commit 0310871d8f71da4ad8643687fbc40f219a0dac4d upstream.
The switch to the new control framework caused a regression where the audio was
no longer unmuted after the carrier scan finished.
The original code attempted to set the volume control to its current value in
order to have the set-volume control code to be called that handles the volume
and muting. However, the framework will not call that code unless the new volume
value is different from the old.
Instead we now call msp_s_ctrl directly.
It is a bit of a hack: we really need a v4l2_ctrl_refresh_ctrl function for this
(or something along those lines).
Thanks to Andy Walls for bisecting this and to Shane Shrybman for reporting it!
Reported-by: Shane Shrybman <shrybman@teksavvy.com>
Thanks-to: Andy Walls <awalls@md.metrocast.net>
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
It is no longer needed to use a struct pointer as argument, since v4l2_subdev
doesn't require that ioctl-like approach anymore. Instead just pass the input,
output and config (new!) arguments directly.
s_std didn't belong in the tuner ops. Stricly speaking it should be part of
the video ops, but it is used by audio and tuner devices as well, so it is
more efficient to make it part of the core ops.
All drivers that use msp3400 now use v4l2_subdev, so we can remove the
legacy code from msp3400.
There are no drivers left that call msp3400 with V4L1 commands. Remove it
from this driver.
The v4l2_ctrl_query_fill_std() function wasn't one the best idea I ever had.
It doesn't add anything valuable that cannot be expressed equally well with
v4l2_ctrl_query_fill and only adds overhead.
Replace it with v4l2_ctrl_query_fill() everywhere it is used and remove it
from v4l2_common.c.
instead of ID.
Since the i2c driver ID will be removed in the near future we have to
modify the v4l2 debugging API to use the driver name instead of driver ID.
Note that this API is not used in applications other than v4l2-dbg.cpp
as it is for debugging and testing only.
Should anyone use the old VIDIOC_G_CHIP_IDENT, then this will be logged
with a warning that it is deprecated and will be removed in 2.6.30.
Since internal to v4l2 the ioctl prototype is the same regardless of it
being called through .ioctl or .unlocked_ioctl, we need to convert it all
to the long return type of unlocked_ioctl.
Thanks to Jean-Francois Moine for posting an initial patch for this and
thus bringing it to our attention.
Cc: Jean-Francois Moine <moinejf@free.fr>
possible
Several V4L2 drivers still included videodev.h. Fix this.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
v4l2-common.h or v4l2-ioctl.h
The functions in a header should not belong to another module. The prio functions
belong to v4l2-common.c, so move them to v4l2-common.h.
The ioctl functions belong to v4l2-ioctl.c, so create a new v4l2-ioctl.h header
and move those functions to it.
Also remove some blank lines that were used to split compat code at -devel
tree.
Update all the remaining new-style i2c drivers to use standard module
aliasing instead of the old driver_name/type driver matching scheme.
Note that the tuner driver is a bit quirky at the moment, as it
overwrites i2c_client.name with arbitrary strings. We write "tuner"
back on remove, to make sure that driver cycling will work properly,
but there may still be troublesome corner cases.
Based on earlier work by Jon Smirl and Jochen Friedrich.
This patch allows new-style i2c chip drivers to have alias names using
the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this
point, the old i2c driver binding scheme (driver_name/type) is still
supported.
Cc: Jochen Friedrich <jochen@scram.de>
Cc: Jon Smirl <jonsmirl@gmail.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
VIDEO_V4L2_COMMON=m
This patch removes zoran checks for VIDEO_V4L2, since this API is always
present, when V4L is selected.
If the chip isn't recognized, then the correct errors should be returned.
The v4l2_i2c_attach() utility function will return 0 for all errors
except -ENOMEM to provide proper compatibility support for the old I2C
probing function.
There were many instances of 7-space indents spread throughout
the v4l-dvb tree.
This patch replaces the 7-space indents with tabs. The whitespace cleaner
script doesn't catch these, because it assumes that all indents are 8-space.
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl>
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc).
Here is a short excerpt of the semantic patch performing
this transformation:
type T2;
expression x;
identifier f,fld;
expression E;
expression E1,E2;
expression e1,e2,e3,y;
statement S;
x =
- kmalloc
+ kzalloc
(E1,E2)
... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\)
- memset((T2)x,0,E1);
expression E1,E2,E3;
- kzalloc(E1 * E2,E3)
+ kcalloc(E1,E2,E3)
[akpm@linux-foundation.org: get kcalloc args the right way around]
Signed-off-by: Yoann Padioleau <padator@wanadoo.fr>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Acked-by: Russell King <rmk@arm.linux.org.uk>
Cc: Bryan Wu <bryan.wu@analog.com>
Acked-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Dave Airlie <airlied@linux.ie>
Acked-by: Roland Dreier <rolandd@cisco.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Acked-by: Pierre Ossman <drzeus-list@drzeus.cx>
Cc: Jeff Garzik <jeff@garzik.org>
Acked-by: Greg KH <greg@kroah.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Replace assignments to "current->state" with the preferred calls to
schedule_timeout_interruptible().
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Returning -1 causes the probe to stop, but it should just continue
instead.
The return value of kthread_run() should be checked by IS_ERR().
The wrong matrix was used when an external input was selected instead of
the tuner input. The rxsubchans field was also not initialized to STEREO
for an external input. And finally the msp34xxg_detect_stereo() should
not try to detect stereo for an external input, that code is for the
tuner input only.
Together these bugs made it hit 'n miss whether you ever got stereo out
of the msp3400 for an external input.
Move process freezing functions from include/linux/sched.h to freezer.h, so
that modifications to the freezer or the kernel configuration don't require
recompiling just about everything.
[akpm@osdl.org: fix ueagle driver]
Signed-off-by: Nigel Cunningham <nigel@suspend2.net>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Pavel Machek <pavel@ucw.cz>
The msp3430G and msp3435G models cannot do Automatic Standard Detection.
So these should be forced to BTSC. These chips are early production versions
for the msp34xxG series and are quite rare.
The workaround for kernel 2.6.18 is to use 'standard=32' as msp3400
module option. Due to broken handling of the 'standard' option in 2.6.17 there is
no workaround possible for that kernel.
Removed usage of HAVE_V4L1
Including videodev.h will just include videodev2.h if V4L1 is not supported
V4L1 code at core drivers will honor CONFIG_V4L1_COMPAT stuff
Replace hardcoded control description by the standard ones supplied
by v4l2-common.
- improve handling of the EXTERN input: don't start an unnecessary carrier scan
- improve the LOG_STATUS output
- ensure that a carrier scan is started again when switching back to the tuner.
- set correct prescale for L-NICAM
- Remove old DECODER_ commands from tvp5150.c, replacing them with newer
ones if appropriate.
- Small VIDIOC_G_TUNER fixes in msp3400 and tuner.
- Fix VIDIOC_S_TUNER support in em28xx.
- remove obsolete VIDIOC_S_INPUT i2c call in bttv
- translate VIDIOCSFREQ to VIDIOC_S_FREQUENCY in i2c call
- improve muting during carrier scan in msp3400
- don't start scan unless really needed.
- no longer reset chip for msp3400c/d.
- remove v4l2 check in tuner-core (radio stops after using the TV)
- add missing VIDIOC_INT_ strings in v4l2-common.c
- msp3400c did not detect the second carrier, thus being always mono.
- properly mute the msp3400c while detecting the carrier.
- fix checks on the presence of scart2/3 inputs and scart 2 output.
- implement proper audio mode fallbacks for msp3400c/d, identical to the
way msp3400g works.
- MODE_STEREO no longer produces dual languages when set for a bilingual
transmission, instead it falls back to LANG1. Use LANG1_LANG2 to hear
both languages of a bilingual transmission. This is much more intuitive
for the user and is in accordance with the preferred usage in the v4l2
specification.
- bttv tried to implement v4l2 calls with v4l1 calls to the i2c devices,
completely mangling the audmode/rxsubchans handling. v4l2 calls now do
v4l2 calls to the i2c devices.
- fixed broken i2c_vidiocschan in bttv.
- add start/end lines to LOG_STATUS.
The driver tried to set a register that is not present on msp3400c devices.
Add the missing test.
VIDIOC_G/S_AUDOUT does not belong in msp3400 (it's a user level command,
not to be used in internal i2c drivers). Also fix a compile warning and
improve LOG_STATUS.
- implement VIDIOC_INT_S_AUDIO_ROUTING for msp3400 and tvaudio
- use the new command in bttv, pvrusb2 and em28xx.
- remove the now obsolete MSP_SET_MATRIX from msp3400 (yeah!)
- remove the obsolete VIDIOC_S_AUDIO from msp3400.
Moved msp3400.h to msp3400-driver.h.
Created media/msp3400.h with the new routing defines and lots of comments.
Lots of cleanups:
- remove duplicate actions
- add D/K3 Dual FM-Stereo and D/K NICAM FM (HDEV3) support
- put prescales in the proper place
- add missing D/K NICAM
- msp34xxg_reset now only resets instead of also starting the autodetect
(moved that to msp34xxg_thread)
- fix support for SAP.
msp_modus is 'G' model specific. Moved it to kthreads and also added proper
handling for the Japanese and South Korean TV standards.
For the new routing implementation it is easier if all the 'normal'
scart inputs (IN1-IN4) are consecutive.
Cleanup audio input handling in bttv and tvaudio:
- inputs were specified that were never used
- mute was handled as a special input which led to confusing code
- confusing naming made it difficult to see if the setting was for
i2c or gpio.
The old audiochip.h input names moved to tvaudio.h. Currently this
is used both by tvaudio and msp3400 until the msp3400 implements the
new msp3400-specific inputs.
Detect in bttv the tvaudio and msp3400 i2c clients and use these
client pointers to set the inputs directly instead of broadcasting the
command.
Removed AUDC_SET_INPUT. Now replaced by VIDIOC_S_AUDIO. This will be
replaced again later by the new ROUTING commands.
Removed VIDIOC_G_AUDIO implementations in i2c drivers: this command is
a user level command and not to be used internally. It wasn't called at
all anyway.
- Audmode and rxsubchans fixes in msp3400, tuner, tvaudio and cx25840.
- msp3400 cleanups
- Fix handling of VIDIOC_G_TUNER audmode in msp3400: audmode
is only changed by the user with S_TUNER, never by the driver.
