path: root/drivers/media/video/mt9v022.c
2012-03-08[media] convert drivers/media/* to use module_i2c_driver()Axel Lin
This patch converts the drivers in drivers/media/* to use the module_i2_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Heungjun Kim <riverful.kim@samsung.com> Cc: Joonyoung Shim <jy0922.shim@samsung.com> Cc: Andrew Chew <achew@nvidia.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Michael Grzeschik <m.grzeschik@pengutronix.de> Cc: Johannes Obermaier <johannes.obermaier@gmail.com> Cc: Steven Toth <stoth@kernellabs.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Acked-by: Tomasz Stanislawski <t.stanislaws@samsung.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-23Merge tag 'v3.2-rc2' into staging/for_v3.3Mauro Carvalho Chehab
* tag 'v3.2-rc2': (3068 commits) Linux 3.2-rc2 hfs: add sanity check for file name length fsl-rio: fix compile error blackfin: Fixup export.h includes Blackfin: add serial TX IRQ in individual platform resource virtio-pci: fix use after free ACPI / cpuidle: Remove acpi_idle_suspend (to fix suspend regression) drm/radeon/kms/combios: fix dynamic allocation of PM clock modes [CPUFREQ] db8500: fix build error due to undeclared i variable bma023: Add SFI translation for this device vrtc: change its year offset from 1960 to 1972 ce4100: fix a build error arm/imx: fix imx6q mmc error when mounting rootfs arm/imx: fix AUTO_ZRELADDR selection arm/imx: fix the references to ARCH_MX3 ARM: mx51/53: set pwm clock parent to ipg_perclk btrfs: rename the option to nospace_cache drm/radeon/kms/pm: switch to dynamically allocating clock mode array drm/radeon/kms: optimize r600_pm_profile_init drm/radeon/kms/pm: add a proper pm profile init function for fusion ... Conflicts: drivers/media/radio/Kconfig
2011-11-07[media] v4l: use i2c_smbus_read_word_swappedJonathan Cameron
Function ensures that error codes don't get mangled. Dependant on: which is working it's way through the i2c tree. Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Acked-by: Jean Delvare <khali@linux-fr.org> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-03[media] V4L: mt9m001, mt9v022: use internally cached pixel codeGuennadi Liakhovetski
Using the internally cached pixel code, instead of the one, provided by the soc-camera, removes one more use of struct soc_camera_device in these drivers. Also remove the no longer needed soc_camera_from_i2c() inline function. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-03[media] V4L: soc-camera: start removing struct soc_camera_device from client ↵Guennadi Liakhovetski
drivers Remove most trivial uses of struct soc_camera_device from most client drivers, abstracting some of them inside inline functions. Next steps will eliminate remaining uses and modify inline functions to not use struct soc_camera_device. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-03[media] mt9v022: convert to the control frameworkHans Verkuil
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> [g.liakhovetski@gmx.de: simplified pointer arithmetic] Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-03[media] V4L: mt9v022: remove superfluous soc-camera client operationsGuennadi Liakhovetski
Now that all soc-camera hosts have been ported to use V4L2 subdevice mediabus-config operations and soc-camera client bus-parameter operations have been made optional, they can be removed. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-03[media] V4L: mt9m001, mt9v022: add a clarifying commentGuennadi Liakhovetski
2011-11-03[media] V4L: mt9v022: support the new mbus-config subdev opsGuennadi Liakhovetski
Extend the driver to also support [gs]_mbus_config() subdevice video operations. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-10-31drivers/media: Add module.h to all files using it implicitlyPaul Gortmaker
A pending cleanup will mean that module.h won't be implicitly everywhere anymore. Make sure the modular drivers in clocksource are actually calling out for <module.h> explicitly in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-07-27[media] V4L: soc-camera: remove soc-camera bus and devices on itGuennadi Liakhovetski
Now that v4l2 subdevices have got their own device objects, having one more device in soc-camera clients became redundant and confusing. This patch removes those devices and the soc-camera bus, they used to reside on. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] V4L: mt9v022: fix pixel clockTeresa Gámez
The setup of the pixel clock is done wrong in the mt9v022 driver. The 'Invert Pixel Clock' bit has to be set to 1 for falling edge and not for rising. This is not clearly described in the data sheet. Tested on pcm037 and pcm027/pcm990. Signed-off-by: Teresa Gámez <t.gamez@phytec.de> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: Rename V4L2_MBUS_FMT_GREY8_1X8 to V4L2_MBUS_FMT_Y8_1X8Laurent Pinchart
For consistency with the V4L2_MBUS_FMT_Y10_1X10 format. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] media: video: do not clear 'driver' from an i2c_clientWolfram Sang
The i2c-core does this already. Reported-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: v4l: Use v4l2_get_subdevdata instead of accessing v4l2_subdev::privLaurent Pinchart
Replace direct access to the v4l2_subdev priv field with the inline v4l2_get_subdevdata method. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-09-27V4L/DVB: mt9v022.c: Fixed compilation warningIonut Gabriel Popescu
The drivers/media/video/mt9v022.c file, on line 405, tries a "case 0" o a v4l2_mbus_pixelcode enum which don't have an 0 value element, so I got a compile warning. That "case" is useless so it can be removed. Signed-off-by: Ionut Gabriel Popescu <poyo_vl@yahoo.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-06-04Merge branch 'v4l_for_2.6.35' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_2.6.35' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (87 commits) V4L/DVB: ivtv: Timing tweaks and code re-order to try and improve stability V4L/DVB: ivtv: Avoid accidental video standard change V4L/DVB: ivtvfb : Module load / unload fixes V4L/DVB: cx2341x: Report correct temporal setting for log-status V4L/DVB: cx18, cx23885, v4l2 doc, MAINTAINERS: Update Andy Walls' email address V4L/DVB: drivers/media: Eliminate a NULL pointer dereference V4L/DVB: dvb-core: Fix ULE decapsulation bug V4L/DVB: Bug fix: make IR work again for dm1105 V4L/DVB: media/IR: nec-decoder needs to select BITREV V4L/DVB: video/saa7134: change dprintk() to i2cdprintk() V4L/DVB: video/saa7134: remove duplicate break V4L/DVB: IR/imon: add auto-config for 0xffdc rf device V4L/DVB: IR/imon: clean up usage of bools V4L/DVB: em28xx: remove unneeded null checks V4L/DVB: ngene: remove unused #include <linux/version.h> V4L/DVB: ak881x needs slab.h V4L/DVB: FusionHDTV: Use quick reads for I2C IR device probing V4L/DVB: Technotrend S2-3200 ships with a TT 1500 remote V4L/DVB: drivers/media: Use kzalloc V4L/DVB: m920x: Select simple tuner ...
2010-06-03i2c: Remove all i2c_set_clientdata(client, NULL) in driversWolfram Sang
I2C drivers can use the clientdata-pointer to point to private data. As I2C devices are not really unregistered, but merely detached from their driver, it used to be the drivers obligation to clear this pointer during remove() or a failed probe(). As a couple of drivers forgot to do this, it was agreed that it was cleaner if the i2c-core does this clearance when appropriate, as there is no guarantee for the lifetime of the clientdata-pointer after remove() anyhow. This feature was added to the core with commit e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers. As there is no need anymore to clear the clientdata-pointer, remove all current occurrences in the drivers to simplify the code and prevent confusion. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-06-01V4L/DVB: v4l2-subdev.h: fix enum_mbus_fmt prototypeHans Verkuil
enum_mbus_fmt received an index argument that was defined as an int instead of an unsigned int. This is now fixed. This had the knock-on effect that the index argument in the callback get_formats in soc_camera.h also had to be changed to unsigned int. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-18V4L/DVB: The first two parameters of soc_camera_limit_side() are usually ↵Márton Németh
pointers to struct v4l2_rect elements. They are signed, so adjust the prototype accordingly This will remove the following sparse warning (see "make C=1"): * incorrect type in argument 1 (different signedness) expected unsigned int *start got signed int *<noident> as well as a couple more signedness mismatches. Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26soc-camera: update mt9v022 to take into account board signal routingGuennadi Liakhovetski
Use soc_camera_apply_sensor_flags() in mt9v022 to account for any inverters in video signal paths. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13659): soc-camera: convert to the new mediabus APIGuennadi Liakhovetski
Convert soc-camera core and all soc-camera drivers to the new mediabus API. This also takes soc-camera client drivers one step closer to also be usable with generic v4l2-subdev host drivers. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13645): soc-camera: fix multi-line comment coding styleGuennadi Liakhovetski
2009-12-16V4L/DVB (13644): v4l: add new v4l2-subdev sensor operations, use ↵Guennadi Liakhovetski
g_skip_top_lines in soc-camera Introduce new v4l2-subdev sensor operations, move .enum_framesizes() and .enum_frameintervals() methods to it, add a new .g_skip_top_lines() method and switch soc-camera to use it instead of .y_skip_top soc_camera_device member, which can now be removed. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Reviewed-by: Sergio Aguirre <saaguirre@ti.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12536): soc-camera: remove .gain and .exposure struct ↵Guennadi Liakhovetski
soc_camera_device members This makes the soc-camera interface for V4L2 subdevices thinner yet. Handle gain and exposure internally in each driver just like all other controls. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12535): soc-camera: remove .init() and .release() methods from ↵Guennadi Liakhovetski
struct soc_camera_ops Remove unneeded soc-camera operations, this also makes the soc-camera API to v4l2 subdevices thinner. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12534): soc-camera: V4L2 API compliant scaling (S_FMT) and cropping ↵Guennadi Liakhovetski
(S_CROP) The initial soc-camera scaling and cropping implementation turned out to be incompliant with the V4L2 API, e.g., it expected the user to specify cropping in output window pixels, instead of input window pixels. This patch converts the soc-camera core and all drivers to comply with the standard. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12531): soc-camera: Use I2C device for dev_{dbg,info,...} output in ↵Guennadi Liakhovetski
all clients Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12529): soc-camera: switch to s_crop v4l2-subdev video operationGuennadi Liakhovetski
Remove set_crop soc-camera device method and switch to s_crop from v4l2-subdev video operations. Also extend non-i2c drivers to also hold a pointer to their v4l2-subdev instance in control device driver-data, i.e., in dev_get_drvdata((struct device *)to_soc_camera_control(icd)) Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12515): soc-camera: use struct v4l2_rect in struct soc_camera_deviceGuennadi Liakhovetski
Switch to using struct v4l2_rect in struct soc_camera_device for uniformity and simplicity. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12510): soc-camera: (partially) convert to v4l2-(sub)dev APIGuennadi Liakhovetski
Convert the soc-camera framework to use the v4l2-(sub)dev API. Start using v4l2-subdev operations. Only a part of the interface between the soc_camera core, soc_camera host drivers on one side and soc_camera device drivers on the other side is replaced so far. The rest of the interface will be replaced in incremental steps, and will require extensions and, possibly, modifications to the v4l2-subdev code. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12506): soc-camera: convert to platform deviceGuennadi Liakhovetski
Convert soc-camera core and all drivers to platform device API. We already converted platforms to register a platform device for each soc-camera client, now we remove the compatibility code and switch completely to the new scheme. This is a preparatory step for the v4l2-subdev conversion. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-23V4L/DVB (11910): mt9: Use v4l bounding/alignment functionTrent Piepho
The v4l function has a better algorithm for aligning image size. Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11610): soc-camera: simplify register access routines in multiple ↵Guennadi Liakhovetski
sensor drivers Register access routines only need the I2C client, not the soc-camera device context. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11607): soc-camera: add a free_bus method to struct soc_camera_linkGuennadi Liakhovetski
Currently pcm990 camera bus-width management functions request a GPIO and never free it again. With this approach the GPIO extender driver cannot be unloaded once camera drivers have been loaded, also unloading theb i2c-pxa bus driver produces errors, because the GPIO extender driver cannot unregister properly. Another problem is, that if camera drivers are once loaded before the GPIO extender driver, the platform code marks the GPIO unavailable and only a reboot helps to recover. Adding an explicit free_bus method and using it in mt9m001 and mt9v022 drivers fixes these problems. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (11033): mt9v022: allow setting of bus width from board codeSascha Hauer
This patch removes the phytec specific setting of the bus width and switches to the more generic query_bus_param/set_bus_param hooks Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (11024): soc-camera: separate S_FMT and S_CROP operationsGuennadi Liakhovetski
As host and camera drivers become more complex, differences between S_FMT and S_CROP functionality grow, this patch separates them. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10665): soc-camera: add data signal polarity flags to driversGuennadi Liakhovetski
All soc-camera camera and host drivers must specify supported data signal polarity, after all drivers are fixed, we'll add a suitable test to soc_camera_bus_param_compatible(). Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10141): v4l2: debugging API changed to match against driver name ↵Hans Verkuil
instead of ID. Since the i2c driver ID will be removed in the near future we have to modify the v4l2 debugging API to use the driver name instead of driver ID. Note that this API is not used in applications other than v4l2-dbg.cpp as it is for debugging and testing only. Should anyone use the old VIDIOC_G_CHIP_IDENT, then this will be logged with a warning that it is deprecated and will be removed in 2.6.30. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10091): mt9m001 mt9v022: simplify pointer dereferncesGuennadi Liakhovetski
Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10080): soc-camera: readability improvements, more strict ↵Guennadi Liakhovetski
operations checks Simplify multiple drivers by replacing f->fmt.pix.* with a single pointer dereference, merge some needlessly broken lines, verify host and camera operations pointers on registration. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10072): soc-camera: Add signal inversion flags to be used by camera ↵Guennadi Liakhovetski
drivers As reported by Antonio Ospite <ospite@studenti.unina.it> two platforms with a mt9m111 camera require opposite pixel clock polarity, which means one of them inverts it. This patch adds support for inversion flags and switches all available camera drivers to using them. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10066): mt9m001 mt9v022: fix bus-width switch GPIO availability testGuennadi Liakhovetski
Testing for non-NULL platform-data is not enough, we have to check if the GPIO in the platform data is valid or not. Also see my earlier patch: [ARM] pxa/pcm990: use negative number for an invalid GPIO in camera data Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9788): soc-camera: simplify namingGuennadi Liakhovetski
We anyway don't follow the s_fmt_vid_cap / g_fmt_vid_cap / try_fmt_vid_cap naming, and soc-camera is so far only about video capture, let's simplify operation names a bit further. set_fmt_cap / try_fmt_cap wasn't a very good choice too. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8687): soc-camera: Move .power and .reset from soc_camera host to ↵Stefan Herbrechtsmeier
sensor driver Make .power and .reset callbacks per camera instead of per host, also move their invocation to camera drivers. .arch/arm/mach-pxa/include/mach/camera.h | 2 - Signed-off-by: Stefan Herbrechtsmeier <hbmeier@hni.uni-paderborn.de> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8685): mt9m001, mt9v022: Simplify return code checkingGuennadi Liakhovetski
i2c_smbus_write_word_data() returns 0 or a negative error, hence no need to check for "> 0". Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-08-01Remove newline from the description of module parametersNiels de Vos
Some module parameters with only one line have the '\n' at the end of the description. This is not needed nor wanted as after the description the type (i.e. int) is followed by a newline. Some modules contain a multi-line description, these are not affected by this patch. Signed-off-by: Niels de Vos <niels.devos@wincor-nixdorf.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: John W. Linville <linville@tuxdriver.com> Cc: Ed L. Cashin <ecashin@coraid.com> Cc: Dave Airlie <airlied@linux.ie> Cc: Roland Dreier <rolandd@cisco.com> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20V4L/DVB (8143): Fix compilation for mt9v022Mauro Carvalho Chehab
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7859): mt9v022: fix a copy-paste error in commentGuennadi Liakhovetski
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
