path: root/drivers/media/video/mt9v022.c
2008-05-14V4L/DVB (7859): mt9v022: fix a copy-paste error in commentGuennadi Liakhovetski
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7858): video: build fix for drivers/media/video/mt9v022.cIngo Molnar
x86.git testing found the following build bug on latest -git: CC [M] drivers/media/video/mt9v022.o drivers/media/video/mt9v022.c: In function 'bus_switch_request': drivers/media/video/mt9v022.c:199: error: implicit declaration of function 'gpio_is_valid' drivers/media/video/mt9v022.c:201: error: implicit declaration of function 'gpio_request' drivers/media/video/mt9v022.c:207: error: implicit declaration of function 'gpio_direction_output' drivers/media/video/mt9v022.c:211: error: implicit declaration of function 'gpio_free' drivers/media/video/mt9v022.c: In function 'bus_switch_act': drivers/media/video/mt9v022.c:237: error: implicit declaration of function 'gpio_set_value_cansleep' make[2]: *** [drivers/media/video] Error 2 make[1]: *** [drivers/media] Error 2 make[1]: *** Waiting for unfinished jobs.... make: *** [drivers] Error 2 with this config: http://redhat.com/~mingo/misc/config-Sat_May__3_16_08_39_CEST_2008.bad the bug was that the driver uses GPIO functionality but only includes the GPIO interface definitions for the CONFIG_MT9M001_PCA9536_SWITCH case, which was not set in this config. The quick fix seems to be to include linux/gpio.h unconditionally. (this seems like a small cleanup as well as it removes and #ifdef is more robust than an inclusion of asm/gpio.h) Not tested too much yet, so please have another look in any case. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvbLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (28 commits) V4L-DVB(7789a): cx18: fix symbol conflict with ivtv driver V4L/DVB (7789): tuner: remove static dependencies on analog tuner sub-modules V4L/DVB (7785): [2.6 patch] make mt9{m001,v022}_controls[] static V4L/DVB (7786): cx18: new driver for the Conexant CX23418 MPEG encoder chip V4L/DVB (7783): drivers/media/dvb/frontends/s5h1420.c: printk fix V4L/DVB (7782): pvrusb2: Driver is no longer experimental V4L/DVB (7781): pvrusb2-dvb: include dvb support by default and update Kconfig help text V4L/DVB (7780): pvrusb2: always enable support for OnAir Creator / HDTV USB2 V4L/DVB (7779): pvrusb2-dvb: quiet down noise in kernel log for feed debug Rename common tuner Kconfig names to use the same Fix V4L/DVB core help messages V4L/DVB (7769): Move other terrestrial tuners to common/tuners V4L/DVB (7768): reorganize some DVB-S Kconfig items V4L/DVB(7767): Move tuners to common/tuners V4L/DVB (7766): saa7134: add another PCI ID for Beholder M6 V4L/DVB (7765): Add support for Beholder BeholdTV H6 V4L/DVB (7763): ivtv: add tuner support for the AverMedia M116 V4L/DVB (7762): ivtv: fix tuner detection for PAL-N/Nc V4L/DVB (7761): ivtv: increase the DMA timeout from 100 to 300 ms V4L/DVB (7759): ivtv: increase version number to 1.2.1 ...
2008-04-29V4L/DVB (7785): [2.6 patch] make mt9{m001,v022}_controls[] staticAdrian Bunk
This patch makes the needlessly global mt9{m001,v022}_controls[] static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29i2c: Convert most new-style drivers to use module aliasingJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. Update most new-style i2c drivers to use standard module aliasing instead of the old driver_name/type driver matching scheme. I've left the video drivers apart (except for SoC camera drivers) as they're a bit more diffcult to deal with, they'll have their own patch later. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Jochen Friedrich <jochen@scram.de>
2008-04-29i2c: Add support for device alias namesJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. This patch allows new-style i2c chip drivers to have alias names using the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this point, the old i2c driver binding scheme (driver_name/type) is still supported. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jochen Friedrich <jochen@scram.de> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org>
2008-04-24V4L/DVB (7406): soc-camera: improve separation between soc_camera_ops and ↵Guennadi Liakhovetski
soc_camera_device In case of muliple cameras, handled by the same driver, they can support Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7336): soc-camera: streamline hardware parameter negotiationGuennadi Liakhovetski
Improve hardware parameter negotiation between the camera host driver and camera drivers. Parameters like horizontal and vertical synchronisation, pixel clock polarity shall be set depending on capabilities of the parties. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7249): Fix advertised pixel formats in mt9m001 and mt9v022Guennadi Liakhovetski
Only advertise pixel formats, that we actually can support in the present configuration. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7218): Fix breakage in mt9m001 and mt9v022 driver if ↵Guennadi Liakhovetski
"CONFIG_GENERIC_GPIO is not set" Both camera drivers can function without GPIO support, in which case they will only support the 10 bit data width mode. But the two respective switch have to depend on CONFIG_GENERIC_GPIO. Additionally remove redundant gpio_is_valid tests - they are repeated in bus_switch_request() functions. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7217): Replace NO_GPIO with gpio_is_valid()Guennadi Liakhovetski
Upon suggestion by David Brownell use a gpio_is_valid() predicate instead of an explicit NO_GPIO macro. The respective patch to include/asm-generic/gpio.h has been accepted upstream. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7174): Add support for the MT9V022 cameraGuennadi Liakhovetski
This driver supports Micron MT9V022 colour camera. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
