Rename all PCI drivers with their own directory under
drivers/media/video into drivers/media/pci and update the
building system.
After discussing with Andy Walls on irc, we've agreed that this
is the best thing to do. No regressions will be introduced, as 3.x.y
is greater then the current versions for cx18 and ivtv.
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Since for 2.6.27 ivtvfb uses DMA for write it is important that
you can identify which ivtv version supports this and which doesn't.
Increase the version number so we can tell the difference.
Thanks to Ian Armstrong for pointing this out to me.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
- add guards
- remove unused header includes
- move card-specific stuff from ivtv-driver.h to ivtv-cards.h
- move YUV-specific stuff from ivtv-driver.h to ivtv-yuv.h
It took three core maintainers, over four years of work, eight new i2c
modules, eleven new V4L2 ioctls, three new DVB video ioctls, a Sliced
VBI API, a new MPEG encoder API, an enhanced DVB video MPEG decoding
API, major YUV/OSD contributions from Ian and John, web/wiki/svn/trac
support from Axel Thimm, (hardware) support from Hauppauge, support and
assistance from the v4l-dvb people and the many, many users of ivtv to
finally make it possible to merge this driver into the kernel.
Thank you all!
Signed-off-by: Kevin Thayer <nufan_wfk@yahoo.com>
Signed-off-by: Chris Kennedy <c@groovy.org>
Signed-off-by: John P Harvey <john.p.harvey@btinternet.com>
Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk>
