Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Remove the EXPERIMENTAL tag.
ivtv used tvaudio in the past and at the time tvaudio required V4L1.
Since tvaudio is no longer dependent on V4L1 and since ivtv actually
no longer uses tvaudio at all, this is no removed from Kconfig.
Without this patch ivtv won't be build if V4L1 is disabled.
inode is never used on video_ioctl2. Remove it and rename the function to
__video_ioctl2. This allows its usage directly as a callback at
fops.unlocked_ioctl.
Since we still need a callback with inode to be used with fops.ioctl,
this patch adds video_ioctl2() that is just a call to __video_ioctl2().
Also, this patch adds some comments about video_ioctl2 and __video_ioctl2
usage at v4l2-ioctl.h.
When using FBIOBLANK, FB_BLANK_POWERDOWN will now switch off the video output.
Since some televisions turn themselves off after a while with no signal, this
is the closest we can get to power-saving.
Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk>
When loading ivtv the TV-out of the PVR-350 will flash green since the
saa712x is activated before the MPEG decoder has been initialized.
Deactivate the saa712x until the MPEG decoder has been initialized.
Signed-off-by: Martin Dauskardt <martin.dauskardt@gmx.de>
A consolidated implementation will provide this generically through
asm/byteorder, remove direct includes to avoid breakage when the
changeover to the new implementation occurs.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Acked-by: "Paul E. McKenney" <paulmck@us.ibm.com>
image height
Ian Armstrong pointed out to me that it is perfectly valid to have a
576 lines YUV video with NTSC output in this particular case. In fact,
without this the X driver for ivtv does not function properly.
Reverted my earlier change that restrictred the height to 480 for NTSC
and add the comments provided by Ian to explain what is happening here.
Thanks-to: Ian Armstrong <ian@iarmst.co.uk>
Modifies behaviour of a failed dma write() operation for the yuv device.
If the dma transfer for the yuv device fails, the write() operation will now
exit immediately.
Modified yuv register update handling to remove a potential race condition
which could occur with the first video frame.
Also removed a forced yuv position update, since changing the source video
dimensions or interlace settings doesn't affect the frame already being
displayed.
When the framebuffer format was queried via VIDIOC_G_FBUF,
V4L2_FBUF_FLAG_OVERLAY would only be correctly returned for certain screen
depths.
The service_set field was used in saa7115 and cx25840 to determine
whether raw or sliced VBI was desired. This is incorrect since it is
perfectly valid to select sliced VBI with a service_set of 0.
Instead these drivers should checked on VIDIOC_S_FMT whether the type
field matches the raw or sliced VBI type.
Updated ivtv accordingly.
Suggested by Martin Dauskardt. This is conform what the other drivers do.
The v4l core creates four different video devices (video, vbi, radio, vtx)
and each has its own range of minor numbers. However, modern devices keep
increasing the number of devices that they need so a maximum of 64 video
devices will not be enough in the future. In addition this scheme makes
it very hard to add new device types.
This patch disconnects the kernel number allocation (e.g. video0, video1,
etc.) from the actual minor number (just pick the first free minor).
This allows for much more flexibility in the future. However, it does
require the use of udev. For those who cannot use udev a new CONFIG option
was created that changes the allocation scheme back to the old behavior.
Thanks to Greg KH for suggesting this approach during the 2008 LPC.
In addition, several bugs were fixed in the ivtv and cx18 drivers: these
drivers try to allocate specific kernel numbers but that scheme contained
a bug which caused what should have been e.g. video17 to appear as e.g.
video2.
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
video out fmt fixes
- V4L2_CAP_VBI_OUTPUT is not supported by ivtv, remove it.
- ivtv_try_fmt_vid_out also needed to constrain the width/height of MPEG decoder
window sizes.
- allow empty sliced services.
It was possible to set out-of-bounds windows sizes, this is now
fixed.
BIT define conflicts on kernels < 2.6.24, byteorder/swab.h doesn't need
to be included at all.
ivtv_claim_stream() can now become static.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Use "[%04x:%04x]" for PCI vendor/device IDs to follow the format
used by lspci(8).
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
- change the work-queue to a single threaded high prio workqueue
- use DMA instead of PIO for the sliced VBI data.
- remove some incorrect tests
- increase the internal VBI capture queue size for sliced VBI packets
- ignore duplicate VBI lines
With these changes it should finally be possible to get reliable closed
captions.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Since for 2.6.27 ivtvfb uses DMA for write it is important that
you can identify which ivtv version supports this and which doesn't.
Increase the version number so we can tell the difference.
Thanks to Ian Armstrong for pointing this out to me.
After commit d9b19199e4894089456aaad295023263b5225c1a
(always enable FW_LOADER unless EMBEDDED=y) we can remove
the FW_LOADER select's and corresponding dependencies
on HOTPLUG.
The type and type2 fields were unused and so could be removed.
Instead add a vfl_type field that contains the type of the video
device.
struct
All ioctl callbacks are now stored in a new v4l2_ioctl_ops struct. Drivers fill in
a const struct v4l2_ioctl_ops and video_device just contains a const pointer to it.
This ensures a clean separation between the const ops struct and the non-const
video_device struct.
has_ir was set to and compared to -1 in several cases, even though it is
an u32. ivtv also contained a FIXME for an old kernel that could be
removed.
Thanks to Roel Kluin for creating an initial patch for this. Although
I chose a different solution here it did help in pointing out the problem.
v4l2-common.h or v4l2-ioctl.h
The functions in a header should not belong to another module. The prio functions
belong to v4l2-common.c, so move them to v4l2-common.h.
The ioctl functions belong to v4l2-ioctl.c, so create a new v4l2-ioctl.h header
and move those functions to it.
The field 'dev' is not the video device, but the parent of the video device.
Rename accordingly.
The saa7127 driver supports all of SAA7126, SAA7127, SAA7128 and
SAA1729 devices. Declare all these devices, so that board drivers can
tell which device is present, instead of always relying on
auto-detection (which needs to write to the chip, eek!).
We still need the detection for ivtv, so a special device name
"saa7127_auto" can be used when the caller doesn't know exactly which
device is present.
Fix casts of pointers to integers of different sizes in the ivtv framebuffer
driver.
These were introduced in patch 38eb6ba5b8487d15b020fe391d324edd2b659b03.
Also remove some blank lines that were used to split compat code at -devel
tree.
rules.
without eeprom.
through s/g_ext_ctrl
videodev converts old-style controls to an extended control so the ivtv and
cx18 drivers no longer have to handle both.
not defined.
Thanks to Randy Dunlap for reporting this.
The cx18 can support transport streams with newer firmwares. Add a TS
capability to the generic cx2341x module.
Completely rely on the video_ioctl2 debugging facilities rather than
doing it ourselves.
Fill in some missing fields in ivtv with VIDIOC_G_FBUF.
The IVTV_IOC_DMA_FRAME ioctl fails to correctly 'start' the decoder. Although
yuv output will be correct, some functions which should be disabled while the
decoder is in use remain enabled. This can result in hardware registers being
corrupted, causing problems with the mpeg decoder. This patch ensures the
decoder 'start' sequence is called, disabling these functions until the
device is closed.
write() operations to the yuv device may not always 'start' the decoder.
Although yuv output will be correct, some functions which should be disabled
while the decoder is in use remain enabled. This can result in hardware
registers being corrupted, causing problems with the mpeg decoder. This patch
simply moves the existing decoder 'start' sequence to earlier in the write()
handler.
If the capture is scaled, then the video_temporal_filter is set to 0
by the cx2341x.c module since otherwise you would get ghosting.
However, this was also done in the VIDIOC_S_FMT ioctl which meant that
the video_temporal_filter control was reset to 0 or 8 each time S_FMT
was called. This was old code that should have been removed a long time
ago.
Based on an initial conversion patch from Douglas Landgraf.
Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com>
Separate gpio_init field and xceive_pin and combine the two when
the gpio is initialized. So there is no longer any need to set the
xceive pin in the gpio_init values, simplifying the creation of a
new card definition.
