path: root/drivers/media/video/ov7670.c
2011-07-27[media] marvell-cam: Move cafe-ccic into its own directoryJonathan Corbet
This driver will soon become a family of drivers, so let's give it its own place to live. This move requires putting ov7670.h into include/media, but there are no code changes. Cc: Daniel Drake <dsd@laptop.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-01-19[media] v4l2-subdev: remove core.s_config and v4l2_i2c_new_subdev_cfg()Hans Verkuil
The core.s_config op was meant for legacy drivers that needed to work with old pre-2.6.26 kernels. This is no longer relevant. Unfortunately, this op was incorrectly called from several drivers. Replace those occurences with proper i2c_board_info structs and call v4l2_i2c_new_subdev_board. After these changes v4l2_i2c_new_subdev_cfg() was no longer used, so remove that function as well. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-23[media] ov7670: allow configuration of image size, clock speed, and I/O methodDaniel Drake
These parameters need to be configurable based on the host system. They can now be communicated through the s_config call. The old CONFIG_OLPC_XO_1 selector was not correct; this kind of arrangement wouldn't allow for a universal kernel that would work on both laptops. Certain parts of the probe routine had to be moved later (into s_config), because we can't do any I/O until we know which I/O method has been selected through this mechanism. Signed-off-by: Daniel Drake <dsd@laptop.org> Acked-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21[media] ov7670: fix QVGA visible areaDaniel Drake
The QVGA mode has a green horizontal line on the left hand side, and a red (or sometimes blue) vertical line at the bottom. Tweak the visible area to remove them. Thanks to Mauro for explaining how to fix this. Signed-off-by: Daniel Drake <dsd@laptop.org> Acked-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21[media] ov7670: implement VIDIOC_ENUM_FRAMESIZESDaniel Drake
GStreamer uses this. Signed-off-by: Daniel Drake <dsd@laptop.org> Acked-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21[media] ov7670: implement VIDIOC_ENUM_FRAMEINTERVALSJonathan Corbet
Inquiring minds (and gstreamer) want to know. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: ov7670: remove obsolete v4l2-i2c-drv.h headerHans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: ov7670: remove obsolete enum/try/s_fmt opsHans Verkuil
2010-10-21V4L/DVB: ov7670: add enum/try/s_mbus_fmt supportHans Verkuil
2010-05-18V4L/DVB: ov7670: silence some compiler warningsJonathan Corbet
Get rid of some "unused variable" warnings. These were the result of sloppiness and should not have happened; I'll go stand in the corner now. Reported-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-18V4L/DVB: ov7670: Always rewrite clkrc when setting formatJonathan Corbet
That makes frame rate configuration persistent. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-18V4L/DVB: ov7670: Restore SMBUS I/O for the XO 1.0Jonathan Corbet
The Cafe controller doesn't do non-SMBUS I/O, so we have to use it there. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-18V4L/DVB: ov7670: wire up controls for exposure and autoexposureJonathan Corbet
2010-05-18V4L/DVB: ov7670: Wire up V4L2_CID_GAIN and V4L2_CID_AUTOGAINJonathan Corbet
Allow applications to play with the gain settings. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-18V4L/DVB: ov7670: Don't use SMBUS I/OJonathan Corbet
Contrary to my earlier belief, the ov7670 is not actually an SMBUS device, though it will pretend to be one if it's in a good mood. Unfortunately, it's rarely in a good mood, especially on the XO 1.5. So use low-level i2c I/O instead. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-18V4L/DVB: ov7670: Avoid reading clkrcJonathan Corbet
Reading the clkrc register creates flaky behavior in some situations, and we can easily track its state separately. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-18V4L/DVB: ov7670: Use CCIR601 in all video modesJonathan Corbet
Also provide for a longer delay after reset - the XO 1.5 needs it. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-03-30V4L/DVB (11117): ov7670: add support to get/set registersHans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Acked-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (11116): ov7670: cleanup and remove legacy code.Hans Verkuil
v4l2-i2c-drv-legacy.h and ov7670_command are no longer needed after the cafe driver is converted to use v4l2_subdev. Rather than using a large ov7670_control array, just call the handlers via a simple switch and use v4l2_ctrl_query_fill() to handle queryctrl. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Acked-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (11113): ov7670: convert to v4l2_subdevHans Verkuil
2009-03-30V4L/DVB (10907): avoid loading the entire videodev.h header on V4L2 driversMauro Carvalho Chehab
2009-01-07i2c: Drop I2C_CLASS_CAM_DIGITALJean Delvare
There are a number of drivers which set their i2c bus class to I2C_CLASS_CAM_DIGITAL, however no chip driver actually checks for this flag, so we might as well drop it now. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-01-02V4L/DVB (10141): v4l2: debugging API changed to match against driver name ↵Hans Verkuil
instead of ID. Since the i2c driver ID will be removed in the near future we have to modify the v4l2 debugging API to use the driver name instead of driver ID. Note that this API is not used in applications other than v4l2-dbg.cpp as it is for debugging and testing only. Should anyone use the old VIDIOC_G_CHIP_IDENT, then this will be logged with a warning that it is deprecated and will be removed in 2.6.30. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-07-20V4L/DVB (8381): ov7670: fix compile warningsHans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Acked-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (8318): OV7670: don't reject unsupported settingsDaniel Drake
For VIDIOC_G_FMT/VIDIOC_TRY_FMT, the V4L2 API spec states: "Drivers should not return an error code unless the input is ambiguous" "Very simple, inflexible devices may even ignore all input and always return the default parameters." "When the requested buffer type is not supported drivers return an EINVAL error code." i.e. returning errors for unsupported fields is bad, and it's ok to unconditionally overwrite user-requested settings This patch makes ov7670 meet that behaviour, and brings it in line with other drivers e.g. stk-webcam. It also fixes compatibility with (unpatched) gstreamer. Signed-off-by: Daniel Drake <dsd@laptop.org> Acked-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-12ov7670: clean up ov7670_read semanticsAndres Salomon
Cortland Setlow pointed out a bug in ov7670.c where the result from ov7670_read() was just being checked for !0, rather than <0. This made me realize that ov7670_read's semantics were rather confusing; it both fills in 'value' with the result, and returns it. This is goes against general kernel convention; so rather than fixing callers, let's fix the function. This makes ov7670_read return <0 in the case of an error, and 0 upon success. Thus, code like: res = ov7670_read(...); if (!res) goto error; ..will work properly. Signed-off-by: Cortland Setlow <csetlow@tower-research.com> Signed-off-by: Andres Salomon <dilinger@debian.org> Acked-by: Jonathan Corbet <corbet@lwn.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-09V4L/DVB (6079): Cleanup: remove linux/moduleparam.h from drivers/media filesMauro Carvalho Chehab
Since at least kernel 2.6.12-rc2, module.h includes moduleparm.h. This patch removes all occurences of moduleparm.h from drivers/media files. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-08-20V4L/DVB (6027): Get rid of an ill-behaved msleep in i2c writeJonathan Corbet
Configuring the OLPC camera requires something over 150 register writes. Unfortunately, querying the CAFE i2c controller too soon after a write causes the hardware to flake. The problem had been "solved" with an msleep() call, but, between the number of registers and how msleep() behaves, that resulted in a 3-second delay on camera initialization. Instead, we hand-code a wait for the completion interrupt which avoids reading the status registers. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5739): Replace C code with calls to ARRAY_SIZE macro.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-22V4L/DVB (5691): Ov7670: reset clkrc in rgb565 modeJonathan Corbet
A bug in the ov7670 sensor causes it to introduce noise unless the CLKRC register is rewritten *after* setting the image mode. Naturally, resetting CLKRC in this way will cause other modes to fail. So carefully poke the register only when indicated. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5469): Add raw bayer support to the ov7670 driverJonathan Corbet
Add raw bayer support to the ov7670 driver Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5469a): Copyright and maintainer tweaksJonathan Corbet
Fix up Cafe/ov7670 copyrights and maintainer entries Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5468): Don't mirror ov7670 images by defaultJonathan Corbet
Don't mirror ov7670 images by default. The ov7670 sensor driver sets the mirror bit by default, which is not the desired mode. OLPC has been running with this patch for a while. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5306): Add support for VIDIOC_G_CHIP_IDENTHans Verkuil
VIDIOC_G_CHIP_IDENT improves debugging of card problems: it can be used to detect which chips are on the board and based on that information selected register dumps can be made, making it easy to debug complicated media chips containing tens or hundreds of registers. This ioctl replaces the internal VIDIOC_INT_G_CHIP_IDENT ioctl. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-12Jon needs a new shift key.Dave Jones
Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-10V4L/DVB (4909): Add s/g_parm to cafe_ccicJonathan Corbet
Add s/g_parm support allowing applications to tweak the frame rate. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4908): Remove the fake RGB32 format from cafe_ccicJonathan Corbet
Remove RGB32, useful for debugging, but with no place in production. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4842): Updated camera driverJonathan Corbet
A couple of Cafe driver fixes, and support for the hue and saturation controls. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4798): OmniVision OV7670 driverJonathan Corbet
This patch adds a V4L2 driver for the OmniVision OV7670 camera. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
