Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
If the firmware has failed, this patch will automatically reload &
restart the card. The previous card state will be restored on a
successful restart. Firmware reload will only happen if neither the
encoder or decoder is active. If the card is busy then behaviour is as
before, returning -EIO on device access until the reload can occur. On
cards that support video output, coloured bars will be displayed during
the reload.
Andy Walls (ivtv maintainer and patch committer) made minor tweaks to
comments and the logged messages, but nothing substantial otherwise.
Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk>
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
>From Ian's e-mail:
When a device is opened the firmware state will be checked. If it isn't
responding then the open will fail with -EIO. Due to the nature of the
hardware, a single failed check will block everything since we don't know
exactly what has failed. A side effect of this is the blocking of debug
access, so an additional debug level has been created which allows the block
to be bypassed.
Andy Walls' modifications:
I modified Ian's patch to add a separate fw_debug module parameter to change
the driver's behavior, as opposed to using the normal debug module parameter.
The fw_debug module parameter is only available when CONFIG_VIDEO_ADV_DEBUG
is set.
I also made some minor whitespace adjustments and changed some warning
messages to be a bit more specific. s/happy/glad/g
Added small delay on device open & close to allow hardware to settle. Move yuv
register restore to before the decoder firmware call to stop playback.
v4l2_prio_init/open/close returned an int when in fact they would
always return 0. Make these void functions.
v4l2_prio_close and v4l2_prio_check pass an enum v4l2_priority as a
pointer for no good reason. Replace with a normal enum v4l2_priority
argument.
These changes will simplify the work of moving priority handling into
the v4l core.
Instead of using the minor number in kernel log messages, use the device
node name as returned by the video_device_node_name() function. This
makes debug, informational and error messages easier to understand for
end users.
[mchehab.redhat.com: removed tm6000 changes as tm6000 is not ready yet for submission even on staging]
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
v4l2_subdev.
With all the v4l2_subdev changes that were made to these drivers it is a
good idea to increase the version number of each driver.
It's just the patch level that is increased, except for the zoran and saa7146
drivers where the minor number was increased due to the more substantial
changes that were made to those two drivers.
s_std didn't belong in the tuner ops. Stricly speaking it should be part of
the video ops, but it is used by audio and tuner devices as well, so it is
more efficient to make it part of the core ops.
Use consistent naming for pci_dev, v4l2_device and video_device.
Initial addition of controls to set AC-3 audio encoding for the CX23418 - it
does not work yet due to firmware or cx18 driver issues. This change affects
the common cx2341x and ivtv modules due to shared structures and
common functions.
Signed-off-by: Andy Walls <awalls@radix.net>
Introduce a struct v4l2_file_operations for v4l2 drivers.
Remove the unnecessary inode argument.
Move compat32 handling (and llseek) into the v4l2-dev core: this is now
handled in the v4l2 core and no longer in the drivers themselves.
Note that this changeset reverts an earlier patch that changed the return
type of__video_ioctl2 from int to long. This change will be reinstated
later in a much improved version.
Modifies behaviour of a failed dma write() operation for the yuv device.
If the dma transfer for the yuv device fails, the write() operation will now
exit immediately.
The service_set field was used in saa7115 and cx25840 to determine
whether raw or sliced VBI was desired. This is incorrect since it is
perfectly valid to select sliced VBI with a service_set of 0.
Instead these drivers should checked on VIDIOC_S_FMT whether the type
field matches the raw or sliced VBI type.
Updated ivtv accordingly.
ivtv_claim_stream() can now become static.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
write() operations to the yuv device may not always 'start' the decoder.
Although yuv output will be correct, some functions which should be disabled
while the decoder is in use remain enabled. This can result in hardware
registers being corrupted, causing problems with the mpeg decoder. This patch
simply moves the existing decoder 'start' sequence to earlier in the write()
handler.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Upon error conditions in cx18/ivtv_probe(), the code at the 'err:' label
leaves a NULL entry in cx18/ivtv_cards[]. This can cause a NULL pointer
de-reference in cx18/ivtv_v4l2_open() which is fixed by this patch.
The functions time_before, time_before_eq, time_after, and time_after_eq
are more robust for comparing jiffies against other values.
A simplified version of the semantic patch making this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@ change_compare_np @
expression E;
- jiffies <= E
+ time_before_eq(jiffies,E)
- jiffies >= E
+ time_after_eq(jiffies,E)
- jiffies < E
+ time_before(jiffies,E)
- jiffies > E
+ time_after(jiffies,E)
@ include depends on change_compare_np @
@ no_include depends on !include && change_compare_np @
#include <linux/...>
+ #include <linux/jiffies.h>
// </smpl>
The q_io queue was never taken into account by the poll function. Thanks to
Andy Walls for finding this bug.
IVTV_IOC_DMA_FRAME framework
Previously, all yuv data written to /dev/video48 had only basic support with
no double buffering to avoid display tearing.
With this patch, yuv frames written to video48 are now handled by the existing
IVTV_IOC_DMA_FRAME framework. As such, the frames are hardware buffered to
avoid tearing, and honour scaling mode & field order options. Unlike the
proprietary IVTV_IOC_DMA_FRAME ioctl, all parameters are controlled by the
V4L2 API.
Due to mpeg & yuv output restrictions being different, their V4L2 output
controls have been separated. To control the yuv output, the V4L2 calls must
be done via video48.
If the ivtvfb module is loaded, there will be one side effect to this merge.
The yuv output window will be constrained to the visible framebuffer area. In
the event that a virtual framebuffer size is being used, the limit to the
output size will be the virtual dimensions, but only the portion that falls
within the currently visible area of the framebuffer will be shown.
Like the IVTV_IOC_DMA_FRAME ioctl, the supplied frames must be padded to 720
pixels wide. However the height must only be padded up the nearest multiple
of 32. This would mean an image of 102 lines must be padded to 128. As long
as the true source image size is given, the padding will not be visible in
the final output.
Currently the yuv output stream buffer is divided into blocks whose size
depend on the broadcast standard selected during the driver init phase.
However, the standard can be changed after the init phase. This effectively
breaks the yuv output stream handler, since it relies on the different yuv
planes being block aligned.
This patch changes the setup, so that the block size is always the same. The
decoder dma function has been modified to cope with the fact that the second
yuv plane may no longer be block aligned. The start of the yuv frame must
still be at the beginning of a block, so the stream write function has also
been modified to ensure this is always true.
Also, the stream write function will now initiate a yuv dma transfer as soon
as a full frame is ready. It will not wait until the current write request
has completed, or the stream buffer becomes full.
Trying to open the radio when a capture is in progress will make it
impossible to open the radio again since the radio stream wasn't released.
We shouldn't dereference "itv" when we know it's NULL...
Spotted by the Coverity checker.
Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl>
Besides some VBI cleanups this patch also fixes a subtle problem with the
VBI re-insertion stream where the PIO work handler wasn't called quickly
enough, resulting in occasional corrupt data.
Furthermore the CC output didn't disable CC correctly and at the right time,
causing duplicates to be sent.
An saa7127 fix for VPS output was also added: the wrong data was sent.
Support for V4L2_ENC_CMD_STOP_AT_GOP_END was broken. While the driver
correctly waited for the card to capture until the GOP was complete,
afterwards the driver buffers were just flushed instead of waiting
for the application to read all the pending data.
into ivtv-routing.c
- add guards
- remove unused header includes
- move card-specific stuff from ivtv-driver.h to ivtv-cards.h
- move YUV-specific stuff from ivtv-driver.h to ivtv-yuv.h
- Always clear when stopping the decoder
- Clear if the filehandle that is being close was used for UDMA_YUV output.
Serialization is now done on the open/close/ioctl level and also when the
read/write/poll start an encoder/decoder stream.
- add FILE debug flag for open/close/read/write/poll.
- show cmd for encoder/decoder command ioctl.
When there are no more free buffers, then buffers are stolen from the
predma queue. Buffers should be stolen from the head of that queue (which
is where the most recently added buffers are) and all buffers belonging
to a frame should be stolen. Otherwise 'half-frames' would remain in the
queue, which leads to ugly playback and complete sync failure for YUV
buffers.
The CX2341X_ENC_INITIALIZE_INPUT firmware call requires careful handling,
otherwise the computer can freeze or the top-third of the screen can start
flickering. This patch ensures that CX2341X_ENC_INITIALIZE_INPUT is called
at the right time and in the right way.
In addition the stop capture handling was improved so that the last pending
DMA transfer is also processed. Otherwise this would be the first data that
arrived when a new capture was started which is not what you want.
When changing channels the audio has to be muted. This is done
by calling CX2341X_ENC_MUTE_AUDIO and by muted the audio input.
The latter is not necessary and is now removed.
ivtv-fb: initializing the framebuffer should trigger ivtv firmware load
The firmware is now loaded when the driver is actually used for the first
time. This allows the driver to be compiled in-kernel instead of as a module.
Using udma yuv causes the driver becomes locked into that mode. This prevents
use of the mpeg decoder & non-udma yuv output. This patch clears the
operating mode when the device is closed.
Due to a documentation bug (the type mask is 3 bits long, not 2) the wrong
frame types were filled in: the B and P frame types were swapped.
This bug also hid a second bug: when a capture is stopped a last entry is
written into the pgm index buffer with internal type 0, denoting the end
of the program. This entry wasn't ignored, instead it was accidentally
returned to the caller as a P frame.
While decoding (MPEG or YUV) is active or when VBI output is in use, then
do not clear the VBI output of the saa7127. Only after the last user is
gone can we clear it.
This fixes the case where playback was stopped, another channel was chosen
and playback was restarted, while /dev/vbi16 was used to set the WSS
(widescreen) setting. Without this fix the WSS was reset on every stop
instead of just keeping the last value.
Pausing a decoder followed by a Play command would do nothing. Fixed.
Pausing a decoder running at non-standard speed following by a Continue
would reset the speed to 100%. Fixed.
Add support for high volume debug messages, allowing them to be turned
on selectively.
Signed-off-by: Jose Alberto Reguero <jareguero@telefonica.net>
Replace the call to MINOR() with a call to the inline iminor()
routine.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Acked-by: Hans Verkuil <hverkuil@xs4all.nl>
