path: root/drivers/media/video/hexium_gemini.c
2010-12-30[media] v4l: fix handling of v4l2_input.capabilitiesHans Verkuil
The v4l core sets the v4l2_input.capabilities field based on the supplied v4l2_ioctl_ops. However, several drivers do a memset or memcpy of the v4l2_input struct, thus overwriting that field incorrectly. Either remove the memset (which is already done by the v4l core), or add the proper capabilities field in case of a memcpy. The same is also true for v4l2_output, but that only affected the ivtv driver. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21[media] i2c: Stop using I2C_CLASS_TV_ANALOGJean Delvare
Detection class I2C_CLASS_TV_ANALOG is set by a few adapters but no I2C device driver is setting it anymore, which means it can be dropped. I2C devices on analog TV adapters are instantiated explicitly these days, which is much better. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-06V4L/DVB: saa7146: fix regression of the av7110/budget-av driverHans Verkuil
An earlier regression fix for the mxb driver (V4L/DVB: saa7146_vv: fix regression where v4l2_device was registered too late) caused a new regression in the av7110 driver. Reverted the old fix and fixed the problem in the mxb driver instead. Tested on mxb and budget-av cards. The real problem is that the saa7146 framework has separate probe() and attach() driver callbacks which should be rolled into one. This is now done for the mxb driver, but others should do the same. Lack of hardware makes this hard to do, though. I hope to get hold of some hexium cards and then I can try to improve the framework to prevent this from happening again. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: saa7146_vv: fix regression where v4l2_device was registered too lateHans Verkuil
v4l2_device_register needs to be called before the i2c subdevs are loaded. However, it was called afterwards in the saa7146 driver. This caused an oops when loading the mxb and hexium drivers. The vv_init function is now split into two: one registers the v4l2_device, the other does the rest of the initialization. The three drivers that depend on this have been updated to call the new vv_devinit function. Thanks to Michael Hunold for reporting this. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13241): Cleanup redundant tests on unsignedRoel Kluin
The variables are unsigned so the test `>= 0' is always true, the `< 0' test always fails. In these cases the other part of the test catches wrapped values. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB: cleanup redundant tests on unsignedRoel Kluin
Remove redundant tests on unsigned. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10271): saa7146: convert to video_ioctl2.Hans Verkuil
The conversion to video_ioctl2 is the first phase to converting this driver to the latest v4l2 framework. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10138): v4l2-ioctl: change to long return type to match unlocked_ioctl.Hans Verkuil
Since internal to v4l2 the ioctl prototype is the same regardless of it being called through .ioctl or .unlocked_ioctl, we need to convert it all to the long return type of unlocked_ioctl. Thanks to Jean-Francois Moine for posting an initial patch for this and thus bringing it to our attention. Cc: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-04-24V4L/DVB (7094): static memoryDouglas Schilling Landgraf
- Static memory is always initialized with 0. - Replaced in some cases C99 comments for /* */ Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3537a): Whitespace cleanupMauro Carvalho Chehab
2006-01-11V4L/DVB (3344a): Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to k(z|c)alloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
