead to an oops following i2c changes c. 2.6.31.
Earlier editions of this patch have been floating around the 'net for a
while, including being patched into Fedora kernels, and they *do* work.
This specific version isn't yet tested, beyond loading ir-kbd-i2c and
confirming that it does bind to the RX address of the hdpvr.
[mchehab@redhat.com: I2C_CLASS_TV_ANALOG is not defined. Fix compilation bug]
Acked-by: Andy Walls <awalls@md.metrocast.net>
Adds I2C registration of the Zilog Z8F0811 IR microcontroller for either
lirc_zilog or ir-kbd-i2c to use. This is a required step in removing
lirc_zilog's use of the deprecated struct i2c_adapter.id field.
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
Detection class I2C_CLASS_TV_ANALOG is set by a few adapters but no
I2C device driver is setting it anymore, which means it can be
dropped. I2C devices on analog TV adapters are instantiated
explicitly these days, which is much better.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
There is no point in defining I2C adapter IDs when no code is using
them. As this field might go away in the future, stop using it when
we don't need to.
Signed-off-by: Janne Grunau <j@jannau.net>
The device encodes component video up to 1080i to a MPEG-TS stream with
H.264 video and stereo AAC audio. Newer firmwares accept also AC3
(up to 5.1) audio over optical SPDIF without reencoding.
Firmware upgrade is unimplemeted but rather unimportant since
the firmware sits on a flash chip.
The I2C adapter to drive the integrated infrared receiver/sender is
currently disabled due to a conflict with cx18-based devices.
Tested-by: Jarod Wilson <jarod@redhat.com>
