path: root/drivers/media/video/ov9640.c
2011-07-27[media] V4L: soc-camera: remove soc-camera bus and devices on itGuennadi Liakhovetski
Now that v4l2 subdevices have got their own device objects, having one more device in soc-camera clients became redundant and confusing. This patch removes those devices and the soc-camera bus, they used to reside on. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-30[media] ov9640: fix OmniVision OV9640 sensor driver's priv data retrievingDavid Cohen
OmniVision OV9640 driver wasn't requesting properly its private data on I2C remove and video_probe functions. It was retrieving the V4L2 subdev struct address instead of priv struct's one. This patch fixes such problem. Signed-off-by: David Cohen <dacohen@gmail.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-30[media] ov9640: use macro to request OmniVision OV9640 sensor private dataDavid Cohen
This cleanup patch creates macro to request OmniVision OV9640 private data, which increases readability. Signed-off-by: David Cohen <dacohen@gmail.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: v4l: Use v4l2_get_subdevdata instead of accessing v4l2_subdev::privLaurent Pinchart
Replace direct access to the v4l2_subdev priv field with the inline v4l2_get_subdevdata method. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-02V4L/DVB: mediabus: fix ambiguous pixel code namesGuennadi Liakhovetski
Endianness notation is meaningless for 8 bit YUYV codes. Switch pixel code names to explicitly state the order of colour components in the data stream. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-06-04Merge branch 'v4l_for_2.6.35' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_2.6.35' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (87 commits) V4L/DVB: ivtv: Timing tweaks and code re-order to try and improve stability V4L/DVB: ivtv: Avoid accidental video standard change V4L/DVB: ivtvfb : Module load / unload fixes V4L/DVB: cx2341x: Report correct temporal setting for log-status V4L/DVB: cx18, cx23885, v4l2 doc, MAINTAINERS: Update Andy Walls' email address V4L/DVB: drivers/media: Eliminate a NULL pointer dereference V4L/DVB: dvb-core: Fix ULE decapsulation bug V4L/DVB: Bug fix: make IR work again for dm1105 V4L/DVB: media/IR: nec-decoder needs to select BITREV V4L/DVB: video/saa7134: change dprintk() to i2cdprintk() V4L/DVB: video/saa7134: remove duplicate break V4L/DVB: IR/imon: add auto-config for 0xffdc rf device V4L/DVB: IR/imon: clean up usage of bools V4L/DVB: em28xx: remove unneeded null checks V4L/DVB: ngene: remove unused #include <linux/version.h> V4L/DVB: ak881x needs slab.h V4L/DVB: FusionHDTV: Use quick reads for I2C IR device probing V4L/DVB: Technotrend S2-3200 ships with a TT 1500 remote V4L/DVB: drivers/media: Use kzalloc V4L/DVB: m920x: Select simple tuner ...
2010-06-03i2c: Remove all i2c_set_clientdata(client, NULL) in driversWolfram Sang
I2C drivers can use the clientdata-pointer to point to private data. As I2C devices are not really unregistered, but merely detached from their driver, it used to be the drivers obligation to clear this pointer during remove() or a failed probe(). As a couple of drivers forgot to do this, it was agreed that it was cleaner if the i2c-core does this clearance when appropriate, as there is no guarantee for the lifetime of the clientdata-pointer after remove() anyhow. This feature was added to the core with commit e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers. As there is no need anymore to clear the clientdata-pointer, remove all current occurrences in the drivers to simplify the code and prevent confusion. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-06-01V4L/DVB: v4l2-subdev.h: fix enum_mbus_fmt prototypeHans Verkuil
enum_mbus_fmt received an index argument that was defined as an int instead of an unsigned int. This is now fixed. This had the knock-on effect that the index argument in the callback get_formats in soc_camera.h also had to be changed to unsigned int. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-18V4L/DVB: Fix bad whitespacingMauro Carvalho Chehab
2009-12-16V4L/DVB (13659): soc-camera: convert to the new mediabus APIGuennadi Liakhovetski
Convert soc-camera core and all soc-camera drivers to the new mediabus API. This also takes soc-camera client drivers one step closer to also be usable with generic v4l2-subdev host drivers. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13040): V4L2: Add a v4l2-subdev (soc-camera) driver for OmniVision ↵Marek Vasut
OV9640 sensor Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
