Internally separates the setting of the broadcast standard for the encoder &
decoder. Externally there's no change in functionality.
[awalls@md.metrocast.net: Edited to fix a checkpatch gripe about multiple
assignment and to remove a now unused DEFINE_WAIT() due to this patch]
Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk>
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
Add sanity check to ivtvfb_pan_display() to ensure only valid values are used
to pan the display. Invalid values are rejected with -EINVAL
We must not use any information in the passed var besides xoffset,
yoffset and vmode as otherwise applications might abuse it. Also use the
aligned fix.line_length and not the (possible) unaligned xres_virtual.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Reviewed-by: Ian Armstrong <ian@iarmst.demon.co.uk>
The FBIOGET_VBLANK device ioctl allows unprivileged users to read 16
bytes of uninitialized stack memory, because the "reserved" member of
the fb_vblank struct declared on the stack is not altered or zeroed
before being copied back to the user. This patch takes care of it.
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
Stanse found that in ivtvfb_callback_cleanup and ivtvfb_callback_init
there are unneeded tests for itv being NULL. But itv is initialized
as container_of with non-zero offset in those functions, so it is
never NULL (even if v4l2_dev is). This was found because itv is
dereferenced earlier than the test.
Reviewed-by: Andy Walls <awalls@md.metrocast.net>
If the firmware has failed, this patch will automatically reload &
restart the card. The previous card state will be restored on a
successful restart. Firmware reload will only happen if neither the
encoder or decoder is active. If the card is busy then behaviour is as
before, returning -EIO on device access until the reload can occur. On
cards that support video output, coloured bars will be displayed during
the reload.
Andy Walls (ivtv maintainer and patch committer) made minor tweaks to
comments and the logged messages, but nothing substantial otherwise.
Check firmware state when loading module & if firmware is not responding exit
with an error. When module is unloaded, only disable the framebuffer & not all
decoder output.
address
Get rid of the magic number 0x28c0 used in several places in the ivtv and
ivtvfb driver and define the register address to a meaningful name.
Signed-off-by: Andy Walls <awalls@radix.net>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Found the coccinelle tool.
Thanks-to: Julia Lawall <julia@diku.dk>
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Use consistent naming for pci_dev, v4l2_device and video_device.
When using FBIOBLANK, FB_BLANK_POWERDOWN will now switch off the video output.
Since some televisions turn themselves off after a while with no signal, this
is the closest we can get to power-saving.
Fix casts of pointers to integers of different sizes in the ivtv framebuffer
driver.
These were introduced in patch 38eb6ba5b8487d15b020fe391d324edd2b659b03.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Completely rely on the video_ioctl2 debugging facilities rather than
doing it ourselves.
Fill in some missing fields in ivtv with VIDIOC_G_FBUF.
write() operations to the ivtv framebuffer will now attempt to use DMA if the
amount of data to copy is >= 4096 bytes. This change effectively depreciates
the need for the proprietary IVTVFB_IOC_DMA_FRAME ioctl since a write() of
sufficient size will do the same thing.
- don't show kernel backtrace when the allocation of the buffers fails: the
normal ivtv/cx18 messages are clear enough and the backtrace scares users.
- fix cleanup after the buffer allocation fails (caused kernel panic).
Fix "warning: Using plain integer as NULL pointer".
Convert 'x < y ? x : y' to use min() instead.
Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se>
IVTV_IOC_DMA_FRAME framework
Previously, all yuv data written to /dev/video48 had only basic support with
no double buffering to avoid display tearing.
With this patch, yuv frames written to video48 are now handled by the existing
IVTV_IOC_DMA_FRAME framework. As such, the frames are hardware buffered to
avoid tearing, and honour scaling mode & field order options. Unlike the
proprietary IVTV_IOC_DMA_FRAME ioctl, all parameters are controlled by the
V4L2 API.
Due to mpeg & yuv output restrictions being different, their V4L2 output
controls have been separated. To control the yuv output, the V4L2 calls must
be done via video48.
If the ivtvfb module is loaded, there will be one side effect to this merge.
The yuv output window will be constrained to the visible framebuffer area. In
the event that a virtual framebuffer size is being used, the limit to the
output size will be the virtual dimensions, but only the portion that falls
within the currently visible area of the framebuffer will be shown.
Like the IVTV_IOC_DMA_FRAME ioctl, the supplied frames must be padded to 720
pixels wide. However the height must only be padded up the nearest multiple
of 32. This would mean an image of 102 lines must be padded to 128. As long
as the true source image size is given, the padding will not be visible in
the final output.
Due to changes in the core ivtv driver as of release 1.0, the osd_compat
module option has been rendered obsolete. This patch removes the option and
all code associated with it.
Prevent unloading the framebuffer if it is still in use.
This patch partially reverts a previous change that caused the
CX2341X_OSD_SET_PIXEL_FORMAT firmware calls to be skipped when the pixel
format of the framebuffer wasn't altered by FBIOPUT_VSCREENINFO.
Unfortunately, another firmware call on the PVR350 sometimes scrambles the
display when trying to adjust the framebuffer settings. This patch re-enables
the CX2341X_OSD_SET_PIXEL_FORMAT calls to try and prevent this from
occurring.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
ivtvfb: replace ivtv_fb prefix to ivtvfb, change warning to info message
The convention for framebuffer devices is to call them xxxfb, not xxx-fb.
Conform to this. Also move the ivtvfb.h header to include/linux: it is a
public header. The FBIO_WAITFORVSYNC ioctl is now also defined in the
ivtvfb.h header, no more need to include matroxfb.h for just this ioctl.
